Author Topic: Outdoor Cedar log peeling bench or vise of some sort any ideas?  (Read 849 times)
Offline Rusticcreations
So as some of you know I build log Furniture for a living, I was wondering if any of you have any ideas or know of any designs for a station to place logs in to hold them at a comfortable height to stand and strip the bark off with a drawknife.
Keeping in mind that most logs are not straight and I also need to be able to easily and quickly strap or tie down the logs to hold them tight.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Outdoor Cedar log peeling bench or vise of some sort any ideas?
« Reply #1 on: May 26, 2016, 07:56:33 PM »
A riving brake might work well for that.
« Reply #2 on: May 26, 2016, 10:11:31 PM »
So after sitting here searching for a log stripping vise design of some sort I said the heck with it and went out to the shop,
An hour and half later I have this and I'm very impressed with it, I built it from scratch outta my head and it works awesome.
Where the ratchet strap is located there is a slide that moves up n down and using the ratchet I can clamp the log in place.
On the back half are 2 45 degree 2x4s that have adjustment holes in them that can use to adjust for bigger or smaller logs to help hold them at a comfortable height.
Not bad for some redneck engineering huh
Offline just_sawing
  • Making Split Rails Shingles and Sawing
« Reply #3 on: May 29, 2016, 08:46:10 PM »
One of my customers makes cedar furniture and his competitors put the logs in a shallow pond. Then they take a pressure washer to them. They will spin and the water logged bark will fly off.
You can follow me at
www.http://haneyfamilysawmill.com
Bench vise
Started by Dan_Shade on General Woodworking
Last post March 26, 2019, 06:32:30 AM
by WV Sawmiller
Favorite Bench Vise?
Started by GaTrapper on General Board
Last post September 22, 2016, 08:32:12 AM
by Kbeitz
Woodworking bench front/face vise?
Started by Brad_bb on General Woodworking
Last post September 09, 2019, 07:10:57 AM
by 21incher
Just picked up a nice Wilton 161051 Pattern Makers Rotating Head Bench Vise
Started by Kbeitz on General Woodworking
Last post September 01, 2016, 12:59:57 AM
by Kbeitz
