Arborwear
Author Topic: Doug Fir vs White Fir identification  (Read 687 times)
Offline JRWoodchuck
« on: November 30, 2016, 01:38:42 PM »
I live in Eastern Oregon and primarily cut Western Larch for firewood. Occasionally Doug Fir. But I don't know Doug Fir well enough to identify it over White Fir and don't like cutting trees down that I don't need to. So my question is, is there any distinct ways to tell them apart when dead and standing. Once I cut one down I know almost as soon as I start cutting it. But they look similar to me prior. Thanks!
Home built bandsaw mill still trying find the owners manual!
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
Re: Doug Fir vs White Fir identification
« Reply #1 on: November 30, 2016, 03:01:17 PM »
Dead and standing, that's a tough one.  Green, piece of cake.  If the tree has only been dead a year or two, there might still be needles, maybe.  Telltale sign in a dead WF could be the branching, or lack of in the tops(WF usually die topside and move down), and cluster branching mid section.  If the bark is coming off toward the top, it is definitely whiter looking than DF.  You say you know almost immediately when you start cutting it on the ground.  Not the safest for the next person, but you could put a cut into the tree and look at your saw chips. Once you get past the outer layer, the heartwood of a DF is most assuredly darker.  Trunk bark for the two can look similiar, especially if growing in the same stand.  Hope this helps.
Offline JRWoodchuck
« Reply #2 on: November 30, 2016, 03:18:41 PM »
Thanks Brad, When I start cutting I always finish cutting a tree down just to make sure that no freak accidents happen to someone else. I really don't like cutting trees down that don't need to be cut. I just wasn't sure if there was some tell tale ways of picking one out over the other. Thanks again.
Red & White Oak Identification
Started by Tom on Ask The Forester
Last post December 17, 2001, 12:43:12 PM
by swampwhiteoak
recycled
Need about 20,000 bd ft of doug fit
Started by pegs1 on Wanted
Last post February 27, 2007, 08:49:43 PM
by oakiemac
Red Needles on Doug Fir
Started by cloudcap on Tree, Plant and Wood I.D.
Last post June 25, 2009, 05:18:45 PM
by SwampDonkey
Doug fir siding?
Started by bman on Timber Framing/Log construction
Last post December 08, 2005, 01:14:14 PM
by solodan
