KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Sawing Too Thin  (Read 6090 times)
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
Re: Sawing Too Thin
« Reply #60 on: April 21, 2017, 07:02:22 AM »
Cup will change the numbers for sure if you allow it to happen.
So don't let it cup. Problem solved.
Also, cup can be controlled, to some extent, by the sawing pattern.  Or conversely, it can be made much more likely, and much worse, with incorrect sawing patterns.
HobbyHardwoodAlabama.com
Offline D6c
Re: Sawing Too Thin
« Reply #61 on: April 21, 2017, 09:47:49 AM »
Interesting thread, especially since there isn't much of an established furniture lumber market here (that I know of).
I've got about 60 walnut logs (small to med.) right now that I'm unsure how I want to saw them.
The original scale on my LT40 only allowed 1/6" inch for blade kerf and 4/4 was under 1" so I made another scale allowing 0.1" so 4/4 measures a full 1"
From reading this thread it sounds like need to make up another scale that will make 4/4 lumber at 1 1/8".
....A setworks would make things a lot easier.
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Sawing Too Thin
« Reply #62 on: April 21, 2017, 12:29:42 PM »
I have found from personal experience that there is nothing worse than not having the wood I needed to complete the project I had in mind.
I WILL NEVER SKIMP AGAIN!!!
1992 LT40HD
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Sawing Too Thin
« Reply #63 on: April 21, 2017, 03:52:45 PM »
Yes, especially for walnut.
Online barbender
Re: Sawing Too Thin
« Reply #64 on: April 21, 2017, 09:55:27 PM »
The scale on my WM has a regular quarter scale on one side, and a hardwood scale on the other where the 4/4 is 1 1/8" if I remember right (97 model).
Offline Larry
Re: Sawing Too Thin
« Reply #65 on: April 21, 2017, 10:13:23 PM »
Had a customer come looking for some wood.  She said that she went to buy some cedar from another sawyer, but it was sawn at 3/4" thick  :-\.  Maybe suitable for lining a closet, but how good is the cedar closet lining market?
I've sold quite a bit of 3/4" cedar.  Yes, closet lining, paneling, siding, and craft items.  Next best seller is 10/4 for outside stuff.
I'm sometimes amazed at what sells. :D
Re: Sawing Too Thin
« Reply #66 on: April 21, 2017, 11:04:32 PM »
I'm trying another experiment.  A local mill had a whole stack of miscut thin cedar boards.  Waste of lumber for them, opportunity for me.  I bought about 800 bdft for almost nothing, dried and planed it to 1/2" on one side.  Rough sawn one side, planed the other.  We seem to have at least one customer a week ask for this, so now we can point them to the stack and hope they bite.  This is why the topic is so relevant as "sawing too thin" affects the big mills as well as us little guys.
Offline sandsawmill14
  • love my job (most days)
Re: Sawing Too Thin
« Reply #67 on: April 22, 2017, 12:17:10 AM »
to thin is a major problem for commercial lumber i had a tt load of poplar ( 12 mbdft ) because it was a 1 5/8 instead of 1 11/16 :o >:( ::) but they told me the spec beforehand so... smiley_dunce it was on me not them ::) when they give you a min spec its the min :( :D :D :D
Offline plowboyswr
Re: Sawing Too Thin
« Reply #68 on: April 22, 2017, 01:36:56 AM »
Got caught by a buddy's daughter at church a few weeks ago. She says Uncle Steve we are replacing the floor in our house can you bring your truck over so we can load up the debris to haul off. She bats them puppy dog eyes at me gives me a hug the best she can with her pregnant belly in the way so what was I to say.  Yeah, I go, we load up their old carpet and some other junk. Then she says can you help carry in the new flooring. Oh all right. We step into the garage and there sits a bundle of Cedar. That they are going to use for flooring. The "lumber" measures out at a whopping 3/8" thick with tongue and groove that are about 3/16" thick surface planed and sanded. 2 and 1/2" wide random length with nothing over 2' long. My jaw was scraping the ground. You're not seriously using this for flooring I remember saying. Yep we are her husband replies. He has put it down and it looks good but we shall see how it holds up. It takes all kinds!  ::)
Just an ole farm boy takin one day at a time.
Steve
Offline thecfarm
Re: Sawing Too Thin
« Reply #69 on: April 22, 2017, 06:16:47 AM »
The cedar here would not last long.
I can see 1/2 inch cedar for a liner for a closet. Would want something behind it too.
Online kelLOGg
  • Still learning more than I'm teaching
Re: Sawing Too Thin
« Reply #70 on: April 22, 2017, 08:07:11 AM »
I planed hickory to 3/4" and planned to have it T&Ged for flooring in our house. I took it to a local woodwork shop that said their process required planning and T&Ging in one step. GLUP! I didn't know this. I accepted it at 9/16" and installed it with backer board under it to match the level of existing flooring. It looks great after 10 years. For subsequent flooring I saved a step and omitted the planing.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
comparing thin kerf sawing to circle saw sawing
Started by postville on Sawmills and Milling
Last post March 18, 2011, 08:40:49 PM
by northwoods1
Sawing Thin Strips
Started by Ga Mtn Man on Sawmills and Milling
Last post April 28, 2014, 09:58:21 AM
by Cedarman
suggestions for sawing thin
Started by Raym on Sawmills and Milling
Last post November 03, 2017, 08:19:20 PM
by opticsguy
Best sawing process: thick & slow or thin & fast?
Started by SawyerBrown on Sawmills and Milling
Last post February 15, 2014, 08:25:25 AM
by Peter Drouin
