Author Topic: 10 inch saw blades. What do you recommend?  (Read 2455 times)
Offline 21incher
« on: August 28, 2016, 02:08:06 PM »
I have been using a contractors saw with thin kerf Freud combination blades for the last 30 years . Never got perfect results, but the saw was not capable of perfect cuts and only was 1HP. I just ordered a Grizzly G1023RLWX cabinet saw that is 5 HP and should be capable of better precision. I want to order new blades for it so I am looking for input on the blades that everyone uses. I am looking for recommendations for a good general purpose blade,  a good glue line ripping blade, and a good 8" dado set that has very little tearout. I need full kerf blades because of the riving knife setup.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: 10 inch saw blades. What do you recommend?
« Reply #1 on: August 28, 2016, 03:10:00 PM »
 I have a 12 inche cabinet saw and I have a few blades for it, I use a 10 inche thin kerf Freud riping blade most of the time as it is way cheaper then a the 12 inche to buy and get sharpened. I do have a 12 inche freud riping blade for the deep cuts. As I almost only ever rip on my table saw I have litle use for a combination blade for it and a good riping blade will do the job nicely when ever I need to crosscut with it.
   Marcel
Offline barbender
« Reply #2 on: August 28, 2016, 03:13:55 PM »
I have always preferred the Freud blades, but I've never tried the more expensive manufacturers. They are the best I can get locally, FWIW.
Offline Bruno of NH
« Reply #3 on: August 28, 2016, 03:56:44 PM »
Give a Forrest blade a try or a good quality amana .
I have the Dewalt hybread cabinet saw with the sliding crosscut table
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline Larry
« Reply #4 on: August 28, 2016, 07:36:45 PM »
In my stable of 40 tooth combination blades I have a Freud, an old Freud Avanti, a couple of Forrest WW-II's, and an old premium Craftsman.  I'm not sure I could have seen much difference in performance when new and know for sure there is no difference since having them sharpened a few times each.  I keep them all sharp and will switch one out at the first hint of it dulling.
For ripping I only have experience with Freud glue line rips and have been satisfied.  I generally change from a combination blade to a rip if I have more than a board or two to saw.
I use a CMT dado set I got on sale at Lowes.  I'm sure there are higher quality sets but it has done ok in solid woods.  I seldom if ever do plywood anymore which is the real test for dado blades....plywood is also the test for crosscut and combination blades.  It takes an excellent blade along with an accurate saw to deliver splinter free cuts for any length of time.
From my experience I think you would probably be satisfied with any of the high end Freud's or Forrest.
Offline 21incher
« Reply #5 on: August 28, 2016, 09:01:59 PM »
Thanks. It sounds like I should stick with Freud. I have read good and bad about the Forest Woodworker II so I am thinking about avoiding that one. I have a couple of old Freud LU84M11 blades I may try and find someone that can sharpen them. I will have to look into the Amana also. The saw will be used mainly for ripping so I guess that I will order a rip blade first. Hopefully it won't be to hard to  sell my Delta contractors saw with a sliding table on craigslist this week.:)
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: August 29, 2016, 07:46:21 AM »
I have used exclusively Freud and Forrest WWII.  The Forrest stays sharper and cuts cleaner much longer.  Both cut the same when new and sharp.
Offline 21incher
« Reply #7 on: October 01, 2016, 07:21:32 PM »
In the end I purchased a Freud P410 premiere fusion That I am very happy with. Clean crosscuts any thickness and rips up to 1 1/2" stock great. It was a toss up between that and the Forrest, but the Freud was about $40.00 cheeper on Amazon and had better reviews so I decided to try it. I think I will pick up the Freud rip blade next because the 410 blade is slow when  ripping 2" stock. Thanks for all the suggestions. :)
Offline jamesamd
« Reply #8 on: October 01, 2016, 11:09:59 PM »
excellent choice  8) I have 5 that get rotated as they resin up. They stay on the saw always unless I'm making a quick dado.
I have both the freud and cmt dado sets, identical, freud made in italy. cmt made in EU, duh!
Best of luck with Your new saw ;D
Jim
All that is gold does not glitter,not all those that wander are lost.....
Offline AlaskaLes
  • Livin the dream!
« Reply #9 on: October 10, 2016, 02:30:26 PM »
We're using mainly Freud blades and those would be the upper priced range.  I've had great success with those so far.
We went with the Infinity 8" Dado set.  It was near 300.00, but still a bit less than the Forrest we were looking at.  Bought the 150.00 freud dado set first and had all kinds of tearout, so we took it back.
Infinity blades are very good and I plan to try some of their 10" blades in the future.
We're running these on the 5hp Industrial SawStop.
I've cut several 2"-3" slabs to size and I am amazed at how easily this saw slices through 3" of solid wood.  The motor just loads up and keeps on chewing.
You can see Mt McKinley from our backyard...Up Close!!
