Author Topic: CB EC-2400 firebox weld issue  (Read 609 times)
Offline Bob Lentz
    • Back40Ranch
« on: September 14, 2016, 03:50:15 PM »
the metal with holes in it that covers the air channel has broken and bent a part of the cover inward (see pic).  This caused the air channel to become totally clogged solid. Cant get far enough behind the plate to clean out.  I am thinking that the cover will need to be removed to gain access to the channel to clean it, then a new cover plate welded in.
The unit is 6 years old.  Maybe time for a new one?
Thoughts?
eClassic-2400
Triangle Tube Backup (Propane)
Heating 6500 sqft house and small pool
Offline stratford 50
Re: CB EC-2400 firebox weld issue
« Reply #1 on: September 18, 2016, 08:45:01 AM »
Is the picture showing the stainless steel angled plate that is removable for cleaning? I have a 2014 CB 2400 and doesn't appear from your pictures to look similar. I use a very stiff wire and an air compressor with a shop vac and so far cleaning the air channel is doable.
Offline burnswin
« Reply #2 on: October 22, 2016, 05:42:48 AM »
I was told my coal bed was too deep generating so much heat it warped the air channel plate.  I have a replacement kit from CB - E-Classic 2400 Air Channel Insert - that came from the dealer.  it includes cutting out the existing channel and slipping this insert in on both sided.  I have a friend who's a welder so we are installing them this month.
Possible Issue w/Eclassic 2400
Started by ParadisePA on Firewood and Wood Heating
Last post May 11, 2012, 08:02:04 AM
by Ken01
E-Classic 2400 Issue Revisitied
Started by Cass007 on Firewood and Wood Heating
Last post March 16, 2015, 08:26:14 PM
by garret
E Classic 2400 air flow issue?
Started by VTwoodburning on Firewood and Wood Heating
Last post November 17, 2014, 01:50:45 PM
by VTwoodburning
Central Boiler E-Classic 2400 serious issue
Started by AsaG on Firewood and Wood Heating
Last post February 25, 2012, 11:06:25 PM
by AsaG
