Baltic Abrasives Technologies
Author Topic: circle saw question  (Read 428 times)
Offline SCSawyer
  • If Your Not Sawing Your Wasting Time.
circle saw question
« on: June 26, 2016, 11:07:25 PM »
Got a question for the circle saw guys, while I'm in cut the saw is spraying dust to the sawyers box ? Are the gullets not emptying before coming back around ? Or is it picking it up from the rear of the saw as the log passes ? I remember having this trouble on another mill but I think I corrected it by resetting the lead, I really don't want to change the lead, the mill saws great where it is , the dust spray is just driving me nuts until I can get the shed over it and get a screen up, any ideas ? " 95-100 deg heat in the hot sun + getting snowed on every time the log passes = 1 cranky sawyer !
Silas S. Roberts , Bluff Mtn. Timber
Offline Ron Wenrich
Re: circle saw question
« Reply #1 on: June 27, 2016, 05:25:59 AM »
Without a shed, and direct sunlight on the saw, your saw is too hot to saw without the shower.  Sun will make the saw hot and do weird things.  You need to get it off the saw, if you want to saw during the day.  When I first started, I simply built a frame over the saw and put slabs on top to make a roof.  It worked until we got a shed over top.  Saw on a cloudy day and see if there isn't a difference.
The other factor is you probably need to adjust your saw guides.  Your board side guide is probably off a bit, since the sun has dished the saw.  You need to keep your saw guides well adjusted, especially in hot weather.
Circle saw bit question
Started by Sawyerfortyish on Sawmills and Milling
Last post October 16, 2005, 02:54:09 PM
by Frickman
Circle saw guides question
Started by Sprucegum on Sawmills and Milling
Last post June 20, 2007, 08:49:15 AM
by Ron Wenrich
circle saw blade question
Started by Paul_H on Sawmills and Milling
Last post June 19, 2006, 06:32:11 PM
by sawmill_john
Question for circle saw owners
Started by backwoodsdave on Sawmills and Milling
Last post September 22, 2018, 06:51:27 PM
by jemmy
