Author Topic: Wooden planter  (Read 1306 times)
Offline Czech_Made
Wooden planter
« on: June 14, 2016, 08:47:13 PM »
Just making the wife happy but, of course, she asked for more.  Nothing special about this, no joinery to speak of except some rabbets using the almost-new-to-me 8"x66" jointer.
Oh, and I milled that oak myself  ;D
Offline samandothers
Re: Wooden planter
« Reply #1 on: June 14, 2016, 09:12:49 PM »
Well done!  What brand jointer?
Offline Czech_Made
Re: Wooden planter
« Reply #2 on: June 15, 2016, 06:56:12 AM »
Bridgewood.  I had to make adjusting wheels, the previous owner used vicegrips  >:( but it cuts nice and straight.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Wooden planter
« Reply #3 on: June 15, 2016, 07:21:31 PM »
That is really nice.  :)
Offline Czech_Made
Re: Wooden planter
« Reply #4 on: June 16, 2016, 08:50:12 AM »
Thank you.
Offline tule peak timber
  • roborob
    • tule peak timber
Re: Wooden planter
« Reply #5 on: June 16, 2016, 10:13:05 AM »
Nice ! :)
Offline Jemclimber
Re: Wooden planter
« Reply #6 on: June 22, 2016, 08:23:20 AM »
Very nice planter!!!  smiley_thumbsup Will you line it, use and insert, or just fill it up?
lt15
Offline Czech_Made
Re: Wooden planter
« Reply #7 on: June 22, 2016, 08:39:28 AM »
I used Thompson water seal, two coats and since it is white oak, I hope it will hold few years.
I also set boards rabbets to drain out.
Offline LittleJohn
  • I am not a professional, I just pretend I am...
Re: Wooden planter
« Reply #8 on: June 22, 2016, 09:02:23 AM »
I found some good stuff the other day, CopperCoat, it is basically a painted on green treat.  I was using some because I was putting in some post around my wifes Hobby garden to keep bunnies out, apparently you can put this stuff on untreated wood and it is good for ground contact.
Offline Czech_Made
Re: Wooden planter
« Reply #9 on: June 22, 2016, 09:59:52 AM »
This?
Never heard of it, will check it out, thank you.
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: Wooden planter
« Reply #10 on: June 22, 2016, 03:02:34 PM »
The active ingredient is copper napthenate. The solvent based formulations work better but stink for quite a while. The stuff works. I think the original one was called cuprinol. Old timers like me know it by that name.
  • roborob
    • tule peak timber
Re: Wooden planter
« Reply #11 on: June 22, 2016, 05:32:14 PM »
Very familiar with Cuprinol from years ago as well as Pentachloraphenol . Both worked well and are a thing of the distant past here in California. Rob
Offline caveman
  • In the land of the blind the one eyed man is king
Re: Wooden planter
« Reply #12 on: June 22, 2016, 09:36:16 PM »
This is a can I had left over after building a cypress deck on the back of our house in 1994 when we built it.  The deck boards lasted about five years.  The original "old style" pressure treated joists are still there.  I do not think the Cuperinol would be a long term solution for surface treating wood that is intended to go into the ground around here.
The planters look really good.  Some of my students made some that were similar for a couple of our teachers last year. The one in the background near the lathe is complete.
Caveman
Offline opticsguy
Re: Wooden planter
« Reply #13 on: June 22, 2016, 11:57:28 PM »
My understanding is;  Thompsons water seal is basically paraffin dissolved in Thinner.  After application, the thinner evaporates leaving a coating of paraffin.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline Czech_Made
Re: Wooden planter
« Reply #14 on: June 23, 2016, 08:40:50 AM »
A side note, in my old country people would dip fence posts in used car oil, it worked reasonably well.
Try that in CA  ;D ;D ;D
  • roborob
    • tule peak timber
Re: Wooden planter
« Reply #15 on: June 23, 2016, 09:16:24 AM »
 :D :D :D :D :D :D :D :D :D
Offline LittleJohn
Re: Wooden planter
« Reply #16 on: June 23, 2016, 09:24:33 AM »
This?
Yes, I had never heard of it either, til I had to do some internet scouting cause I could not get ground rated Pressure treated.  SO i got regular GT, and will be hoping for the best.  By the way I am planting these posts in SOLID CLAY, so I put an a few (ok, maybe 4) coat of the stuff, and extra on all end grains
Offline Czech_Made
Re: Wooden planter
« Reply #17 on: June 23, 2016, 09:35:09 AM »
Maybe shovel of gravel for the hole bottom?
Offline LittleJohn
Re: Wooden planter
« Reply #18 on: June 23, 2016, 01:43:20 PM »
when they dug out the full basement it was clay the bottom, 9'+, I can only imagine how fun that was to the shovel operator
Wooden piston with wooden connecting rod
Started by hackberry jake on General Woodworking
Last post April 12, 2012, 01:23:38 AM
by Don_Papenburg
log planter
Started by Dave H. on General Woodworking
Last post June 25, 2016, 07:54:08 AM
by lowpolyjoe
planter pic added
Started by trapper on Sawmills and Milling
Last post May 07, 2014, 07:05:49 AM
by Sixacresand
Planter Plates
Started by farmerdoug on For Sale
Last post January 30, 2010, 09:22:28 AM
by farmerdoug
