Author Topic: Starting a mill build... slowly  (Read 2284 times)
Online Revival Sawmill
  • Still Learning.
« on: November 21, 2016, 04:48:04 PM »
I've been lurking here for a while, joined a couple of days ago and have been shamelessly picking your collective brains for information about building portable bandsaw mills.  I'm starting to gather materials for my first build, and thought I'd start posting progress here in case anyone is interested!
Wheels, bearings, blade guide wheels, zerk bolts, and three 'on-sale' hydraulic motors from Cook's saw
70' of 7"x14"x3/8" H-beam from the local scrapyard that I'm planing to turn into the trailer/deck
Got two of these RR power units as prospective power sources for the mill.  Since they aren't currently running, and I have no idea about specs or horsepower, I'm not sure they'll work.  If I go this route, they have big hydraulic pumps on them so I may be able to power the wheels hydraulically.  I may end up putting an electric motor on it, and powering it with a separate 3-phase diesel generator. I'm thinking that would make the headrig lighter and I might be able to put the angle-iron track on the outside upper surface of the lower flange, instead of top dead center of the upper flange, and make the headrig carriage less long so I can cut longer logs on the same size trailer. Still figuring that part out.  ;D
Bunch of 3"x3"x3/8" square tubing I scrounged up at the scrapyard.  I'm hoping these'll work as the bunks on the log-deck once I scrape the asbestos or whatever that white junk is off of them...
That's all for now.  Sorry this is going to go so slowly!
Thanks,
Offline york
Re: Starting a mill build... slowly
« Reply #1 on: November 21, 2016, 05:02:10 PM »
Wooddust please try to keep it all in one thread,with out a doubt ,will be watching this build and good luck...
Albert
Offline fishfighter
« Reply #2 on: November 21, 2016, 05:54:30 PM »
Watching. Love things that people build. ;D
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #3 on: November 21, 2016, 06:18:28 PM »
Slow is good...some of us aren't the fastest readers. :D  Looks like it's going to be a heavy-duty mill.  Looking forward to following along.  I see you're in western NC.  What town are you near...I might be close enough to come take a look sometime.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline bedway
« Reply #4 on: November 21, 2016, 06:41:09 PM »
Since I built my own mill and it has been a work in progress ever since ill be watching your build closely. If I can be of any help feel free to yell. I might not have all the answers but im a good listener.
Offline ozarkgem
  • age 65 yrs old
« Reply #5 on: November 21, 2016, 06:44:00 PM »
are the wheels for  1 1/2" bands?
Offline btulloh
« Reply #6 on: November 21, 2016, 08:07:11 PM »
Very interesting.  I'm looking forward to following your progress.
HM126
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #7 on: November 22, 2016, 10:53:42 AM »
 :P popcorn_smiley
  • Still Learning.
« Reply #8 on: November 22, 2016, 11:26:34 AM »
We're about halfway between Asheville and Boone - once I've  made some progress and there's something worth looking at, that might be good!
Thanks,
  • Still Learning.
« Reply #9 on: November 22, 2016, 11:27:13 AM »
2" band, 30" wheels
Offline larrydown60
« Reply #10 on: November 23, 2016, 09:27:40 AM »
Watching, good luck with your build. Good things take time, mine looks like it might it be spring before I can finish it. It will be 2 years in April.
  • Still Learning.
« Reply #11 on: November 23, 2016, 05:20:52 PM »
Got the big V-groove casters to run the carriage back and forth on today!
Got 8 of them on Amazon, 6" tall, 2" wide, rated for 1200#s, greasable. I'm trying to keep the headrig and carriage under 5000# combined, so I think they should work.  Three of them arrived with some damage to the bearings, but the seller is sending me new bearing parts and explained how to swap them out! That leaves me 7500# to play with on the trailer/deck before I start having towing issues from weight.
I measured the H-beam more carefully today, and it looks like it's actually 6.75"x14", so I'll have to redraw a few things before any welding happens.  There are two pieces 248" long, one piece 247" and a short 11' one.  I'm thinking now to make the trailer 24' long, cap weld another piece of the same Hbeam across each end buying me another 13.5" of track, and leaving enough scrap to weld two 71&5/8" pieces horizontally at the bottom of the frame at 1/3 and 2/3 of the length.  I think that by turning these two pieces on their sides, they should stay low enough not to interfere with the log bunks or clamp/stop stuff.  I'm hoping the one 2/3 of the way back will be lined up on the tandem axle to help stiffen that area.
