Arborwear
Author Topic: John Deere 753J Feller Buncher  (Read 975 times)
Offline ValleyLogger
« on: May 31, 2016, 06:18:57 PM »
Anyone out there running a 753 j Feller Buncher that could tell me what the normal operating temperature of the hydraulic oil is on average
My oil is getting pretty hot and I'm trying to get to the bottom of it. Just curious if anyone else has seen this issue with this model and has any info
If so thanks
Offline 1270d
Re: John Deere 753J Feller Buncher
« Reply #1 on: May 31, 2016, 10:06:32 PM »
I can't comment on your particular machine, but anything over 160-170f would have me worried.
« Reply #2 on: May 31, 2016, 10:34:53 PM »
The oil gets up to anywhere from 160's to 200 degrees and that is without even running all day
Been trying to find the heat source but it is a challenge
Offline chevytaHOE5674
« Reply #3 on: May 31, 2016, 10:42:46 PM »
First thing in the morning when the machine is cold fire it up and then take your IR temperature gun and start checking the temps of valves/motors/pumps/etc and see if any of them are heating up faster than the others. On our processor I've had a bad O-ring in a valve stack cause the oil to get really hot before.
Offline Mountaynman
  • work from the southern adks to the catskills in NY
« Reply #4 on: June 03, 2016, 03:52:15 PM »
if any of your functions are slower than normal check there thinking u have oil bypassing in a cylinder somewhere that's where your heat is coming from
1999 546 Fabtek 2009 450J 1999 Prentice 210E Run Husky 372xps and 660 Stihls
Online wannaergo
  • Work while I'm young, sleep when I'm dead!
« Reply #5 on: June 03, 2016, 04:24:41 PM »
On our 501, we had the bypass valve for the oil cooler stick. No oil would go through the cooler and it would get really hot really fast.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
653E john Deere buncher
Started by cutter88 on Forestry and Logging
Last post January 11, 2016, 09:30:28 PM
by Firewood dealer
New to me Feller Buncher
Started by smwwoody on Forestry and Logging
Last post July 21, 2013, 08:57:52 PM
by semologger
Bell feller buncher
Started by TonyS319 on Wanted
Last post September 11, 2014, 07:00:04 PM
by Mooseherder
running a feller buncher?
Started by treefarmer87 on Forestry and Logging
Last post November 03, 2010, 12:48:25 AM
by treefarmer87
