Author Topic: Making sausage  (Read 4349 times)
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
Making sausage
« on: August 01, 2016, 02:56:52 PM »
I'm getting into sausage making. First batch of 15 lbs about did my kitchen aide in due to heat so I'm looking into something with a bit more power.
thinking about this unit?
https://www.amazon.com/STX-INTERNATIONAL-STX-3000-TF-Turboforce-Attachment/dp/B0012KJBR0/ref=sr_1_1?ie=UTF8&qid=1470076809&sr=8-1&keywords=STX+INTERNATIONAL+STX-3000-TF+Turboforce+3-Speed+Electric+with+3+Cutting+Blades%2C+3+Grinding+Plates%2C+Kubbe+Attachment+and+Sausage+Stuffing+Tubes
I'll be making Italian links. Last batch turned out great but it was a long day doing it in small batches.
Couple things I learned...
get the meat COLD!
Use less salt,
get the meat COLD!
use more fennel,
Get the meat cold!!
The First 60 years of childhood is always the hardest.
Offline Texas Ranger
  • Texan, by God and by choice.
Re: Making sausage
« Reply #1 on: August 01, 2016, 04:13:16 PM »
We have one of the grinders you posted the url for, slow.
Offline 21incher
Re: Making sausage
« Reply #2 on: August 01, 2016, 05:39:09 PM »
That looks great. I have a old grinder like the one you posted and is is fairly slow, but will run all day. I think that people that make large batches of sausage grind their meat and then use a seperate stuffer so the meat does not get mushed up from the pressure on the tube keeping it in the grinder auger to long and changing the texture. With the peppers coming in in my garden I had better get grinding also. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Mooseherder
Re: Making sausage
« Reply #3 on: August 01, 2016, 08:34:14 PM »
Another thing that helps to keep from mushing is to prime the head.
Make sure the knife and plate aren't too loose.  Hand force should suffice.
Bump the switch while dropping in a piece or two and turn off right away.  If you have mush, tighten the head.  You could also change to a medium or larger grind plate.  A nice steady feed rate with cut pieces that fall into the auger easily also keep things moving properly without heating the head.  Turn the motor off if you aren't able to keep feeding.  Sometimes you need three hands but you only have two.  Commercial Grinders raise the temperature of the meat from Cooler temp of 34 degrees to 50 degrees during the process.  Higher if grinding more than twice. I'm not sure how those home models work but I've been looking at buying one at Gander Mountain also.
Hope that one works out good for you.  Let us know.
Lane Circle Mill
Online LeeB
Re: Making sausage
« Reply #4 on: August 02, 2016, 12:04:58 AM »
Check LEM Products. They have really good prices on refurbished units. We make sausage a while hog at a  time.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: Making sausage
« Reply #5 on: August 02, 2016, 09:40:02 AM »
My son has the Cabelas 1 hp and it works good for grinding but not so great for stuffing IMO.
I dont know who makes this machine for cabelas.
I tried my wifes Kitchen aid and nearly killed it, she wasnt happy and very slow.
I think a separate stuffer is the way to go..
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Online LeeB
Re: Making sausage
« Reply #6 on: August 02, 2016, 11:05:28 AM »
Definitely on the separate stuffer. I have a 5 pound crank type and it will stuff 5 pounds in about 2 minutes. It takes longer to thread the casing than it does to fill it. Grizzly has good prices on them.
Offline DDW_OR
Re: Making sausage
« Reply #7 on: August 02, 2016, 02:21:02 PM »
I also am thinking of making sausage, then smoking it in an old metal fridge i have.
when i watch the "how its made" type of shows i saw that ice was added to the mixing process to keep the sausage COLD.
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Raider Bill
Re: Making sausage
« Reply #8 on: August 02, 2016, 02:46:14 PM »
I got my butts just about frozen before I cut them in chunks then back in the freezer before grinding and then again for mixing and then stuffing. between that and using a kitchen aide it was a LONG day.
I also kept my pans in the freezer.
One of the best smokers I've ever had was a old fridge.
Online WV Sawmiller
    • Green's Sawmill Services
Re: Making sausage
« Reply #9 on: August 02, 2016, 09:34:33 PM »
   I have never tried stuffing my sausages. I just make bulk venison sausage. I grind and mix it in a big manual mixer, I thin it uses a #32 blade. I mix 4 lbs of venison and one lb of ground pork and seasoning from a local sporting good store. I think one pouch makes 12 lbs of sausage and 2 pouches per box for about $5.
   I use an ice cream scoop to make balls, put 4 to a vacuum bag, squeeze them flat into 4 patties the vacuum and seal. That works well for the 2 of us. Usually cook 2 for breakfast if just us since my wife prefers bacon.