Mighty Mite MK 4B, full-hyd, diesel bandmill
Kubota 4wd 3650GST w/FEL; Forks;
3pt Log Arm& Log trailer
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
Robar RC-50 50BMG-just in case the trees get out of line
Offline sawguy21
« Reply #10 on: October 10, 2016, 03:53:37 PM »
I just got a decent 10" for hauling it away, the shop didn't want to bother trying to sell it, but the blades are resined up. What do you suggest for cleaning them? They are relatively inexpensive carbide tips but at my skill level they should serve just fine. ;D
Offline 21incher
« Reply #11 on: October 10, 2016, 07:37:40 PM »
I was thinking about that freud dado set and found many reviews that also had tearout issues like you. I am currently thinking about the Dewalt set with 4 wing center cutters that seems to be in my price range with good reviews. The best part about having the horsepower is being able to use full kerf blades that don't flex like the thin kerfs I used on my old saw. :)
Offline jamesamd
« Reply #12 on: October 10, 2016, 08:00:55 PM »
Offline Just Me
« Reply #13 on: October 11, 2016, 06:47:03 AM »
 I use FS Tool and commercial Freud blades, bot are good with a nod to the FS Tool.
Don't use a dado a lot but have a Forest that has 20+ years use on it, cuts well with no chipout. Its a 10". If you have a ten inch saw and have the HP I would recommend an 8" size dado.
Offline btulloh
« Reply #14 on: October 11, 2016, 08:56:23 AM »
I soak them in a shallow pan with a lot of baking soda and a few drops of DW deterg.  Start with hot water.  Leave them in for a while and then rinse.  The resin just falls off.  I've seen lot's of other ways but this has always worked for me.
HM126
Offline btulloh
« Reply #15 on: October 11, 2016, 09:01:10 AM »
Good discussion on dado blades.
Does the Infinity dado leave a smooth bottom?
HM126
Offline AlaskaLes
  • Livin the dream!
« Reply #16 on: October 11, 2016, 02:06:49 PM »
We are presently building funeral urns and jewelry boxes, etc from our KD wood.
When we started last year, we needed to get our tools up to the standards of production that we were striving for.  The Freud set was their 2nd most expensive...125.00+
The bottom of the dado slots were not smooth and the edges where it exited had tearout.
After 20-30 dado slots...there were several carbides trying to release from the blade.
I really like Freud and use them a lot, but this was very substandard for Freud.
The Infinity dado set is Excellent!!  They cut smooth at the edges and almost perfectly smooth in the bottom of the slots.  They are very well balanced and run (I think) 24 teeth on the outer blades and the 4 blade cutters in the center.
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
Offline 21incher
« Reply #17 on: October 20, 2016, 08:32:22 AM »
I was checking out the 8 inch infinity dado set on the infinity site and it is on sale for $219 and there is a $20 coupon code so is $199, but they list it as having 6 - 6 tooth center blades. Is that the set you have? I didn't see a 4 tooth center cutter set like you mentioned.  I think I may try one since you have had good results using one.  :)
Offline azmtnman
« Reply #18 on: October 21, 2016, 12:21:59 AM »
I didn't see anybody mention Diablo blades. Doesn't anyone use those? I have had good luck with their 7-1/4 circular saw blades and have 10" on our miter saws. They seem to last and cut nicely.
1983 LT 30, 1954 Ford NAA, 2006 Polaris 500 EFI, '03 Dodge D2500 Cummins powered 4X4 long-bed crew cab, Cummins powered '88 Chevy R30, Stihl MS250, MS311 and MS661--I cut trees for my boss who was a Jewish carpenter!
Offline AlaskaLes
  • Livin the dream!
« Reply #19 on: October 21, 2016, 03:55:02 AM »
21",
I was just sittin here sipping on a nice dark beer and slowing down for the evening, and I read this and hustled out to the shop to check.
I was wrong...I bought them last year. This is the 8" Dado set.  They are indeed the 6 tooth chippers.  The right/left blades are in the dado saw so I didn't count them, but we are very happy and I would buy them again.
The set comes with right side; left side; 4@1/8"; 1@1/16"; 1@1/32"; and shim pack.
After messing around with the Freud that disappointed and shouldn't have...I would buy these or the Forrest.  They have the best history of happy customers.
The only thing I think the Forrest might have over these is, Infinity uses poly/plastic disc shims.   Forrest uses metal disc shims.  Maybe better...I haven't had any issues with this kit.
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
I need some 2 inch 055 blades
Started by just_sawing on Sawmills and Milling
Last post October 12, 2010, 10:15:46 PM
by sgschwend
4 or 5 inch wide Band Blades ??
Started by Tobaccoman on Sawmills and Milling
Last post May 09, 2013, 09:39:05 PM
by isaacpopp
31 inch to 25 inch Western Red Cedar on the Manual LT 35
Started by Ruffneck on General Board
Last post March 16, 2017, 02:50:23 PM
by Ruffneck
10 inch X 4 Inch beams Coastal Douglas Fir
Started by ultraglide62 on Drying and Processing
Last post June 11, 2012, 10:36:24 AM
by metalspinner
