Author Topic: sharping chain?  (Read 1867 times)
Offline minesmoria
sharping chain?
« on: October 29, 2004, 07:08:36 PM »
I bought a dremel  stone tool.
It says to use pink stone for 3/8 pitch 7/32
blue stone 5/ 32 for 3/8  low profile lp
I dont know if i have lp chain or not, should i just try both and see which one gets it the sharpest?
Offline SasquatchMan
  • Get it done.
Re: sharping chain?
« Reply #1 on: October 29, 2004, 07:53:04 PM »
I think it's more to do with how well the stone fits inside the curve of the cutter....
Senior Member?  That's funny.
Offline tony_marks
Re: sharping chain?
« Reply #2 on: October 30, 2004, 04:33:24 AM »
 its probably to late now .. but if u use that stone.. a little bit goes a real long way..
mabe u can donate one chain to learning how to use the new tool..
then just a little bit should bring the edge back,on the next chain..
jmo
Offline jokers
  • Chainsaw Freak
Re: sharping chain?
« Reply #3 on: October 30, 2004, 07:50:07 AM »
What model # is your chain? provide us with any identifying numbers and someone will help you determine what size chain you have, it`s really key to use the right diameter stone or file.
Russ
Offline minesmoria
Re: sharping chain?
« Reply #4 on: October 30, 2004, 11:16:46 AM »
The chain is 3/8 .50 guage oregon 72 i dont now if it is lp or not.
Offline jokers
  • Chainsaw Freak
Re: sharping chain?
« Reply #5 on: October 30, 2004, 11:45:42 AM »
If it is 72, it`s standard 3/8 and the 7/32 stone would be correct until you are ground back about half way on the tooth, then switch to a 3/16 stone to maintain the correct sideplate angle.
Russ
Offline rahtreelimbs
  • Confirmed Chainsaw Addict!!!
Re: sharping chain?
« Reply #6 on: October 30, 2004, 07:47:04 PM »
Lose the Dremel (junk.....big time) and learn to hand file. ;)
Nothing Like A  Modded Saw To Start Your Day!!![/SIZE]† † † † † † †  Later, Rich.
Offline sigidi
Re: sharping chain?
« Reply #7 on: November 01, 2004, 02:39:25 AM »
My 2 cents worth and by no means an expert opinion...
I've sharpened chain about 10 times now - the first sharpen was done by a dealer using a grinding machine - wasn't really impressed and was spurred on to learn myself really fast. ($12AUS for an 18" bar chain)
It's probably taken the first 5 hand sharpens for me to be happy with how it cuts and it's cutting much better now - at least it travels straight through the cut now!!!!
I'm using a Sharpboy Precision Filing Guide each sharpen - it is a bit to set up (5-7 mins) but it gives good results and I don't use the saw much, just trimming logs for the mill so I can sharpen at home of a nighttime.
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
Re: sharping chain?
« Reply #8 on: November 01, 2004, 04:10:36 AM »
I hit a bunch of steel with my chain (my fault) so I took it to the dealer to be resharpened.  Cost $10 for the resharpen, same as a new chain for that saw.  Guess who will sharpen his own or just replace from now on?  ::)
chain saw sharping
Started by kardar2 on Chainsaws
Last post November 10, 2012, 11:59:12 PM
by kardar2
The joy of sharping chain at 10 degrees
Started by alsayyed on Chainsaws
Last post July 24, 2007, 06:35:59 PM
by Tony_T
Chain sharping for lazy people
Started by treeboy on Chainsaws
Last post November 27, 2005, 11:55:36 AM
by redpowerd
blade sharping
Started by sawwood on Sawmills and Milling
Last post June 24, 2010, 10:15:47 PM
by tyb525
