Author Topic: Walnut boards thickness  (Read 1767 times)
Offline WOOD100
« on: June 09, 2016, 12:47:57 PM »
I have a walnut log. What is the optimum walnut boards thickness? I was thinking about 1 inch. What do you think?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Walnut boards thickness
« Reply #1 on: June 09, 2016, 01:23:49 PM »
Depends upon what the lumber will be used for.  Is it for your personal use or are you planning to dry/sell it?
Offline Kcwoodbutcher
  • Startin' to get the hang of it
« Reply #2 on: June 09, 2016, 01:35:05 PM »
If I'm planning on selling it I go 1 1/8". At 1" I may lose a board or two because of drying defects. That extra 1/8" makes a difference.
My job is to do everything nobody else felt like doing today
Offline bags
  • Location: Up high in the Colorado Rockies, Westcliffe ,CO.
« Reply #3 on: June 09, 2016, 09:08:17 PM »
I cut 5/4 for the furniture/ cabinet makers around here. Depending on how the board dries--- Theres more than enough material to plane out any cupping, and keep your clients "happy".
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #4 on: June 09, 2016, 10:12:42 PM »
I would saw it 1 1/8" thick for 4/4, 1 5/8" thick for 6/4, and 2 1/8" thick for 8/4.  If you saw at 1 1/8", then after drying and planing, 90% of it will clean up to 15/16" thick.  That is what most woodworkers want.
Offline cwimer973
  • I'm new! Wood-Mizer LT10 - Please Help Me Learn
    • Wimer Hardwoods
« Reply #5 on: June 10, 2016, 08:41:34 AM »
If you get a nice couple slabs to bookmatch into a table you may get a buyer to pay much more. Depends on your market but slabs on either side of the pith and some 8/4 for legs and rails when you cut on the sides of the pith work great for a table project.
I usually only flat saw here for making furniture and hope to one day learn the techniques to maximize quality wood without introducing to much waste.
Your Fellow Woodworker,
- Chris
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: June 10, 2016, 08:50:15 AM »
Personally I always preferred to glue up 1" boards matching opposing grain patterns for legs etc.  My theory was/is that they would be much more stable.  Anyway, I never had any problems with the glued up legs.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #7 on: June 10, 2016, 10:45:27 PM »
1 1/8" is what I saw to.
HobbyHardwoodAlabama.com
Offline WIwoodworker
    • Milwaukee Woodworks
« Reply #8 on: June 11, 2016, 12:18:21 AM »
The easiest to sell is 4/4 which I also cut at 1 1/8". That assumes a nice relatively straight log. Good luck with your log!
Peterson 9" WPF
Offline Carson-saws
« Reply #9 on: June 11, 2016, 11:43:02 AM »
I feel it depends on the grade of the log, both before you open it  and after the face cut.
Let the Forest be salvation long before it needs to be
Offline carykong
  • Installing my roof ridge metal
    • Have Mill Will Travel
« Reply #10 on: June 11, 2016, 12:40:08 PM »
Walnut logs have a long self life. I support the previous posts that the actual user will determine how you actually mill the log.
boards increasing in thickness
Started by JB Griffin on Sawmills and Milling
Last post April 06, 2014, 11:18:43 PM
by jpecor
How to use the thickness guage on the mill to get boards????
Started by francismilker on Sawmills and Milling
Last post January 22, 2013, 08:14:32 PM
by Cutting Edge
2" walnut boards
Started by KitchenTable on Wanted
Last post July 18, 2018, 10:35:27 PM
by Busysawyer
Which Thickness?
Started by Horselog on Sawmills and Milling
Last post April 01, 2016, 10:01:24 PM
by 280 rem
