Arborwear
Author Topic: LED Lights on a Sawmill  (Read 4435 times)
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: LED Lights on a Sawmill
« Reply #40 on: December 07, 2016, 06:28:39 PM »
Funny this should come up again as we were looking at it today.  We were thinking to just grab battery power from before the starter solenoid, and have a switch right there next to it.  I was trying to figure out where I should mount the lights for the most optimal placement.  I really like those you posted, Marty.  Good stinkin!
Boy, back in my day..
Offline 47sawdust
« Reply #41 on: December 08, 2016, 09:50:53 AM »
The strip lights on the mill pictured...anybody have a source?How are they attached?
Mick
Offline DDW_OR
« Reply #42 on: December 08, 2016, 01:46:23 PM »
just search for "led 12v strip lights"
attachment is by screw, or glue, or double sided tape. the key is to dissipate the heat generated by the LED's
side note: i converted my desk swing arm magnifying lamp to LED. here is where i got the LED ring from
http://www.ebay.com/itm/Super-Bright-5730-SMD-LED-Panel-Circle-Annular-Ceiling-Light-Fixtures-Board-/151657510448?var=&hash=item0
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Turbosaw 26EX, Hakmet Arbro 400 stroke harvester, BrushHound 30EX
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #43 on: December 09, 2016, 06:17:43 AM »
Hello,
  The owner is from Virginia. I asked him the same question about the source. He has a business and the guy just stopped in. He wanted him to try them.  I will see if I can get more info. The LED lights looked like they had a adhesive on the back. So they were just stuck on. The one on the mast was very very thin. Again I thought it was a sticker you could hardly feel it. I would think these lights would be very low amp draw.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline 47sawdust
« Reply #44 on: December 09, 2016, 08:17:51 AM »
Global Industrial Sales has them.The brand name is Truckstar Led strip lights.They have a variety of the lengths.I ordered a 24''and a 48'' length to mount on my LT30.
The 24 was $23.00,the 48 was $37.00.They are no doubt cheaper elsewhere but I like the peace of mind buying from folks I know.The lights are adhesive backed as well as include clips and screws.
 Marty thanks for your post,as always,we learn something new and useful.
Mick
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #45 on: December 09, 2016, 08:31:52 AM »
Offline btulloh
« Reply #46 on: December 11, 2016, 10:42:41 AM »
Someone gave me a couple 5 meter rolls of the LED strip lights that look very much like the ones on the mill.  They came from ebay and were about $15 a roll.  Cheap.  These were 30 lumens per LED, so a 1 ft strip was about the same as 60 watt equivalent LED bulb from your local store, but only pull about 250 -300 ma.  They are adhesive backed and be cut to any length you want.  I've used some here and there and they make a pretty good and cheap solution for some odd situations.  I may even try using some in a 4 tube ceiling light instead of replacing the bad ballast.
There are a lot of different offerings, so you need to pay attention to things like color temperature and output to get what you want.  They also come in a weather proof version, which means there inside some tubing with the ends sealed.
HM126
Offline Brad_bb
    • My timberframe blog
« Reply #47 on: January 27, 2017, 12:48:56 AM »
This LED light bar on my forklift mast is great!!!  Turns night into day!
Offline 4x4American
    • Website Link
« Reply #48 on: January 27, 2017, 07:23:54 AM »
Got mine on the other day
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #49 on: January 27, 2017, 04:30:34 PM »
I like it, it gives plenty of light!   8)
~Chuck~
I LOVE MY SAWMILL
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #50 on: January 27, 2017, 05:05:06 PM »
I like it too.  Bet there will be UFOs reported in your area soon.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline DDW_OR
« Reply #51 on: January 27, 2017, 06:37:50 PM »
Ultimate Forestry Optics
or
Ultimate Forestry Obeliscolychny
obeliscolychny = lighthouse
http://phrontistery.info/o.html
Offline LulaNord
  • Member*
« Reply #52 on: May 16, 2017, 01:30:40 PM »
Hi...i am a new user here. In my case i used to saw under flood lights and I put 4 lights around the mill pointing right to the center.  Doing this I eliminated most of the shadows that the head, log and myself caused. It was easy to move the lights where needed but if you're looking for mounting on the mill.
hdi pcb
Offline ChugiakTinkerer
« Reply #53 on: May 16, 2017, 09:44:22 PM »
Welcome to the forum LulaNord!
Woodland Mills HM130
Night Maneuvers - Lights on Sawmill
Started by UpInATree on Sawmills and Milling
Last post September 17, 2011, 07:17:49 AM
by sherpa
Sawmill Trailer Lights Stopped Working...a Day in Purgatory
Started by Ga Mtn Man on Sawmills and Milling
Last post April 22, 2017, 06:07:08 AM
by ToddsPoint
question
LED Lights?
Started by sandhills on General Board
Last post May 31, 2017, 10:27:39 AM
by trapper
Uh Oh...Now, I have lights
Started by tcsmpsi on Sawmills and Milling
Last post January 29, 2007, 12:04:17 PM
by Robert Long
