Author Topic: Rotobec Grapple  (Read 1276 times)
Offline LaegersATC500R
Rotobec Grapple
« on: June 03, 2016, 06:25:56 PM »
The bottom of the rotator housing is leaking oil. I need to remove the grapple to replace the seals. I looked at the parts break down and have an idea how to do it. I never did this before so I need a little help.  The rotator model number is 3252 mounted on a F90. Any pointers on how best to remove? BTW this is an older unit built around 1995
Morton Downey Jr. was a good man.
Offline Autocar
Re: Rotobec Grapple
« Reply #1 on: June 03, 2016, 08:23:27 PM »
When I bought my F-90 the motor was missing and the hanger bracket for the grapple was home made. The grapple it self had a flat plate and you could see holes where the motor was bolted on. I ended up making a new hanger bracket and put a Char-Lynn motor on mine to rotate left and right. If I remember rightly on my 110 Prentice you unbolted  [four 3/8 inch bolts ] and the motor would drop down and I believe it had a spline shaft [ Male ] that went into a female splin and thats how it would spin. Then I pulled all the bolts off the top of the motor and when you pulled the top off  then you can replace the splin shaft seal and you might as well replace the two plastic padles that makes it rotate. Not sure but about bet the F-90 is about the same as the 110.
Bill
Offline kiko
Re: Rotobec Grapple
« Reply #2 on: June 03, 2016, 09:26:16 PM »
Does the rotator look like this one?
Offline AlexHart
Re: Rotobec Grapple
« Reply #3 on: June 03, 2016, 10:32:30 PM »
When I took mine apart the Prentice guy at the Oliver Store (I guess that's all gone now and they are owned by Cat now) warned me it would be hard to get it apart and it didn't disappoint.    I guess they are pressed in there or something.   I made up a puller out of some threaded rod and a pretty nasty steel plate and we just kept hammering on it with the big air wrench and it finally pulled out (thank goodness).
Once it came out replacing the parts wasn't that hard and surprisingly affordable.   Honestly its been awhile and I can't even remember what the heck I did but it wasn't too bad.
And that's why I took mine apart was that exact problem.    Oil coming out the bottom from bad seals.
Re: Rotobec Grapple
« Reply #4 on: June 05, 2016, 08:55:29 PM »
This is what it looks like
--Photos MUST be in the Forestry Forum gallery!!!!!--.com/user/Chainsaw3406/media/0604161640_zpstvsjpkfg.jpg.html][img width=650 --Photos MUST be in the Forestry Forum gallery!!!!!--.com/albums/qq150/Chainsaw3406/0604161640_zpstvsjpkfg.jpg[/img][/URL]
Offline kiko
Re: Rotobec Grapple
« Reply #5 on: June 06, 2016, 09:05:58 PM »
The pictures are not in your gallery.
Re: Rotobec Grapple
« Reply #6 on: June 10, 2016, 06:30:17 AM »
It shows 2 pics in  my gallery
Offline kiko
Re: Rotobec Grapple
« Reply #7 on: June 10, 2016, 10:59:42 PM »
I can't open them for some reason or another.
Re: Rotobec Grapple
« Reply #8 on: June 11, 2016, 06:26:25 AM »
Rotobec forwarder
Started by Frickman on Forestry and Logging
Last post August 25, 2007, 03:01:36 PM
by Frickman
rotobec on john deere 110
Started by Emajsh on Forestry and Logging
Last post August 09, 2010, 04:50:58 PM
by treefarmer87
Anyone use the rotobec elite loader?
Started by Woodhauler on Forestry and Logging
Last post October 27, 2010, 06:22:05 PM
by Woodhauler
walvoil hydralics in a rotobec elite.
Last post September 30, 2014, 05:51:14 AM
by snowstorm
