Baltic Abrasives Technologies
Author Topic: Anyone running a mill with 2" bands  (Read 1829 times)
Offline ozarkgem
  • age 65 yrs old
« on: June 18, 2016, 07:02:42 AM »
I haven't seen any post or pics of members with a mill using a 2" band. Just curious as to why or why not.
Offline bkaimwood
  • Life's too short to sweat the small stuff
Re: Anyone running a mill with 2" bands
« Reply #1 on: June 18, 2016, 08:53:54 PM »
Considered it for the home made mill...only reason was for straight cuts in wider cuts, 36" and beyond....never got that far, but should take 50+ hp to turn that band effectively.... curious why you ask?...
bk
Offline ozarkgem
  • age 65 yrs old
« Reply #2 on: June 18, 2016, 08:59:49 PM »
just going over my mill build in my head. I have a 60 HP diesel engine I plan on using and want to get max production out of it. I have found a vertical band saw that uses 2" bands and he wants to sell it. Thinking of the using the wheels. I want all the production I can wring out of the engine.
Offline sandsawmill14
  • love my job (most days)
« Reply #3 on: June 19, 2016, 09:44:18 AM »
We have a brewco  re saw that runs 2" bands with a 50 hp electric motor its fast it will cut 10 mbdft  a day real easy
Offline Ludo
« Reply #4 on: June 19, 2016, 07:05:15 PM »
I run a 2" x 24' blade on 30" wheels I think they are 30"...  I have a 36hp Briggs gas engine and have cut up to 60" wide with no problem.  If the bade is sharp it will cut flat as a pancake!
Last week's 52" x 12' walnut
Offline ozarkgem
  • age 65 yrs old
« Reply #5 on: June 19, 2016, 07:42:11 PM »
If you are using 50 HP electric I wonder if 60 hp diesel would be enough?  10mbdft a day now that is what I am talking about. Course I wouldn't get that sawing logs by myself.
Offline ozarkgem
  • age 65 yrs old
« Reply #6 on: June 19, 2016, 07:44:56 PM »
How much does a blade cost for your mill? I like the 60" wide cut. I doubt that I would go that wide but maybe 48 . We don't see many walnut that big.
Offline Ludo
« Reply #7 on: June 19, 2016, 08:36:46 PM »
$42 shipped for a Woodmizer Silver tip.
Offline ozarkgem
  • age 65 yrs old
« Reply #8 on: June 20, 2016, 05:25:36 AM »
Is your mill homemade? any pics of it?
Offline JB Griffin
« Reply #9 on: June 20, 2016, 09:06:04 PM »
At work we have a 2016 Baker Dominator 3650e, 50hp 3ph, running 1 1/2" x 20ft .055 turbo 7s. We routinely cut 7mbf in oak cutting ties and grade and 10mbf in pine sawing bridge timbers out of pine. That's runnin a 3 man crew.
With some fine tuning and pushing a little harder I think we could routinely hit 9mbf in oak, but everything would have to go SMOOTH.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
« Reply #10 on: June 20, 2016, 10:58:56 PM »
It would be a little slower but would pull it fine just  little slower feed rate
Offline Horselog
    • Sinking Creek Horse Logging
« Reply #11 on: June 21, 2016, 07:36:58 PM »
I am very interested in your experience with that setup. How long do your blades last on average?  How many sharpenings are you getting per blade?
What diameter oak logs are you sawing that give you 7mbf/day?
So you're running Wood Mizer blades?
I'm considering this particular mill, and looking for real world experience with it.
Benjamin Harris
Sinking Creek Horse Logging and Wood Products
Appalachian Mountains of Virginia
horse_logger@me.com
www.sinkingcreekhorselogging.com
2" Bands for a Timber Harvester Mill
Started by warren46 on Sawmills and Milling
Last post August 28, 2017, 09:59:14 PM
by JB Griffin
Anyone running the new Wood-Mizer 7 degree bands?
Started by Dave Shepard on Sawmills and Milling
Last post December 29, 2009, 11:13:01 AM
by jpgreen
2" bands
Started by bandmiller2 on Sawmills and Milling
Last post October 06, 2008, 02:51:41 AM
by backwoods sawyer
question
1-1/2" bands
Started by Larry on Sawmills and Milling
Last post April 27, 2013, 07:17:46 AM
by FeltzE
