Author Topic: Stihl HT-101 Pole Saw running issues  (Read 5622 times)
Offline tstex
« on: September 13, 2016, 10:15:25 AM »
Hello to All,
It's been awhile since I've been on the boards - good to be back and I hope everyone is doing well.
My pole-chain saw would not fire-up bc the primer-ball was not working to prime fuel into the carb.  The primer ball plate was $28 bucks, and a whole new carb w plate was $45, so I just replaced the whole thing.
The guy at the shop got it to fire-up after replacing the carb/primer ball, but it was running sluggishly.  He asked me how old the fuel was?  I had mixed a new batch about 2-3 months ago, and stored the gas container in a well built and concealed utility house where all my chainsaws, oils, fuels, etc are stored.
Got it back to the ranch and it was tough getting it started, but once started it ran but when it got to a near idle, it would die.  Not easy to start again either.
I called the guy back and he said to try fresh fuel and then let him know.  if w new fuel it did the same, to call him back and they would fine tune the carb settings.   He told me the settings come factory set when I asked.
Prior to when I last used it and all before, it wasn't that hard to start when on full choke after pulling cord 3-5 times...once I got it warmed-up, it idled well too, and restarted very easily.
To conclude, looking to get your advice and experience on what might be the issue(s)?  I really don't think it is the gas bc I have used what I think is older gas previously and did not have this problem.  If you have any questions, pls let me know and I will get right back to you.  I am going back out to the ranch again tomorrow [Wed] and would like to have resolved if possible.
Thank you very much for your time and help,
tstex
Offline Ox
  • Trying to learn/remember something new every day.
Re: Stihl HT-101 Pole Saw running issues
« Reply #1 on: September 13, 2016, 10:41:02 AM »
Ain't nothing more than a new carburetor needing some adjustment.  Very common.
Could be a bad batch of gas.  If you can help it, don't run ethanol fuel in it.  If you have no other choice, buy a product made to counter the ethanol in the fuel.  Ethanol is the scourge of modern humans.
Offline tstex
« Reply #2 on: September 13, 2016, 11:04:54 AM »
Thanks OX - I'll try the new gas, but unfortunately, the ethanol is unavoidable.  What fuel additives are you referring to that will counter the OH issue?  I use the Stihl mixture w my gas and 10% ethanol.  I use the lower octane gas; would a higher octane help?
Offline dougand3
« Reply #3 on: September 13, 2016, 11:31:36 AM »
Agree with Ox - carb adjustment. Dealer should have done this. Carb probably needs a silly tool for H-L screw heads. I've seen 7 different variants of carb tool - Spline, D, Pacman, etc. One reason I like AM carbs - plain ole slot head.
If pole saw ran fine on 87 Octane before, bumping up to 89 or 91 won't help. Many small 2 cycles do call for 89 Octane (USA method) but many folks do fine on 87.
I use non-ethanol gas, so can't comment on additives.
Offline Ox
« Reply #4 on: September 13, 2016, 11:39:58 AM »
Personally, I've always used the high test fuel.  Some do, some don't.  Around here, high test is ethanol free so it's what I use.  If it ran OK on 87 before, keep using it.  My brother in PA has to use ethanol as well.  He's got his own business in lawn care and landscaping.  He uses something called Ethanol Shield and swears by it.  No more problems with the ethanol.  There's something made by by Sta-Bil for ethanol I'm pretty sure, found at Walmart.
Offline tstex
« Reply #5 on: September 13, 2016, 11:49:44 AM »
Thanks again for your follow-up Ox - I am going to buy those fuel stabilizers...
Doug, if I can find the correct tool, are there any instructions or videos/or other that can show me how to fine-tune?  I will not try it if I do not have the correct tool...
thanks again guys, I really appreciate the quick responses - tstex
Offline dougand3
« Reply #6 on: September 13, 2016, 02:09:30 PM »
mweba has a great chainsaw tuning video. The principles are the same.
You can search youtube for "String trimmer tuning". I don't know which is good.
Look at your H-L screws and see what the heads are. Most are Splined. You can jury rig a copper tube or electrical connector to turn screws....but you need to know if you're really turning or slipping.
What I do is pull the screws and dremel a slot in screw head. Or if in a hurry, just cut the collar, too.
http://www.forestryforum.com/gallery/albums/userpics/36829/H_L_mix_screws3.jpg
Offline tstex
« Reply #7 on: September 13, 2016, 04:49:08 PM »
Wow !!!  Thanks Doug, I appreciate that.
While there are some unscrupulous people in this world, it never ceases to amaze me of the generous people on this forum and others just like it that spend time to make videos in the hope they can help out someone else.
That's also a great close-up pic of the carb !!
Truly amazing - tstex
Offline ZeroJunk
« Reply #8 on: September 14, 2016, 07:45:11 PM »
Without knowing how many hours is on it the valves could need adjusting. And, if it really has a lot of hours on it the cam gear could need replacing. If it only has a few hours on it then yeah, could just need a carb tweaking.
I usually adjust the idle for max RPM and then richen just enough to hear it start to slow down.
Offline tstex
« Reply #9 on: September 15, 2016, 10:00:18 AM »
Hey Guys,
It was one thing breaking after the other, and I had to go back into town so I just dropped-off the c-saw to the dealer and they said they would finish-up the tuning.  I do have 3 other chain saws an I know one of them needs some tuning, so I am going to follow the video...none of these need the funky tools to fine-tune carb...I'll post back and let you know if where was anything else that need to be done besides fine-tuning.  I also put a note on there to tell me what was done to get her fine-tuned and post that back.