I've contacted the power company about running service out to the barn we're building so I can take care of the welding myself; otherwise I'll have to cut/prep most of this stuff and drag it all the way to town and hire the welding out :(
Snagged a 50hp 3-phase motor today too, in case the diesel doesn't work out.  Still thinking to use the hydraulic pump to engage the wheel and run the carriage transit and headrig elevation control stuff.
I've asked about hydraulic elevation control vs acme thread in another post, and despite encouragement to use the hydraulic/chain system, I'm still leaning a bit towards the acme thread since I 'trust' it a bit more, and I can already visualize how to use one of the three hydraulic motors I got from Cook's to spin the nut on them, without right-angle drives or worrying about the headrig coming loose and smashing to pieces on the deck...
Thanks for following along! Please pipe up if you think/know I'm making a mistake somewhere!
  • Still Learning.
« Reply #12 on: January 09, 2017, 01:04:29 PM »
Progress is intermittent at best.  I've switched the design to use the 50hp electric motor to drive the mill, and have been working on getting a 3 ph diesel generator to keep it portable. Unfortunately the best prospect for a generator fell through, and I totaled my truck on the way home from not picking it up :( .  Now it's looking like this thing is going to be stationary at first, and I'll have to add axles and a tongue to it sometime later. My next project is sorting out the hydraulics for the deck - to rotate/tilt/clamp the logs.  I have a 'spare' 25 hp electric motor that I was considering running a hydraulic pump off of, but it seems like overkill.  Most of the electric hydraulic power units I'm seeing online are only 5-10hp?  Anyone have any guidance about how much hp I need for the hydraulics on the deck?
Thanks,
Offline Rougespear
  • Salmon Arm, British Columbia
« Reply #13 on: January 09, 2017, 01:27:12 PM »
3-6 GPM seems to be about what most mills are using.  Depends on your desired cycle speeds.  A 3hp electric motor should do well enough for sure.
Custom built Cook's-style hydraulic bandmill.
Offline Kellyj
  • I'm *DanG new!
« Reply #14 on: January 13, 2017, 09:59:55 PM »
Where did you get your 30" band wheels from?
Many projects started, few finished.
Offline ozarkgem
  • age 65 yrs old
« Reply #15 on: January 14, 2017, 05:53:11 AM »
a 10 hp hydraulic power unit will be more than enough.
  • Still Learning.
« Reply #16 on: January 14, 2017, 07:37:04 AM »
Cook's
  • Still Learning.
« Reply #17 on: January 14, 2017, 07:38:27 AM »
Have a 5 hp hydraulic unit in order; if that doesn't do it, I'll go up from there😈
Thanks for the guidance!
  • Still Learning.
« Reply #18 on: October 12, 2017, 04:09:16 PM »
Anyone know why most mills use a chrome shaft with a bushing-type-thing for the saw head to run up and down on?  Why not more v-groove wheels and a piece of angle welded front and back of the carriage, sort of  like they use on this one:
 you can get a good view of the vertical v-groove wheels around 33 seconds into the video.  Are there problems with sawdust/chips getting in between the wheels and tracks?
I was considering using two vertical v-groove wheels on the front of the carriage on adjustable mounts and one fixed one on the back of the carriage - then I could use the adjustments on the v-groove wheels to 'tilt' the blade up or down in relation to the bed (the cooks videos say to have your blade tilted down a couple of degrees for some reason?).
Thanks for any answers/input!
Offline lbjordal
« Reply #19 on: October 18, 2017, 05:46:31 AM »
Good too see that your still building.
I have plans for a mill using pretty much the same Cooks parts as you.
I think the reason for using chrome shafts and bushings as guides is simplicity (no rotating parts or bearings)
Starting My homemade bandsaw mill build
Started by Kwill on Sawmills and Milling
Last post May 22, 2016, 05:37:32 PM
by Kwill
Hi All Starting Band Mill Build Couple Questions OKAY more than a couple
Started by biggkidd on Sawmills and Milling
Last post August 01, 2014, 11:56:25 PM
by biggkidd
Starting on a Shed Build
Started by davis555 on Timber Framing/Log construction
Last post August 02, 2014, 11:32:07 AM
by Jim_Rogers
Starting my sawmill build
Started by Splintershack on Sawmills and Milling
Last post March 08, 2017, 09:39:24 AM
by Splintershack
