Baltic Abrasives Technologies
Author Topic: More Pics of my sawmill build  (Read 35501 times)
Offline larrydown60
« on: May 17, 2016, 11:39:02 PM »
I am finally working on the sawmill. Here is some pictures of what I have been doing this week. I had to buy a welder and teach myself how to use it. The welding is getting easier every day. Did some bartering with a fabricator he got his stuff done and I got the shaft. So Had to start welding myself a little slow at first but going good now. I hope to have the log stops and the locks on the sawmill frame in the next couple of days. I will post more pics tomorrow of the saw mill boxes I am building for the head and bearing holders for the pulley shafts sure takes a lot of time prepping everything to weld and the grinder has gotten me a few times. LOL
Online ljohnsaw
Re: More Pics of my sawmill build
« Reply #1 on: May 17, 2016, 11:48:07 PM »
Larry, do you have an iPhone??  You might want to look at your post on a normal computer and see if you can rotate your pictures - I'm getting dizzy! :D
Did you build the trailer frame or did you purchase that and are adding your mill track?  Looks pretty heavy duty!  Tandem axle to boot - planning on hauling logs with it as well?  Did you put on the removable hitch?
John Sawicky
Offline Picky2016
  • I'm new but trying!
« Reply #2 on: May 18, 2016, 06:54:16 AM »
Nice bed, I'm watching. Giving me some ideas for my next build lol.
Offline larrydown60
« Reply #3 on: May 18, 2016, 07:38:53 PM »
I did buy the trailer but I have been rebuilding it I have pics in my gallery of what I started with and I did put the removeable hitch on it I hate hitting my shins  thanks
Offline larrydown60
« Reply #4 on: May 18, 2016, 07:39:51 PM »
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #5 on: May 18, 2016, 08:00:15 PM »
Looks stout and with nice paint.  Mills like to rust what with the wet sawdust and all.
Offline larrydown60
« Reply #6 on: May 18, 2016, 08:09:36 PM »
Here is more pics of what I got done today Sawmill tension box, log stops installed,and Saw Mount Drive Pulley Arbor and idle side pulley arbor
Offline larrydown60
« Reply #7 on: May 18, 2016, 08:14:00 PM »
Thanks tractor paint. Sanded Primer and 2 coats should last a little while. LOL I hope
Offline tnaz
  • Retired; with a Full Time Task! Of my Choosen
« Reply #8 on: May 18, 2016, 08:42:57 PM »
Looking good!!!
Online ljohnsaw
« Reply #9 on: May 18, 2016, 11:49:14 PM »
Larry, I thought you had welded on the angle iron for your carriage to ride on but that doesn't look like the case.  What will your saw head be traveling on?
John Sawicky
Offline larrydown60
« Reply #10 on: May 19, 2016, 12:51:54 AM »
On the bottom outside angle I will weld 1x1 angle upside down so the v groove wheel Ride on upside down angle. I just Ordered the wheels tonight. Plan on making the sawmill lift boxes, and the log locks tomorrow
Offline larrydown60
« Reply #11 on: May 19, 2016, 09:46:37 PM »
Didn't get much accomplished today spent the day chasing down welding gas and looking through the scrap yard for more steel. Got one of the moveable log locks built, and cut the bottom of the log back stops out so they will slide up and down instead of making different lengths of the stops
Offline larrydown60
« Reply #12 on: May 20, 2016, 10:04:38 AM »
John, I did figure out how to rotate the pics in the gallery but I am not sure how to rotate the ones that are in the post Sorry, I see I can rotate them when posting
Offline pineywoods
« Reply #13 on: May 20, 2016, 10:09:57 AM »
Larry, I think you have missed an important point.  There are NO pics in your post, only a link to the pic in the gallery...therefore fixing the gallery takes care of the problem...Keep it up, your build looks quite well done...
Online ljohnsaw
« Reply #14 on: May 20, 2016, 11:09:26 AM »
Well, yes and no.  IIRC, Jeff posted a thread about fixing pictures.  Yes, you fixed them in your gallery.  But go back up the thread and you will see a couple of pics that are stretched.  Jeff stated that  IF the "modify" is still available on those posts, you can click on that, delete the link to the picture and the re-insert the edited picture link.  Then all will be good.
John Sawicky
Offline larrydown60
« Reply #15 on: May 20, 2016, 05:07:00 PM »
John, I looked at my post and Pineywoods said I have no pics in my post I looked at the post and the pics are showing up when I look at the post. I hope they are showing up thanks for your help and sorry about the bad pics
Online ljohnsaw
« Reply #16 on: May 20, 2016, 06:12:35 PM »
NO, what Piney was saying is that your pictures are NOT IN your posts, there are LINKS to your gallery in your posts.  So, when you alter a picture in your gallery, it changes things in your posts where that picture is referenced (linked).  The thing that Jeff mentioned is when you rotate a picture, the original link had some information in it on how it should be displayed.  When you rotate a picture, the length and width are swapped.  But the original link in your post doesn't know that and it will be stretched or squashed one way or another.  This is why you need to delete the link and re-insert (re-link) your picture with the new information.  Hopefully that makes sense.
John Sawicky
Offline larrydown60
« Reply #17 on: May 20, 2016, 10:32:15 PM »
Thanks John i will try that thanks
Offline larrydown60
« Reply #18 on: May 20, 2016, 11:09:31 PM »
I got the log stops cut so they will go up and Down Still have to weld a bolt on the side of the log stops  Got the log locks built and one installed before the welder quit working This is all that I GOT DONE TODAY. I HOPE THESE PICS ARE DONE RIGHT  lol
Offline larrydown60
« Reply #19 on: May 21, 2016, 09:50:28 PM »
Thanks Pineywoods, Coming from you means a lot. I have been admiring your work for about a year now. If you see anything that I can do it improve anything I am all ears.I am just trying to get it to cut some wood. then I plan on adding hydraulics after words I would have had the saw head built but my cheap welder died, gotta wait till Monday to order the part for the welder. I am going to use wheel chair motors for the up/down and drive the saw head forward and reverse. Thanks again
Pics of my sawmill build & first cut
Started by GAmillworker on Sawmills and Milling
Last post November 03, 2011, 06:53:24 AM
by Piston
Nyle Kiln Build Pics
Started by Hale87 on Drying and Processing
Last post December 25, 2014, 01:48:15 PM
by GAB
introduction and pics of my slabber build
Started by DaveM on Sawmills and Milling
Last post April 26, 2017, 12:46:03 PM
by DaveM
My log arch build with pics and action shots :)
Started by Piston on Forestry and Logging
Last post January 03, 2018, 09:03:33 AM
by Gearbox
