Author Topic: Just Getting into Sawmilling! How to market wood? What Market?  (Read 862 times)
Offline Ohio Logger
« on: November 01, 2016, 08:01:15 AM »
Hi you all! I have a small half home built band mill that I have used for myself and a few friends the last 5 years. I would like to start using it more and work toward upgrading the mill in the next several years. I would like to try to market specialty and character grade hardwood along with supplying pine lumber for a variety of uses. In my area (northeast OH) there is not much pine and so there are very few mills that cut it. Any advice on how to cut  logs for the specialty/slabs or character grade market? Also, I would like to cut pine for stock, but I am not sure what size of boards to cut for fear I won't have a market for it. (I have nearly 10,000 bd ft of pine logs that will need cut in the next year to minimize waste.) I would welcome any thoughts or comments you would have. Thanks! P. S. I will try to post a photo of my mill today or tomorrow.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Just Getting into Sawmilling! How to market wood? What Market?
« Reply #1 on: November 01, 2016, 08:20:08 AM »
Just my $0.02 ...
Cut what you can't buy... Timbers or very wide boards.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline ozarkgem
  • age 65 yrs old
« Reply #2 on: November 01, 2016, 06:17:33 PM »
start advertising that you have pine custom cut to customers specs. List a few odd sizes just so  they know you can saw anything. ad  3x5 3x8  whatever . You don't have to saw them till they order. maybe saw some things for pictures.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: November 01, 2016, 10:49:54 PM »
   Advertise where your target audience will see it.
   My cheapest and an effective technique is homemade half sheet flyers starting with "Got Logs - Need Lumber?" then a couple of paragraphs describing what I can cut. I print these 2 to a sheet on my home printer and post them in local feed stores, hardware, auto parts stores, and especially in local convenience type stores on their community service boards. Keep a stack of them in your truck and a handful of push pins to put them up with. I have to replace them frequently when I stop by as the store owners periodically purge their old flyers or potential customers rip them off rather than writing down the contact info. They are dirt cheap and work.
   A magnetic sign on your vehicle and/or mill (if portable) works well. Parking your mill (if portable) where it can be seen works well too.
   If I see a stack of logs I stop and talk with the owner and if nobody is around leave a business card in a small ziplock bag pinned to the end of the log. Often the guy wants them milled doesn't have a sawmill lined up.
    Contact you local tree service people and give them plenty of business cards to pass out to customer who may want to save a special log they cut. Also be sure to refer the same tree service people to customer who want you to cut trees for them (unless this is a service you provide to - I don't. I tell them I saw logs into lumber but they need to get a professional arborist to get dangerous trees on the ground).
    Talk up your business at every community event and demo where you can. Good luck.
   Another technique is take a load of sample wood products (lumber, fireplace mantels, tomato stakes, slabs, etc.) to your local flea markets and hand out business cards and price lists and talk with anyone interested in wood working or wood products. You will get calls many months later from this.
Offline Ohio Logger
« Reply #4 on: November 03, 2016, 07:58:19 AM »
Thanks for the ideas. Gives me some food for thought. i will try to post some photos this eve. I am planning to cut some pine today.
Fire wood market
Started by Peck on Forestry and Logging
Last post February 19, 2004, 02:41:32 PM
by rebocardo
how is the pulp wood market in the lake states
Started by snowstorm on Forestry and Logging
Last post February 28, 2015, 01:44:24 PM
by BHC
Need a market for this
Started by woodhick on Drying and Processing
Last post November 04, 2005, 07:50:52 PM
by rebocardo
in the market for....
Started by snaponman1526 on Chainsaws
Last post February 03, 2010, 02:42:25 AM
by Ianab
