KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: 1st test-blade tracking problem  (Read 3689 times)
Offline Den-Den
    • Dennis Wood Art
Re: 1st test-blade tracking problem
« Reply #20 on: June 20, 2016, 05:08:27 PM »
They are plain car tires with little to no crown. Should I be in the market for donut tires with a crown? Is that a necessity?
[/quote]
A little crown is all that is needed, no crown is a problem.
Offline bkaimwood
  • Life's too short to sweat the small stuff
« Reply #21 on: June 20, 2016, 06:49:43 PM »
Camber and toe problems are amplified with blade tension...the blade may track ok undertensioned, but if the adjustments are a hair off, the increase in tension will quickly reveal this. Tire problems in general will do the same...
bk
Offline 5quarter
« Reply #22 on: June 21, 2016, 12:14:42 AM »
Hi Ray...I mean that the tire needs to be perfectly round in relation to the axle/shaft. New tires are close to round but used tires will always have some uneven wear that will completely screw up your tracking. some of the guys here get around that by using the drive axle like a lathe and turn the tire perfectly round. I've never used tires as band wheels myself, so all I really know about them is what I've read regarding others who have built mills similar to yours. Keep up the great work!  :)
Offline ljohnsaw
« Reply #23 on: June 21, 2016, 03:16:38 AM »
I don't know how to build a mill, but, all the ones I looked at the blade is deflected down or straight across. Your's are up.
the blade is not on the tires in the video. I shot the footage right after it popped off again.
I noticed that as well.  I went back and looked, there sure seems to be a blade on the mill...
The first thing I noticed was how flat across the tires look - no noticeable crown to them.  I use doughnut tires that have a pretty pronounced crown.  They work great for me.  I do not have top to bottom adjustments, just toe in/out and tension.  My tires are at the rated 60 psi which makes them very hard.  The teeth of my blade are not touching the tire so should not take the set out of one side.  I have yet to set up a caliper to measure the exact tension.  I just tighten to the point that flutter of the blade is reduced and I get great cutting.
As far as tire speed, I have not recalculated with my gas engine.  With my electric motor, I figured that they were traveling at 60 to 65 mph.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline ray299
« Reply #24 on: June 21, 2016, 09:04:53 AM »
SO what does everyone think about the tire types? DO I need donut tires that crown? I have regular car tires and they don't look like they have a crown even after being inflated to max... I mean they could have a crown but its so small its not noticeable. DO I need a greater more obvious crown?
Thanks!
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #25 on: June 21, 2016, 10:19:42 AM »
Yes.  A crowned wheel/tire will definitely help your blade stay on.  Hopefully you'll be able to find some donuts from the vehicle whose rims/tires you're using now and the backspacing will not be so different that you have to change everything around concerning your guides and such.  Just remember - you'll never get the huge tension with tires that you will with steel or pulley/belt bandwheels.  Tension until flutter goes away and leave it there.  It will take a bunch of fussing to get the right combination of tire pressure, alignment, etc. but once you're there you'll be golden.  Taking notes sometimes helps.
Offline gww
« Reply #26 on: June 21, 2016, 10:35:28 AM »
Ray
Your issue sounds like some that I had and that member Georgia88 also had.  My tires are pretty flat and I took an angle grinder and took a tiny bit of rubber off of it right where the teeth would ride in use.  I didn't work on it too hard though cause I believed with mine it was flex of the mill under tension.  If your blade cut good and then starts diving pretty quick, I would say the tire is taking out the set, if not diving after good cutting, I would say it is a flex issue.
Look here at replie #75 too see what georgia88 did to stop flex.
http://www.forestryforum.com/board/index.php/topic,88250.60.html
replie #468 shows a bad picture of how I added a brace to help with my mill flex.
http://www.forestryforum.com/board/index.php/topic,82695.460.html
I think georgia88 fix is much stronger then mine.
My wheels are out of ballance and bounce a bit but if my bearings on my blade guides are good and my blade is sharp it will cut perfect lumber.  I do find log stress gives me problims at times.  Hickory or maple and sometime sickomore.  I know it will cut good oak so know I can blame the loggs some of the time.
Hope this helps.
gww
Ps
Hi ox, ray, I would personally work on the stress before worrying about a tire switch.  You can figure out pretty easy if the tire is taking the set out of the blade after you get everything tracking and it may be as simple as an angle grinder if it is needed at all.  JMHO
Offline gww
« Reply #27 on: June 21, 2016, 11:04:25 AM »
Ray
Even beefed up a bit I can not really scrunch my tires with the blade.  I also still have enough flex that I have to do the tracking of the blade with almost the tension I need to cut with and it will not run the same with the tension off.  You can get it where it will cut good and be repeatable between blade changes.  You do need to pay attention to the plane of the blade while getting it right.  The blade under tension needs to run paralel with your log bunks.