   Our 3 granddaughters spent the night and my wife fixed them French toast for breakfast. She served them and Abbie the 8 y/o middle granddaughter looked and asked "Where's the sausage." My wife said she didn't fix any and Abbie burst into tears so Becky relented and fixed her some.
Offline Bricklayer51
Re: Making sausage
« Reply #10 on: August 03, 2016, 08:26:04 AM »
We have been making venison sausage for 30 plus years always stuffed with the grinder. Got a stuffer from lems 5 years ago paid for it self the first time we used it.
Offline sbishop
Re: Making sausage
« Reply #11 on: August 03, 2016, 10:01:29 AM »
Do you have your own pork? if not, have you thought about buying ground pork from a butcher then making your sausages? I get my ground pork from Costco just under $2 lbs...saves the marriage...haha
Offline Raider Bill
Re: Making sausage
« Reply #12 on: August 03, 2016, 10:21:10 AM »
Wild Bill and I buy a couple hogs a year from the Amish. They kill, cut and wrap to order. Works out to about $1.19 lb.
They only make bulk country sausage (which I don't eat a lot of) but I'm going to ask if they will put my Italian seasonings in this year instead of theirs then we'll put it in links ourselves. For the amount of sausage we normally get from them I'll diffidently need a stuffer.
They have a huge Hobart grinder and a band saw that is run off a water wheel and cables running through trees to the building due to no power.
Personally I've only made 1 batch of 15 lb. I bought the boston butts at the grocery for .99 lb on sale. It came out so good I gave away about 10lbs bragging so now I'm out.
Offline Carson-saws
Re: Making sausage
« Reply #13 on: August 03, 2016, 10:38:51 AM »
You forgot 1 thing....."get the meat cold"  ;D
Let the Forest be salvation long before it needs to be
Offline sbishop
Re: Making sausage
« Reply #14 on: August 03, 2016, 11:06:59 AM »
That would be great if they could grind and mix up the meat....even if they would only grind it.
I've got a sausage stuffer (15lbs) and I use it once in a while....but the work that is involved in grinding plus the cost of a good grinder, for me its easier to buy the meat already grinded up...and go from there!
just my 2 cents...good luck and don't forgot to post pictures!!!
Offline DDW_OR
Re: Making sausage
« Reply #15 on: August 03, 2016, 04:09:57 PM »
..............One of the best smokers I've ever had was a old fridge.
i got 3 ways i could use with the fridge to do the smoking
Fire and wet wood
Propane and wet wood
Electric hot plate and wet wood.
I think i will use the Electric. could even add an auger to use smoker pellets
looking to do a fishing trip to the West coast, then smoke the fish when i get back.
the local hardwood i have are: Maple, Vine Maple, alder, apple, cherry, plumb, Madrona.
i have never heard of anyone using Oak, got that too.
i know to remove the bark before using it for smoking.
also have the Little Cheif and a brinkmann smoker. i wrapped both with the water heater fiberglass blanket.
I cannot use Pork since i am Kosher.
Offline Raider Bill
Re: Making sausage
« Reply #16 on: August 04, 2016, 08:35:30 AM »
I took out the plastic insides and lined mine with wood, tipped it up side down so the freezer part acted sort of like a baffle. Had a separate firebox out the back.
I cook more with oak that anything. Also I generally leave the bark on.
Offline scgargoyle
Re: Making sausage
« Reply #17 on: August 06, 2016, 06:12:32 AM »
I must be doing something wrong; I've been making and stuffing sausage with my KitchenAid for years. I make 5-7 lbs. at a time, as I like to try different types. Favorites include andouille, hot Italian, breakfast sausage, and a Greek chicken sausage that my wife has gotten seriously addicted to. Nothing better than making andouille, smoking it on your own smoker, and making a big batch of gumbo with it!
I hope my ship comes in before the dock rots!
Offline DDW_OR
Re: Making sausage
« Reply #18 on: August 06, 2016, 12:59:41 PM »
..... a Greek chicken sausage that my wife has gotten seriously addicted to.........
can you share the Recipe  food1
Offline submarinesailor
  • LT15 and a wife of 45 yrs
Re: Making sausage
« Reply #19 on: August 06, 2016, 02:08:11 PM »
X2 ;D ;D
sausage
Started by LeeB on FOOD! FOOD! FOOD!
Last post January 30, 2011, 05:27:00 AM
by Tom
homemade sausage
Started by sandsawmill14 on FOOD! FOOD! FOOD!
Last post February 20, 2017, 02:51:21 PM
by sawguy21
Venison sausage
Started by isawlogs on General Board
Last post March 01, 2004, 03:22:55 PM
by shopteacher
Anybody make their own sausage?
Started by johncinquo on General Board
Last post December 10, 2006, 07:43:59 PM
by BigTrev
