Author Topic: 262xp  (Read 869 times)
Offline 630red
262xp
« on: August 19, 2016, 03:52:34 PM »
had a husqy 262xp in the shop today with the bottom conrod needle bearing letting go and done in piston and cylinder,was wondering is there any other models share the same bottom end.thanks for any replys.
Offline NCFarmboy
Re: 262xp
« Reply #1 on: August 19, 2016, 09:29:00 PM »
257,261.  Best thing is 261 two differences between 261 & 262.  261 has dished piston 262 has flat top piston.  Both 48mm bore.  Both use same cyl.   262 has 3 shoe clutch 261 has 2 shoe clutch.
Shep
Lots & Lots of Saws
Offline SawTroll
Re: 262xp
« Reply #2 on: August 20, 2016, 12:31:51 PM »
Shep
The muffler also is different.
Information collector.
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
Re: 262xp
« Reply #3 on: August 28, 2016, 05:28:04 AM »
Shep
How close are the 254's?? 254,257,261,262 all have 34mm stokes...in very similar cases. Are the cranks the same?? I have four sets of 254 bottom ends in various states of degeneration from sitting in a barn, two good and one maybe good cranks, but all the case bearings are ruined ... was thinking of blending an tweaked AM 262 top end with a popup piston build to one, using a 242 air filter to allow it to be stuffed under its very weather faded 254 top cover... and making a "chicken chit to chicken soup" saw for kicks to see if I can make what should be scrap cut wood...:)
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline SawTroll
Re: 262xp
« Reply #4 on: August 28, 2016, 12:39:49 PM »
Shep
The 154/254 cranks have a shorter con rod, otherwise they are the same - except for minor changes trough "generations" of them, that didn't happen at the same time with all models. I don't think there are any compatibility issues caused by those minor changes, only because of the different con rods.
261 vs 262xp
Started by sd locke on Chainsaws
Last post January 19, 2010, 12:12:19 AM
by des170stihl
261 and 262xp
Started by thumper on Chainsaws
Last post October 14, 2011, 08:44:40 PM
by nmurph
262XP maybe a goner!
Started by Lurcherman on Chainsaws
Last post March 27, 2008, 09:18:37 AM
by SawTroll
262xp issue
Started by northern on Chainsaws
Last post June 11, 2010, 06:50:05 AM
by northern
