Baltic Abrasives Technologies
Author Topic: Hydraulic fluid In Clark 664c  (Read 449 times)
Offline lshobie
« on: June 02, 2016, 05:55:59 PM »
Hi fellas from what I can see in the manual it calls for 10w non detergant oil, I can't get a pail of that and wonder what an equivalent might be or what you all run.
ThankLouis
Clark 664C, Woodmizer LT40, Alaskan Mill, Huskys, Stihls, and echos.
Offline ohiowoodchuck
Re: Hydraulic fluid In Clark 664c
« Reply #1 on: June 02, 2016, 06:18:56 PM »
Lube king makes 10w non detergent oil. I'm not sure what others run in there's though.
Education is the best defense against the media.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #2 on: June 02, 2016, 08:18:54 PM »
 AW-32 hydraulic oil is equivalent to 10W.
Offline oldseabee
« Reply #3 on: June 03, 2016, 10:40:17 AM »
Hydraulic oil above 0 deg F 10W engine oil API class SD or SE MIL-L-2104B or 2104C spec
below 0 Deg F Dexron (not Dexron II)
Clark 664c dumping hydraulic fluid
Started by lshobie on Forestry and Logging
Last post August 06, 2017, 02:12:59 PM
by mike_belben
Will a 664c Clark Tranny fit a 664b clark ranger skidder?
Started by delimberboy on Forestry and Logging
Last post December 22, 2015, 01:23:05 PM
by oldseabee
Clark 664C
Started by Chrbat33 on Forestry and Logging
Last post March 30, 2017, 09:58:10 AM
by ClarkF66
question
clark 664c
Started by borecutter on Forestry and Logging
Last post February 27, 2014, 03:36:58 PM
by oldseabee