Beefing it up while under tension will be the first start and with mine I could only go so far but it was far enough to cut really good and very consistant boards.
good luck
gww
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #28 on: June 21, 2016, 12:36:01 PM »
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline gww
« Reply #29 on: June 21, 2016, 01:08:10 PM »
If the tires have tread, the angle grinder will give you what you need cause a little grinding goes a long way and I think a small amount of crown goes a long way.  Still, You know you have flex cause you got it tracking untill you put it under tension.
gww
Ps I did cut good boards with mine before beefing it up a bit.  It was a double edge sword cause now my blade is a little harder to change.  The beefing over all did improve the cutting well enough to be worth it though and I gained a small amount of cutting speed.  Every little thing that helps even a small amount add up to quite a bit when put with everything else that helps.
Offline ray299
« Reply #30 on: June 21, 2016, 06:47:15 PM »
Learn why you need a crown.
https://woodgears.ca/bandsaw/crowned_pulleys.html
Thanks, but is it me or did he not explain the principle behind why it stays on the hump? I'll have to watch it a few more times... Something about stretching but I didn't really understand...
Offline ray299
« Reply #31 on: June 21, 2016, 07:07:12 PM »
gww
I guess I'm just not getting the concept of "flex"... I'm going to have to do some more reading...
Offline ljohnsaw
« Reply #32 on: June 21, 2016, 07:34:43 PM »
The side on the slightly large diameter of the wheel is pulled with greater tension.  It is easy to see on the rubberband, not so on your blade.  That stretching causes the band to arch in such a way that it will steer itself farther up the crown (as the wheel rotates) until the band is centered on the crown because the forces are equal on both sides.  If he took a shot down the length of the band, you would see it.  Suffice to say, crowned wheels have been used for a long time - they just work and you should follow that example.  Otherwise, you have to build in all sorts of backstops bearings to hold things in place.
gww
A tire, under load, will "flex".  That is, it will bend.  Look at your car.  The top of the wheel is round, where it hits the ground, it has a flat spot, right?  If you tighten your band too tight (for rubber tires), they will have to give, or bend, or "flex" because they can't push as hard as the band is pulling.  IF your band is making your tires look like a fat guy wearing a pair of too tight of a belt, you have too much tension (for the tires).  Either you need more air pressure or a more rigid wheel (not a car tire) to maintain that tension.  Or, just use less tension - you should get good cut results if everything else is set up correctly (including crown on your wheels).
John Sawicky
Offline gww
« Reply #33 on: June 21, 2016, 07:43:21 PM »
ray
Your words.  You said you had the blade staying on the wheels untill you put tension on the blade.  When You put tension on the blade the blade ran off the back of the wheel.  That means when you put it under pressure something changed.  That something is bending or flex of your mill.  If it was not flexing then nothing should change when you put it under tension.  Maby I am misunderstanding what is going on?
Good luck
gww
Ps
What ljohn said is not exactly what I mean.  You could crunch the tire and it would just mess your blade or tire up.  However if the head that holds the tire is flexing than the plane of the tire and wheel is changing and so the blade that did stay on won't cause the tire is not in the same plane it was in before you put tension on it.
Offline gww
« Reply #34 on: June 21, 2016, 07:46:04 PM »
Ray
 I am saying that I believe your frame is not strong enough for the pressure you put on it when you spread your wheels out to tighten the blade.
gww
Offline gww
« Reply #35 on: June 21, 2016, 08:03:56 PM »
Ray
look at the picture in reply #3 here
http://www.forestryforum.com/board/index.php/topic,64720.0.html
and at the front of the mills here
http://kruppt.tripod.com//reworked/index.html
Hope this helps
gww
Offline Kbeitz
    • My Hobbies
« Reply #36 on: June 21, 2016, 08:26:16 PM »
My dad allways told me that a blade or belt will allways hunt for high ground.
Or on your wheels high crown.
Offline ray299
« Reply #37 on: June 21, 2016, 10:15:41 PM »
I think I'm getting crown now... based off all your comments, I thank you! That also means I was tracking it wrong to begin with which is why it kept popping off faster every time I tried to adjust it. I figured tilting the wheel in would make it track towards the front... but that actually puts more tension to the rear of the wheel (said from standing behind the saw head- rear and front being in front of the saw head) I've got a few things to try now.... I did have the blade spinning without tension... fingers crossed
Tracking problem
Started by Maverick127 on Forestry and Logging
Last post February 25, 2016, 12:01:33 AM
by Maverick127
band tracking problem
Started by kelLOGg on Sawmills and Milling
Last post October 21, 2010, 06:31:37 AM
by ladylake
Woodland Mills HM126 tracking problem
Started by clintnelms on Sawmills and Milling
Last post April 07, 2017, 09:53:26 PM
by mattyo5
blade tracking on lt 40
Started by kev on Sawmills and Milling
Last post July 19, 2009, 05:47:29 PM
by kev
