Author Topic: Grading Lumber  (Read 777 times)
Offline BillyB
Grading Lumber
« on: August 11, 2016, 09:27:55 AM »
Ladies or Gentlemen, can anyone tell me how I can get the lumber I cut graded for use for my own buildings? Sumter County GA just informed me any wood. Cut for framing has to be graded.
LT-15, Stihl MS880, MSC362, 72" Grandberg, Kubota M8546
Offline ljohnsaw
Re: Grading Lumber
« Reply #1 on: August 11, 2016, 09:52:43 AM »
If what you are building is "engineered", your engineer can sign off on your wood.  Otherwise, you need to find a traveling grader.
Offline rjwoelk
    • countrysidefirewood
Re: Grading Lumber
« Reply #2 on: August 11, 2016, 10:13:52 AM »
Here in saskatchewan canada I can use ungraded lumber as long as it is not support walls.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Grading Lumber
« Reply #3 on: August 11, 2016, 12:27:35 PM »
Try contacting the southern pine bureau. I think they have traveling graders. Or ask them if they don't.
Jim Rogers
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Grading Lumber
« Reply #4 on: August 12, 2016, 07:54:18 AM »
Yes, call the Southern Pine Inspection Bureau.
Offline Heartwood
  • Will Beemer
    • Heartwood School
Re: Grading Lumber
« Reply #5 on: August 15, 2016, 07:34:47 AM »
Timber Products Inspection (TPI) out of Conyers GA. They specialize in traveling timber grading services.
Lumber grading
Started by Frank_Pender on Sawmills and Milling
Last post October 20, 2005, 09:24:57 AM
by Frank_Pender
Lumber Grading
Started by sawwood on Drying and Processing
Last post April 06, 2008, 10:44:47 PM
by inspectorwoody
lumber grading
Started by rathbone on Sawmills and Milling
Last post March 29, 2006, 08:02:11 PM
by GregS
Grading lumber
Started by mdjblacksmith on Sawmills and Milling
Last post September 17, 2013, 12:07:46 PM
by Ron Wenrich
