Last head motor noise
Started by bugdust, September 29, 2016, 06:27:13 AM
bugdust
I recently replaced the motor that raises and lowers the head on my LT40. After installing the new motor I've noticed the head reacts much faster, which I like, but the noise has increased when operating the motor, before the old motor was quite. I was wondering if this is normal with the newer replacement motors.
Since I retired I really like work: It fascinates me. I can sit and look at it for hours.
MartyParsons
Hello,
  I would remove the belt then run the motor, see if the noise changes. What year is the mill? Can you post a picture? It is hard for someone to describe a noise and tell if it is normal.  :-\
Marty
drobertson
Another possibility could be the end cap is interfering with the plastic fan?
bugdust
Problem solved! At Marty's suggestion I began removing the belt from the motor and I found the pulley set screw was loose on the the motor shaft. Even though it was tight enough to raise/lower the head it was slipping on the shaft. Tighten set screw and good as new. Thanks for your responses ... thanks Marty.