Thanks again to everyone - tstex
Offline Ox
« Reply #10 on: September 15, 2016, 10:27:02 AM »
We're talking about a 2 stroke engine on a pole saw.  No cam gears, camshafts or valves involved.  :)
Offline tstex
« Reply #11 on: September 15, 2016, 10:38:18 AM »
 8)
"The less moving parts it has, the less it will cost you"
I'm all for that - thanks Ox
Offline dougand3
« Reply #12 on: September 15, 2016, 11:06:18 AM »
I just looked at the IPL. This engine does indeed have cam, valves, rods, etc. It must be a "4 Mix" hybrid. It's a 4 stroke that needs 2 cycle mix because it doesn't have an oil reservoir.
So, if not a simple carb tune - lotsa disassembly to diagnose and fix.
Offline Ox
« Reply #13 on: September 15, 2016, 11:13:48 AM »
Oh dear.  Those pesky 4 strokes that run like 2 strokes always trip me up.  Didn't even think about it.  So yeah, some adjustment to those little valves may be in order.  Zero Junk had it right, I was wrong with my assumption that it was a 2 stroke.  I had a mini 4 stroke Honda that didn't run well and a valve adjustment made it run like new again.  The smaller the engine the more an adjustment seems to make a difference.
I remember we were running an International 1466 farm tractor.  It ran and started perfect, plenty of power, good smoke, no clue anything was wrong.  Then entire head needed rebuilding, the seats were all gone.  No clue!  See above idea about small engines being more picky.
Offline ZeroJunk
« Reply #14 on: September 15, 2016, 01:22:06 PM »
Unless the valves themselves are damaged the cam gear, followers, and push rods are easy to get to. Take the top cover and starter cover off, take an air wrench and remove the starter pall deal whatever you call it. There is a four screw cover that comes off and the cam gear comes right out. there are two pins , one for the gear and one for the followers. They slip right out. Put the motor at TDC which is where the arrow on the flywheel points at the bottom screw on the ignition coil and put the new cam in with the arrows on the cam pointing at the two little bosses at like 4 and 8 o'clock inside the crankcase. Really not much to it.
Offline joe_indi
  • The older I get the more I learn
« Reply #15 on: September 16, 2016, 10:15:45 AM »
That Pole saw has the same engine as a F100 brushcutter. They are extremely sturdy. But old fuel affects them. But since your carb is a new one, you need to check the filter in the fuel tank (the pickup body).
One very important thing to remember is to store these engines on the compression stroke. Anything else will cause rust formation on the valve seats, especially the exhaust valve.
Insect intrusion/invasion too is a risk.
Usually the 'first aid' that I carry out for these 4 Mix engines is to add some nitro cellulose thinner and some vegetable oil to the fuel (coconut?sesame/canola/castor).
Remove the air filter.Start up the engine and let it idle. Once in a way blip the throttle.
Hopefully the fuel system and the valve seat will cure themselves.
In case you need some guidance on opening up the valve gear(cam wheel, tappet assembly etc) or setting valve timing, my video on youtube might be of some help.The engine used in the video is a FS130. It is more powerful but otherwise everything is same as on your 101 engine
Offline ZeroJunk
« Reply #16 on: September 16, 2016, 12:17:21 PM »
Nice video Joe. Wish you had taken the valves out. I have never gone that far. I have a carcass in the shop that I may disassemble just to see what's involved.
Offline joe_indi
« Reply #17 on: September 17, 2016, 12:21:23 PM »
Valves removal is a tool-less job! Unless a pen or pencil counts as a tool!
Use the pencil to keep the valve head in position, press down on the washer and slide it sideways. That washer comes off and thats about it. ;D.
If you want it in pictures I can post them
Offline ZeroJunk
« Reply #18 on: September 17, 2016, 12:52:05 PM »
Thanks Joe, I think I can understand it from what you describe.  I have one in the shop that I am at a loss as to what could be the problem other than a sticking valve. It simply won't rev, but idles fine. I have changed the carb, ignition, and cam gear and it changes nothing. It would idle with the carb wide open for 10 or 15 seconds and then decide to take off and run. Then when you let it back down to idle it might take off again eventually. Now, it just maintains about idle speed regardless of how open the butterfly is or which carb is on it. Weird. I have changed gas lines, impulse and all that. Even soaked it with carbon cleaner for 24 hours. Not much left.
Of course, it is way past the time I have spent messing with it, but I'm just curious.
Offline joe_indi
« Reply #19 on: September 17, 2016, 02:18:44 PM »
ZeroJunk, when I get those symptoms on a Stihl 4Mix, the first thing I check are the two pins, the one for the cam wheel and the one for the cam followers. Usually the cylinder side seat of the pin for the cam wheel and the cover side seat of the pin for cam followers become oval and the causes the valve clearances and valve timing to change. I use a piece from a beer can to tighten up the loose seats and it works fine.
How does the HT 131 Stihl Pole Saw compare to other Pole Saws?
Started by JOE.G on Chainsaws
Last post May 29, 2012, 01:36:36 AM
by Dixie Feller
Ms200t running issues
Started by Grimace71 on Chainsaws
Last post June 13, 2018, 05:36:35 AM
by ladylake
Disapointing stihl pole saw
Started by edwin dirnbeck on Chainsaws
Last post December 16, 2017, 09:39:34 AM
by deerslayer
Stihl HT75 pole saw--no oil ?
Started by Bobcat_pa on Chainsaws
Last post March 17, 2004, 04:19:51 PM
by Bobcat_pa
