Council Tool
Author Topic: More Pics of my sawmill build  (Read 35686 times)
Offline larrydown60
Re: More Pics of my sawmill build
« Reply #360 on: October 30, 2017, 09:17:15 AM »
If they are in NY today then I guess I'll be seeing them tomorrow in Pa.
I am only 40 min from Pa Border 30 mile north of Binghamton NY They probably took them 20 mins as the crow flies I kind wish the geese would stay and the *danged crows would leave, they come to the city in the winter and crap all over everything and tear the trash bags open all winter and there is no open season on them in the city. LOL
Offline larrydown60
« Reply #361 on: October 31, 2017, 11:06:28 PM »
Got another load of spruce today Got the last of the white pine loaded onto the mill and went to start the mill and all I got was sparks jumping out of the motor slide must be I have a bad ground.I will move the ground wire from the saw frame to the bolt on the motor mount.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #362 on: November 01, 2017, 10:25:06 AM »
I really like your mill!
1992 LT40HD
Offline larrydown60
« Reply #363 on: November 01, 2017, 10:47:28 AM »
Thanks Darrel
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #364 on: November 01, 2017, 11:06:57 AM »
Larry, do you find the need for 2 axles? Mine is going to have a 24' bed and I was only planning 1.
Offline Florida boy
  • Young sawyer with my first mill
« Reply #365 on: November 01, 2017, 08:07:52 PM »
From what I can tell with our syp  is that a slightly dull blade will leave wavy cuts, knots will definitely  wave even with a sharp blade of you don't go slow. I usually get more then 400 bf but am also usually cutting 2x material. I thinking I get between 700 and a thousand but if there is sand or dirt in the logs it drops significantly. Just my 2 cents
Offline larrydown60
« Reply #366 on: November 01, 2017, 11:52:10 PM »
not yet  but I am planning on a trip to florida with the mill it will help with speed and the distanceI will be driving. The mill weighs about 4000 lbs
Offline Jack S
« Reply #367 on: November 02, 2017, 11:16:32 AM »
When I built my mill trailer I put tandem axles also, mainly for stability and ride. A single axle tends to bound where as a tandem just seems to float going down the road. I feel it will make it a lot easier on the mill. When Larry goes down 81 and 95 he will appreciate what I mean especially when going over every bridge overpass. been running that route over 25 years and it never gets any better  Jack
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #368 on: November 02, 2017, 12:00:46 PM »
I have a torsion axle from a horse trailer. I dunno how bad it is going to bounce. we will see.
Offline Jack S
« Reply #369 on: November 02, 2017, 02:20:33 PM »
  Crusarius, I have a 12 foot enclosed trailer with the torsion suspension and it works great. 20 years so far but having owned tandem equipment trailers they just ride so much better, they just float over the bumps. My feeling is why not help keep our mills from getting kicked around. might keepem more accurate. by the way you and Larry both have been doing a super job on your mill builds
Offline larrydown60
« Reply #370 on: May 14, 2018, 11:57:46 AM »
 Hi everyone after a year of surgeries and healing from toe and knee surgeries I am back and started sawing again  I will be showing a few videos later of a few things I have done in the last couple of weeks.
Online bwstout
« Reply #371 on: May 14, 2018, 02:34:27 PM »
 I like your mill have one looks a lot like it I got plans from Texas Ben off ebay.
home built mill
Offline larrydown60
« Reply #372 on: May 14, 2018, 10:35:32 PM »
That is who I got my plans from but I made it wider 36" and I also made so it would lift 36" tall and a few other modifications.
Online bwstout
« Reply #373 on: May 15, 2018, 01:17:28 PM »
i whish I had done the same I stayed with the plans and now have a pecan log and sycamore that is the 36" range I will have to do a little chain sawing before I can cut them. My intentions  were to build a mill so to cut bowl blanks and not have to split the logs with a chain saw. But as it always happens it gets bigger and friends what something now I saw lumber and have plans to build a kiln before summer ends
home built mill
Offline larrydown60
« Reply #374 on: May 16, 2018, 10:02:29 PM »
bwstout, I also have plans on building 1-2. Just got a 1964 2010 John Deere Industrial tractor with a front loader to help lift the logs on to the mill and move the logs around
Offline larrydown60
« Reply #375 on: May 16, 2018, 11:21:38 PM »
Hi everyone, I have a few videos of a band saw blade sharpener I built while I was recovering from knee replacement and a heart attack. I have also been updating the saw mill I will posting more videos of the upgrades and some jigs I built for cutting beveled siding I have been busy the last couple of weeks.
 https://www.youtube.com/watch?v=FkPuorYKcf4
and  the second video is of it sharpening a blade with it.
Offline Darrel
« Reply #376 on: May 16, 2018, 11:46:54 PM »
I'm impressed Larry.
1992 LT40HD
Offline larrydown60
« Reply #377 on: May 17, 2018, 01:01:57 AM »
Thanks Darrel, Here is another video of siding jigs I built a couple of weeks ago they cut 8" siding 1/4 x 3/4 they are real simple to build they are complements of JosalJo Won on youtube he shows how to build them. I have cut over 200 pieces of siding with them so far with no problems. My neighbor liked the siding I cut so much he wants me to to cut 1000 sq ft of hemlock for a house he is restoring
Offline larrydown60
« Reply #378 on: May 17, 2018, 01:10:25 AM »
Sorry I thought I explained the jigs in the first video so here is a short video explaining them a little .
Offline Darrel
« Reply #379 on: May 17, 2018, 09:51:40 AM »
Very simple and very nice.
1992 LT40HD
Pics of my sawmill build & first cut
Started by GAmillworker on Sawmills and Milling
Last post November 03, 2011, 06:53:24 AM
by Piston
introduction and pics of my slabber build
Started by DaveM on Sawmills and Milling
Last post April 26, 2017, 12:46:03 PM
by DaveM
Nyle Kiln Build Pics
Started by Hale87 on Drying and Processing
Last post December 25, 2014, 01:48:15 PM
by GAB
My log arch build with pics and action shots :)
Started by Piston on Forestry and Logging
Last post January 03, 2018, 09:03:33 AM
by Gearbox
