Baltic Abrasives Technologies
Author Topic: I need a better mousetrap!  (Read 1337 times)
Offline SkyDoc
  • She says its can't be done....but I didnt ask her.
« on: June 26, 2016, 07:43:22 AM »
I am looking to improve my log clamping system. The log dogs that were provided with my track system do "OK" but I feel that I could fabricate something better. I am looking for ideas from others mills that I could copy. I have looked at the useful mod's thread and didnt find anything that suited my fancy.
After visiting with fishfighter and seeing the adjustable stops he has on his woodland mills, I think I am going to copy that for the log stop. What I am looking for is a travelling clamp that I can fabricate to use in conjunction with that type of stop.
Can you guys provide me with some pictures of what you are using on your mills?
Doc
Dad always said "its easier to learn from someone else's  mistake than to make it yourself". Thats why I am here....
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: I need a better mousetrap!
« Reply #1 on: June 26, 2016, 09:38:09 AM »
I'll be watchen this...
I also want a better mouse trap...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline kelLOGg
« Reply #2 on: June 26, 2016, 03:00:31 PM »
I got my idea from robnrob2 who hasn't been online in a long time. They are cam clamps which, IMO work better than the screw clamps they replaced.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Online ljohnsaw
« Reply #3 on: June 26, 2016, 05:43:11 PM »
I will be watching this as well.  I don't have a good picture to show of mine but they need fixing.  Mine have a cam action that runs front to back when tightening.  That sometimes moves the cant or boards I'm trying to edge.  I like the way the one above is set up but I would make one major change.  I would want the cam to be engaged when the lever is down.  If I'm cutting large logs, that arm sticking out will interfere with my saw head.
John Sawicky
Offline kelLOGg
« Reply #4 on: June 26, 2016, 09:30:46 PM »
ljohn,
If you want the lever down, slide the clamping assembly away from the log just a tad and press it all the way down. I have to do that for just the reason you give - so the saw head will pass by unencumbered when sawing a full size log. The cant shown is rather small so there was no need for the extra room.
Bob
Online ljohnsaw
« Reply #5 on: June 27, 2016, 12:22:30 AM »
That's what I get for Assuming...  It looked like you would lift to make the cam engage.
John Sawicky
Offline Czech_Made
« Reply #6 on: June 27, 2016, 09:48:44 AM »
My log dogs look like this, they work well.  maybe not the fastest to be set.
Offline SkyDoc
« Reply #7 on: June 27, 2016, 10:02:33 AM »
WOW! That's really unique. I love the travelling log bunk. Do you get much movement with them being so low on the log?
Offline Czech_Made
« Reply #8 on: June 27, 2016, 10:49:30 AM »
Properly tightened the log is stable enough.
What I have to make is a right angle bracket for cutting beams or cants.
