EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: FF to the rescue  (Read 602 times)
Offline WV Sawmiller
    • Green's Sawmill Services
FF to the rescue
« on: July 11, 2016, 08:35:16 PM »
   I confess - prior to joining the FF I never wore a hard hat when felling trees. Since reading some of the horror stories and recommendations here I now do. Today it paid off.
   Decided to cut some of my dead and dying ash in the woods around my pasture and when I cut the 3rd one, about 14-15 inches butt log, I notched and bore cut it as I find ash is bad to splinter and barber chair on me. It had a natural lean in the direction I wanted it to fall so no need for wedges or cables and snatch blocks like some of the others. I removed the saw and cut the holding wood and it fell right where I wanted it to go. I was sitting back fat, dumb, and happy feeling smug for such a great job then "whack". Out of nowhere (Probably from overhead if the truth be told) a 3' limb about 3/4" in diameter hit me right on the gourd and left shoulder. Probably not big enough to have really done any serious damage but I assure you it hurt a lot less hitting my hard hat than my bare scalp.
   Thanks for everyone's attention and emphasis on safety and keep up the good work. Its real easy to get hurt and it can happen quick.
Offline Jim_Rogers
  • Keep your chisels sharp.
Re: FF to the rescue
« Reply #1 on: July 11, 2016, 08:45:55 PM »
When I was cutting in the woods, as it was falling, and I was running away, I would look up and make sure that something wasn't chasing me from above. There are many ways for a "widow maker" to find you. You need to be aware and "look up" while things are moving through the crowns of the trees around the one you are felling.
Jim Rogers
Offline gspren
« Reply #2 on: July 23, 2016, 10:19:49 AM »
  You need to look up even after things stop moving, I got hit 5-10 minutes after the tree was down.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: July 23, 2016, 01:14:45 PM »
Several minutes after I felled this dead White Oak tree, this Water Oak limb seemingly came out of nowhere.    :o
That was really unnerving to say the least!  :o
I never had or wore chainsaw chaps or a helmet before joining the FF.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #4 on: July 23, 2016, 05:36:54 PM »
A hard hat should be worn in any active timber sale no matter what you're doing.  We put ours on before stepping out of the cabs of machines.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #5 on: July 23, 2016, 06:04:21 PM »
It was many, many years ago, but my uncle was killed by a branch that was no bigger around than my little finger.  It fell down like an arrow and hit the "soft" spot.
Please, always wear a helmet.   :)
Save a farm today or starve tomorrow.
Rescue Me, Please!!!
Started by Gary_C on General Board
Last post June 22, 2008, 08:45:33 AM
by TexasTimbers
Tree Rescue
Started by chet on General Board
Last post September 24, 2004, 09:49:31 PM
by rebocardo
Junior to the Rescue...
Started by Rooster on LogRite Tools and Rite Leg Co
Last post June 13, 2014, 12:54:13 AM
by Rooster
Deer rescue
Started by Texas Ranger on The Outdoor Board
Last post April 01, 2008, 04:23:00 PM
by sgtmaconga
