Author Topic: Grading Lumber  (Read 782 times)
Offline BillyB
Grading Lumber
« on: August 11, 2016, 09:27:55 AM »
Ladies or Gentlemen, can anyone tell me how I can get the lumber I cut graded for use for my own buildings? Sumter County GA just informed me any wood. Cut for framing has to be graded.
LT-15, Stihl MS880, MSC362, 72" Grandberg, Kubota M8546
Offline ljohnsaw
Re: Grading Lumber
« Reply #1 on: August 11, 2016, 09:52:43 AM »
If what you are building is "engineered", your engineer can sign off on your wood.  Otherwise, you need to find a traveling grader.
John Sawicky
Offline rjwoelk
    • countrysidefirewood
Re: Grading Lumber
« Reply #2 on: August 11, 2016, 10:13:52 AM »
Here in saskatchewan canada I can use ungraded lumber as long as it is not support walls.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Grading Lumber
« Reply #3 on: August 11, 2016, 12:27:35 PM »
Try contacting the southern pine bureau. I think they have traveling graders. Or ask them if they don't.
Jim Rogers
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Grading Lumber
« Reply #4 on: August 12, 2016, 07:54:18 AM »
Yes, call the Southern Pine Inspection Bureau.
Offline Heartwood
  • Will Beemer
    • Heartwood School
Re: Grading Lumber
« Reply #5 on: August 15, 2016, 07:34:47 AM »
Timber Products Inspection (TPI) out of Conyers GA. They specialize in traveling timber grading services.
Lumber grading
Started by Ron Wenrich on Sawmills and Milling
Last post June 20, 2009, 09:16:19 PM
by Chico
Lumber grading course
Started by trey_w on Sawmills and Milling
Last post October 15, 2003, 06:20:17 PM
by trey_w
lumber grading
Started by rathbone on Sawmills and Milling
Last post March 29, 2006, 08:02:11 PM
by GregS
Lumber grading
Started by Frank_Pender on Sawmills and Milling
Last post October 20, 2005, 09:24:57 AM
by Frank_Pender
