Author Topic: Portable solar kiln in progress.  (Read 2505 times)
Offline Delawhere Jack
  • I ought to know better.....
« on: October 16, 2016, 08:47:40 PM »
I mentioned this idea a little over a year ago here on the FF. Finally getting it done. Basically the Virginia Tech design with some slight modifications. Shortened the north wall about 1 foot to avoid clearance issues while on the road. There will be three doors on the north wall for loading, each 4 feet wide that will be lifted out for loading. It will accept 12' max material, and hold about 1,000 bf.
Offline GeneWengert-WoodDoc
Re: Portable solar kiln in progress.
« Reply #1 on: October 17, 2016, 06:38:44 AM »
Looks really fine indeed.  One question...do you have a small door so you can get in to inspect and check the lumber during drying?
Offline AnthonyW
  • Wannabe hobby sawyer
« Reply #2 on: October 18, 2016, 09:43:29 PM »
Delawhere Jack: I see you are building on a single axle landscape trailer. I would estimate a 2500 or 3750 axle capacity. Have you estimated the weight of the kiln and of the lumber placed in it? Even 1000 bdft of green white pine is estimated to weigh 3000 pounds, and that does not include the weight of the kiln.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
« Reply #3 on: October 19, 2016, 05:24:07 PM »
Gene, Yes, there will be a small door, about 20" x 40" on the west wall adjacent to the north wall.
« Reply #4 on: October 19, 2016, 05:27:33 PM »
Delawhere Jack: I see you are building on a single axle landscape trailer. I would estimate a 2500 of 3750 axle capacity. Have you estimated the weight of the kiln and of the lumber placed in it? Even 1000 bdft of green white pine is estimated to weigh 3000 pounds, and that does not include the weight of the kiln.
Anthony, the combined kiln and trailer should come in around 3,200lbs. The axle is rated at 3,500. There will be jacks at all four corners, and it will not be moved while loaded.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #5 on: October 19, 2016, 10:22:56 PM »
I like this concept.  I will watch this thread to see how it goes.  keep up the good work and also keep the pictures coming.
1992 LT40HD
« Reply #6 on: October 21, 2016, 07:50:58 AM »
A stickered load of freshly sawn oak weighs more than 6000 pounds per MBF.
Offline Darrel
« Reply #7 on: October 21, 2016, 11:49:39 AM »
I am thinking, that much weight on this trailer would require more jacks than just the four corners.  The springs and axel won't support enough of the weight and the trailer will sag in the middle.  I'd also put jacks forward and aft of the axel.
1992 LT40HD
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #8 on: October 21, 2016, 04:38:28 PM »
Now you can dry wood going 70 mph down the Interstate.
« Reply #9 on: October 22, 2016, 07:13:54 AM »
You also need to add the weight of the stickers and other wood, such as 4x4.  You also need a roof that can withstand 70 mph, which means the normal construction techniques must be modified.
Offline thecfarm
« Reply #10 on: October 22, 2016, 08:56:23 PM »
Take all back roads,35mph tops.  :D That is half as fast.
« Reply #11 on: October 22, 2016, 10:17:21 PM »
I appreciate all of the observations, and I know this is "pushing the envelope" on kiln design. If worse comes to worse, this one will end up as a stationary kiln. It has occurred to me that a smaller model may be more practical. But I'm forging ahead with this. I am certainly keeping highway speeds, overhead clearance and loaded weight in mind.
Hope I don't end up with a Spruce Goose!!  :o
« Reply #12 on: October 26, 2016, 10:34:19 PM »
Slowly coming together. I've been sidetracked with lots of milling work and replacing my furnace lately, but have made some good progress the last few days. Rafters, polycarb panels and ridge cap installed. Still need to sheath the west wall and build doors.
Offline Darrel
« Reply #13 on: October 27, 2016, 12:16:21 AM »
Looking good!
1992 LT40HD
« Reply #14 on: October 30, 2016, 09:14:21 PM »
West wall sheathed, east, west and south walls insulated and interior sheathing installed. Exterior all primed. Have tarps covering the north wall door opening, and the man-door in the west wall due to thunderstorms this evening.
While insulating and installing the interior sheathing this afternoon, the kiln was facing south-west. Boy it gets warm in there!  :D And that's with the north wall door opening wide open.
Got to admit, there are a lot of things I've done stupidly in building this.  smiley_whacko
I really should have built the kiln on the ground and then placed it on the trailer.
My framing skills grade a D-.  :-[  (luckily it hasn't cost my too much lost material).
I should have primed and painted the sheathing before installing it. It's a real pain in the butt trying to paint around the side rails of the trailer.
No major foul ups, but a lot of wisdom in hindsight.... I'll get some more photos tomorrow. It was getting dark when I wrapped up today, and all I wanted to do was get home and shower off the fiberglass insulation dust.  bath_smiley
Offline thecfarm
« Reply #15 on: October 30, 2016, 09:34:12 PM »
As I always say,you need to do something twice to know how to do it the second time.
« Reply #16 on: November 02, 2016, 05:47:15 PM »
I blame my hubris... Seem to have more than my share at times... Think it's a genetic thing.  ::)
« Reply #17 on: November 02, 2016, 05:57:19 PM »
It's coming along. I've been so busy milling lately I haven't had much time to work on it. Anyway, exterior primed and painted. Will need a second coat. East, west and south walls insulated and sheathed on the inside. Put the first coat of paint on the exterior today after milling a small job. At 2pm it was well over 100 degrees inside, with just tarps loosely covering the door openings. It was 68-70 outside.
« Reply #18 on: November 10, 2016, 08:05:56 PM »
The build is coming along. The north wall doors are built, fan plenum and fans installed, and the inside sealed with foundation coating. Will get some more pics soon.
A couple questions:
What are you other solar kiln guys using for baffle material? I looked into getting used retractable awning (Sun Setter type awning) fabric. Talked to a guy who installs them, but he said they're done for the season, and they throw the old ones out.
I'm thinking of making something like a roller shade blind on the outside that can be extended over the collector to adjust collector size for smaller loads. Has anyone done something like this?
Photos are worth a thousand words. ;)
Thanks. John.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #19 on: November 10, 2016, 11:03:47 PM »
I used a dark green tarp for a baffle, attached at the bottom of the wooden fan deck, and draped down over the wood stack.  It's been going strong for many years and I wouldn't want to use anything else, except maybe a black canvass one.
I wouldn't worry about the smaller loads, if you think things aren't right and you are getting too much heat, the easy solution is to just open the vents more to cool the inside off.  I've even cracked the door open some, a solar kiln is extremely forgiving.
HobbyHardwoodAlabama.com
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
Solar Kiln Build Progress
Started by Woodslabs on Drying and Processing
Last post July 29, 2015, 05:17:24 PM
by CaseyK
Portable solar kiln?
Started by Daren on Drying and Processing
Last post March 25, 2005, 10:38:41 AM
by Daren
First charge loaded in the portable solar kiln.
Started by Delawhere Jack on Drying and Processing
Last post March 14, 2017, 03:27:59 PM
by WDH
