Author Topic: New to me sawmill...... I think...  (Read 2823 times)
Offline jim_wrench
Re: New to me sawmill...... I think...
« Reply #20 on: June 15, 2016, 07:25:36 PM »
Some one just posted in this forum they bought a LumberJack sawmill head rig only .
Is this from the same company maybe ?
I suppose it's possible. If so I must have a very early version with wooden wheels and alot of pop rivets. I'll post upore pictures soon.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #21 on: June 15, 2016, 07:42:32 PM »
What you need is a bolt on flywheel pto stub shaft for the other side of the engine.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Joe Hillmann
« Reply #22 on: June 15, 2016, 10:27:37 PM »
I do it quite often but have never done it on anything over 5 hp.  The first few minutes a lot of stuff goes flying as the outer fabric casing gets rubbed off after that it wears pretty well.
If you want to change the direction  of the blade put a half twist in the belt and flip the saw blades inside out.  If you do that you would want to put a small piece of metal between the two halves of the belt where it will want to rub against its self.
Very much interested in seeing a belt like this in action and how is the life span of the belt in this? Yes I believe the drive set up is backwards for sure. This thing looks like a home made affair for sure. Just not by me. But I will give the builder some credit he did build it with guards. Something o might have overlooked till later on in the build.
Offline jim_wrench
« Reply #23 on: June 16, 2016, 01:26:12 AM »
I'm thinking about flipping the motor and running a Jack shaft with pillow blocks. To rotate the mill in the proper direction.. I'm really not looking to reinvent the wheel here but sometimes it just has to be done. :-\
Offline fishfighter
« Reply #24 on: June 16, 2016, 07:47:29 AM »
Well, a man has to do what a man has to do! ;D
Offline jim_wrench
« Reply #25 on: June 21, 2016, 03:25:24 PM »
Making slow progress. But progress none the less.
Before.
After.
At least this should correct being able to use common off the shelf blades of 12' long give or take.
Portable Sawmill Special Deal - SAVE 10% on your Sawmill!
Started by HSV on Peterson Portable Sawmills
Last post March 10, 2015, 10:34:01 PM
by jamieotter
sawmill advice what is the best sawmill
Started by KY colonel on Sawmills and Milling
Last post February 24, 2017, 01:09:51 PM
by KY colonel
My Sawmill Kit
Started by Mark M on Sawmills and Milling
Last post May 13, 2003, 12:46:45 AM
by Mark M
My Sawmill
Started by Kurban on Sawmills and Milling
Last post November 22, 2015, 06:31:37 PM
by Don_Papenburg
