Author Topic: Lt15 wide trailer  (Read 3918 times)
Offline Tahoe tom
    • Greywood Design
Lt15 wide trailer
« on: September 02, 2016, 12:49:21 AM »
Hi everyone, I'm Tom! I just joined the site, and thought I would introduce myself.  I am a married, have a one year old son, and live in the Sierras. I have been a  part time furniture builder/designer the last three years, and just left the tree climbing/care Industry to pursue furniture and milling full time.
Anyway I bought a Lt15 wide and I'm building a trailer for it. So far the trailer is about 23' long. I was wondering where I should place the axle on it? Any Lt15 go owners that would care to measure where their axle lays? Thanks and I look forward to contributing to this online community.
Offline ChugiakTinkerer
Re: Lt15 wide trailer
« Reply #1 on: September 02, 2016, 03:05:46 AM »
Welcome to the forum Tahoe tom!  Hopefully someone with some experience will be along shortly to help you with the trailer.
Woodland Mills HM130
Offline tnaz
  • Retired; with a Full Time Task! Of my Choosen
« Reply #2 on: September 02, 2016, 05:38:32 AM »
Welcome to the Forestry Forum Tahoe tom.
Terry
Offline thecfarm
« Reply #3 on: September 02, 2016, 05:47:16 AM »
Tahoe tom,welcome to the forum.
Good luck with your new business venture!!
There will be someone that will help,but this will get you by until they show up.
http://www.forestryforum.com/board/index.php/topic,83571.msg1275811.html#msg1275811
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #4 on: September 02, 2016, 07:35:47 AM »
60/40 should work pretty good.  That's where I put mine.
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline Czech_Made
« Reply #5 on: September 02, 2016, 07:56:49 AM »
Welcome  :)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: September 02, 2016, 08:41:49 AM »
Hello Tahoe tom, and Welcome to the Forestry Forum.  Your Smile says that you are a happy-go-lucky guy.   :D
I wish you the best with your new business venture.   smiley_thumbsup
Offline John S
« Reply #7 on: September 02, 2016, 09:05:47 AM »
Tom,
I think locating the axle would depend on where the travel pin for the mill is located, such as on the LT15GO.  I would contact Woodmizer and follow their recommendation (and probably purchase their locking hardware).
John
2018 LT40HDG38 Wide
Offline Rougespear
  • Salmon Arm, British Columbia
« Reply #8 on: September 02, 2016, 11:00:26 AM »
Normal is between 60-70% of total trailer length.  Most common is 65% I think.  I put mine at 70% just because that's where it fit best.  Measure total trailer length from the tongue, and I think you need to have 10% of the trailer weight on the tongue.  Best to confirm all I've said though, as I have only built one trailer.  I was careful in the fab process, and it tows very nicely.
Custom built Cook's-style hydraulic bandmill.
Offline Tahoe tom
    • Greywood Design
« Reply #9 on: September 02, 2016, 12:02:10 PM »
Thanks everyone for thexample info and greetings. I will probably put it somewhere around the 60/40 location, I'm just a bit concerned about the 8 foot section that cantelivers out past the axle... but it should be fine right?
Offline Tahoe tom
    • Greywood Design
« Reply #10 on: September 02, 2016, 12:04:32 PM »
Thanks Rougespeare, I think 70% will be better than 60%, does your trailer still back up well? Or did you loose some maneuverability?
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #11 on: September 02, 2016, 05:25:38 PM »
You will have one crazy trailer if you get to much weight
in back of the axle.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Tahoe tom
    • Greywood Design
« Reply #12 on: September 07, 2016, 09:10:03 PM »
Well, I'm just about done with the trailer. I made the axle removable so I can slide it forward or backward on the trailer to find the best placement for both towing and manuverability. All that's left is to build the log ramps and a winch mount for parbuckling.
Online ljohnsaw
« Reply #13 on: September 07, 2016, 11:32:24 PM »
Welcome, Tahoe Tom!  Nice looking trailer.  Are the axles mounted on angle iron or C channel?  How do you lock the axle in place, a couple of hitch pins?  I can't tell in the pictures, do you or will you have leveling jacks on the rear?  I see the mid and front ones but you will definitely need some on the rear!
As far as maneuverability, the closer the wheels are to the hitch, the faster it will jack knife when backing up.  That might come in handy if you are trying to squeeze into a tight spot.  Going forward it won't matter as long as you have 10-15% of the trailer weight on the tongue.  You can lock your head in the place that gives you that amount of weight.  What do you think the whole thing weighs?  Will you be mobile sawing a lot?
My cabin project is not too far from you.  I'm at exit 160, Yuba Gap, 39 miles to the west.  Do you fish much on the Truckee River or Stampede?
John Sawicky
Offline hacknchop
« Reply #14 on: September 08, 2016, 12:18:37 AM »
Welcome to forum trailer looks great i have pull all kinds of mills and know that you will do just fine and before you know it you will back her in anywhere you need to ,have fun and enjoy  :)
Often wrong never indoubt
Offline Tahoe tom
    • Greywood Design
« Reply #15 on: September 08, 2016, 10:13:41 AM »
I was wondering where your cabin was, it looks like a great project!  I mounted the axle on 5/8" bolts,(2 each side) I was going to do hitch pins but I'm not  sure they are secure enough. It's a c channel I welded with angle and flatbar. I think the mill and trailer will weight around 2200. I hope to do a bit of mobile milling to add revenue /diversity to my furniture business. I fly fished the truckee and stampede a lot a while back, currently taking a break. I would love to see your cabin! I have been doing a side job helping build a house on the top of Donner summit off the soda springs exit. It's pretty modern but there is some timber framing and other cool features.
Offline kng
« Reply #16 on: September 08, 2016, 11:28:53 AM »
Nice trailer!
-Kyle
2015 LT15G19 with Power Feed and custom trailer
Offline kensfarm
  • Think!
« Reply #17 on: September 08, 2016, 01:28:23 PM »
That looks great..  TK has large bolts for the head to lock down when transporting.. it puts the head right over the tires I believe.
Online ljohnsaw
« Reply #18 on: September 08, 2016, 05:08:17 PM »
Sounds good.  Don't mean to be a Debbie Downer but, in California, any trailer weighing more than 1,000 or 1,500 (I forget which) must have trailer brakes.  I didn't see any wires for electric brakes.  Both DMV and Highway Patrol said if it has wheels on the road, it must be licensed.  Good luck.
My address is technically Soda Springs but I'm 14 miles from there and only 2 miles from Nyack!  Donner summit is a beautiful place!  Almost bought a cabin there behind Donner Ski Ranch but it didn't have any property and the Rock Crawler championships were held literally in the back yard.
John Sawicky
Offline Homelite775
  • Member*
« Reply #19 on: July 19, 2017, 04:48:48 AM »
Happy to see your pictures Tom.  Looks good.  I'm about to pick up my LT 15 W-I-D-E next week and am not alone here to say we'd love to get an update on your trailer progress, success, and advise for the other mill owners that really want to make their own trailers too.  Thank you for your posting this.  I'll be standing by... likely with welding helmet ON!
LT15 Wide, LT70 Wide, where's the Wide Edger?
Started by Dave Shepard on Sawmills and Milling
Last post March 25, 2018, 11:53:41 PM
by Darrel
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
LT15 vs LT15 wide?
Started by gump on Sawmills and Milling
Last post January 29, 2019, 07:43:56 AM
by randy d
Soon to be new LT15 Wide owner
Started by Smithkp on Sawmills and Milling
Last post August 07, 2018, 06:16:28 PM
by SawyerTed
