Arborwear
Author Topic: first logs  (Read 1041 times)
Offline SCSawyer
  • If Your Not Sawing Your Wasting Time.
first logs
« on: June 27, 2016, 10:22:06 PM »
Got my first logs on the skid poles ready when I get a few spare minutes, from a few pines I needed to cut off of the fence line, 8's,12's and 16's . I hope to saw enough 2x's to frame out a small hay shed that I need real bad,guessing 12-1400 bf, then i got several big nice ones to saw into a mill shed.
Silas S. Roberts , Bluff Mtn. Timber
Offline SCSawyer
Re: first logs
« Reply #1 on: June 27, 2016, 10:27:12 PM »
Offline scully
  • Orange Mills Matter
Re: first logs
« Reply #2 on: June 27, 2016, 11:04:31 PM »
Looks like you preped very well ! I hope you get what you need !
I bleed orange  .
Offline fishfighter
Re: first logs
« Reply #3 on: June 28, 2016, 06:56:47 AM »
We need more pictures of your mill set up. ;D Looks good.
Offline dboyt
  • Log On!
Re: first logs
« Reply #4 on: June 28, 2016, 07:58:49 AM »
Looks like a nice setup.  What are you using for power?
Offline SCSawyer
Re: first logs
« Reply #5 on: June 28, 2016, 08:05:21 AM »
I 6 ford
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: first logs
« Reply #6 on: June 28, 2016, 08:11:03 AM »
I was reading in another thread that the blade needs to be in the shade to prevent the sun from heating it up. LINK
EDIT:  Well I needed to read a bit closer.    :P  Yup, my face is red.    :-[
Offline WV Sawmiller
    • Green's Sawmill Services
Re: first logs
« Reply #7 on: June 28, 2016, 08:27:25 AM »
SCS,
   Congrats. I trust all will go well. Warning - once you make that first cut you will be hooked. Sawdust has been found to be only slightly less addictive than cocaine.
    Leave plenty of room for expansion as you will soon fine that shed is not big enough - they never are. Be careful.
Offline SCSawyer
Re: first logs
« Reply #8 on: June 28, 2016, 08:39:57 AM »
Oh lord too late for that warning  , been at it 20 yrs
Offline SCSawyer
Re: first logs
« Reply #9 on: June 28, 2016, 09:04:41 PM »
Well forgot to take pictures but I did make it home in time to saw 3 logs today, man am I slow, I don't know if its getting older or the fact I didn't have an off bearer !!!
Wanted - small diamater low grade walnut logs and pallet logs ...
Started by Wes Lyon on Wanted
Last post August 12, 2006, 10:31:53 PM
by Wes Lyon
blue stain pine logs,aspen logs, Colorado
Started by logloper on Wanted
Last post February 23, 2010, 09:52:24 PM
by logloper
8 ft logs vs vs split logs for seasoning firewood
Started by Christopher7789 on Drying and Processing
Last post March 30, 2017, 10:45:58 PM
by GeneWengert-WoodDoc
114 logs
Started by woodmills1 on General Board
Last post May 17, 2007, 12:12:20 AM
by woodmills1
