Author Topic: Fuel shutoff solenoid not working  (Read 735 times)
Offline Beavertooth
« on: June 27, 2016, 09:04:25 AM »
My LT70 62cat engine shut off on me the other day. Had made one cut and it kinda cut out and started back then in second cut engine completely shut down. The day before while sawing a couple of logs it kept cutting out and then right back on a few times. Called Wood-Mizer and talked to Doug Hicks and he told me to check the fuel shutoff solenoid.Took it out of the engine and it fired right up. So I kinda screwed a piece of old sock in the hole it came out of and finished sawing up the log. Hooked the solenoid straight up to a battery and it would work fine. So knew it was ok. I checked voltage coming to it and it was only getting 10.6 volts. I traced the problem down to   a loose nut that holds several ground wires down on a bolt inside black box on side of engine. Just thought I would share in case anyone else runs into same problem.
2007 LT70 Remote Station 62hp cat.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Fuel shutoff solenoid not working
« Reply #1 on: June 27, 2016, 09:26:20 AM »
Since there were "several" ground wires it sounds like you corrected a potential for more problems.  We sometimes overlook grounds but they are the other side of every circuit.  Thanks for sharing.
Offline Percy
  • Resident trouble maker
« Reply #2 on: June 27, 2016, 09:44:28 AM »
Ill second the ground thing. A while back, I was sure my accuset 2 had swallowed the big onion. By chance, I found a loose dirty bolt holding a bunch of ground wires. After cleaning and tightening, the old punkooter is still working great. ;D
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
« Reply #3 on: June 27, 2016, 04:45:22 PM »
If you jump across the two wires, that feed the solenoid with a volt meter, do you read 12 volts?
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Offline Beavertooth
« Reply #4 on: June 27, 2016, 06:54:56 PM »
Sparks,
 I had 10.6 volts on those 2 wires when the grounds were loose. After tightening up the ground wires and solenoid  went back to working I did not check voltage.
electric fuel shutoff on kohler
Started by lamar on Sawmills and Milling
Last post September 26, 2003, 08:21:44 PM
by lamar
Peterson WPF Emergency shutoff replacement parts
Started by JimBuis on Sawmills and Milling
Last post May 17, 2009, 04:06:15 PM
by techmark
Plumbing question (drip leak at water shutoff valve)
Started by ecrane99 on Firewood and Wood Heating
Last post August 02, 2011, 01:21:56 PM
by Dean186
Working with trees services, and working and working...
Started by Daren on Urban and Community Forestry
Last post April 23, 2009, 02:01:44 PM
by chep
