Arborwear
Author Topic: sawmill from ground up  (Read 8712 times)
Offline metalshaper
Re: sawmill from ground up
« Reply #20 on: May 15, 2016, 08:40:24 AM »
yes it sure does need wheels.  I have been searching for some for a long time but just can't seem to come up with any.  Farquhar made this steam engine in portable, meaning with wheels, and what they called a sill boiler.  This is the sill boiler but it has all the mounts for wheels.  If I don't find wheels I will just drag it into place and set on some concrete sills.  More to follow.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #21 on: May 15, 2016, 09:23:48 AM »
Penns cave in Pa. has a sale every June and that would be the best place to find large wheels
for steam engines.
http://www.nittanyantique.org/spring.php
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline ozarkgem
  • age 65 yrs old
« Reply #22 on: May 15, 2016, 07:07:06 PM »
That is the coolest sawmill project I have ever seen. Wish you were closer. I would like to help on it.
Offline Mooseherder
« Reply #23 on: May 15, 2016, 11:32:54 PM »
Our Husk frames will be cousins. ;)
Lane Circle Mill
Offline metalshaper
« Reply #24 on: May 28, 2016, 01:45:45 PM »
more work on the sawmill build.  Long way to go before I start making sawdust but this is where time spent on setup will pay off in the long run.  still working on getting my husk platform setup.  Photos to follow.  footings finally finished.
Offline metalshaper
« Reply #25 on: May 28, 2016, 01:46:52 PM »
Legs getting welded to main husk frame.
Offline metalshaper
« Reply #26 on: May 28, 2016, 01:47:57 PM »
finish welded, and primed with my favorite primer....Red Lead.
Offline metalshaper
« Reply #27 on: May 28, 2016, 01:49:01 PM »
Offline metalshaper
« Reply #28 on: May 28, 2016, 01:49:25 PM »
Offline metalshaper
« Reply #29 on: May 28, 2016, 01:51:04 PM »
Carefully setting it on the footings.  the guy near the transit is my buddy Bill.  He is the guy I got the sawmill from and he is helping me in the reassembly of it.
Offline metalshaper
« Reply #30 on: May 28, 2016, 01:53:59 PM »
After careful pouring of the footings, precision cutting of the legs, and gently setting it down on the steel plates, a quick check with the transit shows the entire husk from is less than 1/32" out of level.
Offline metalshaper
« Reply #31 on: May 28, 2016, 01:55:47 PM »
Welding the legs to the 12"x12" steel plates.  Since I was going to be in the dirt for this part of the project I decided to get out the suitcase wire feeder and run some flux core wire, instead of stick welding with 7018.
Offline metalshaper
« Reply #32 on: May 28, 2016, 01:56:57 PM »
finished welding and getting ready to prime.  Rain on the way so I need to get some primer to the fresh sandblasted plates.
Offline metalshaper
« Reply #33 on: May 28, 2016, 01:59:37 PM »
More red lead and plenty of time to spare before the rain.  This is where the project is at the current time.  Husk is in great shape and that will be getting installed next.  At the same time I am going to be pouring footings for the building that will cover the entire mill.   Since I am not sawing yet I am putting out some feelers to see if there is anybody local to me that might be interested in doing some sawing so I can get the roof over this project.
Offline tnaz
  • Retired; with a Full Time Task! Of my Choosen
« Reply #34 on: May 28, 2016, 02:27:19 PM »
Thanks for all the pictures, looking Pretty DanG good.  8)
Keep up the good work,
Terry
Offline fishfighter
« Reply #35 on: May 28, 2016, 04:18:26 PM »
That is one heck of a project. Way to cool.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #36 on: May 28, 2016, 04:33:28 PM »
Within a 1/32"?  That's amazing to me.  Guess we're a little more crude around here.  :D
Awesome project and thanks for taking the time to share the pictures with all of us.
Offline sealark37
« Reply #37 on: May 28, 2016, 07:41:49 PM »
Somebody is going to sweat their socks wet feeding that steam boiler!     Regards, Clark
Offline metalshaper
« Reply #38 on: July 21, 2016, 02:45:45 PM »
still making slow but steady progress on the sawmill build.  Summer temperatures are in the 90's for the next seven days so early morning is the only time to get things done.  This morning I decided to move the husk onto its final resting place.  some photos of the move.
Offline metalshaper
« Reply #39 on: July 21, 2016, 02:48:47 PM »
This 210 john deere  backhoe can easily lift 3000 pounds and load a dump truck all day.  This cast iron husk really made it struggle to get the job done.  Not the fanciest pick, but it balanced good and made the trip out back without any trouble.
Local sawmill burns to the ground
Started by Sawyerfortyish on General Board
Last post September 10, 2007, 04:21:17 PM
by redoakrich
hollow ground (wheel) vs. flat ground
Started by Greg on Timber Framing/Log construction
Last post June 03, 2005, 11:40:30 AM
by Doc
Ground Hog's Day
Started by Corley5 on General Board
Last post February 04, 2004, 03:22:28 PM
by shopteacher
Ground Hog Day?
Started by Dana on Technical Support Topics
Last post April 10, 2006, 05:39:53 PM
by Buzz-sawyer
