Author Topic: Nyle kilns  (Read 1112 times)
Offline C0ke
Nyle kilns
« on: November 30, 2016, 06:53:58 PM »
First I would like to say if this post is not supposed to be in this forum please delete it and I apologize.
Now with that out of the way, I have a timber king saw mill and we purchased a property that has a Nyle L300 Kiln (I believe made in 1997). I cut wood but don't have use for a kiln. The kiln was working up until about 7-8 years ago when we bought the property and shut the power off so it hasn't been in use since then. I was looking to sell it but I have no idea what it is worth used. I contacted Nyle and they said they are worth about $17,000 USD new plus shipping and taxes. Could someone give me a ball park what this thing would be worth used? Would there be any way I could test it (hook it up to a generator or something?) it has these power vents that must open and closed the vents too. What would they be worth? Thanks for the help.
Again, if this post isn't in the right place please delete it.
Thanks.
Offline redprospector
Re: Nyle kilns
« Reply #1 on: November 30, 2016, 08:32:27 PM »
The value of any given item is what the buyer, and seller agree on. Anything else is just an appraisal, an evaluation, or maybe even a guess.
I don't see any reason why you couldn't try it with a generator, if it is sized to meet the electrical requirements of the kiln. Most of the stuff I buy, I buy used. If a piece of equipment hasn't been used in a year or so, and there's no way to test it I won't give much because you just have to assume that it's going to need some work to get it going. How much work is anybody's guess.
So, all that said my suggestion would be to get it running, and advertise it as a working unit, or be prepared to take next to nothing for it. Just my 2 cents.
Online GeneWengert-WoodDoc
Re: Nyle kilns
« Reply #2 on: December 01, 2016, 07:33:58 AM »
Because compressors that are idle deteriorate (seals dry out as they are not lubricated, for example), and because recent compressors are better than 20 year old ones (Involving the refrigeration fluid, for example), and new units have better controls, the value of a non-working unit is very small.  On the other hand, repairs are easy as any refrigeration person can work on these units and the 300 is open enough that it is easy.  But if repairs are needed, the cost is high.  Then, there is the cost of repair to the two heat exchangers and piping, if needed.  Even if they are ok now, the exchangers do not last forever and replacement, including new gas, is high.  The bottom line is that this unit has very small value if you were to use it or if you sell it.
Is there a non-profit wood working organization nearby that would like a kiln?  Donate it to them (after you get it working) and take a tax deduction.
Offline C0ke
Re: Nyle kilns
« Reply #3 on: December 01, 2016, 06:05:20 PM »
Thanks for the replies. No non profit by me.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Nyle kilns
« Reply #4 on: December 02, 2016, 07:48:10 AM »
The only way to asses the value would be to get it operational again to measure performance, refrideration pressures, confirm if the fans, contactors, sequencers, controls, safety switches, etc work.  These are specialized but relatively simplistic systems, but they do have a predictable useful life, and as stated they have wear when they operate, and also deteriorate when they are idle.  I know from experience that some of the Nyle hardware is pretty specialized and expensive from a component standpoint, and I had to pay more for a replacment evaporator coil than I did for an entire compressor.  They are easy to work on, but like any refrigeration system, expensive to service unless you do it yourself.
HobbyHardwoodAlabama.com
Offline Den Socling
  • just wondering
Re: Nyle kilns
« Reply #5 on: December 02, 2016, 09:47:40 AM »
Maybe a vo-tech school would like it as a project. Like everybody says, it's been sitting too long to have any value and if you invest the money to get it operational, you might have a hard time getting it back. It's pretty old.
Offline Brad_bb
    • My timberframe blog
Re: Nyle kilns
« Reply #6 on: December 07, 2016, 11:22:49 PM »
If you mill wood, then you may decide it would be nice having one eventually.  I never thought I would need one, but now it would be good.  I have reclaimed wood that I'd like put in a kiln to kill any Powder Post Beetle (PPB) larvae.  I also want to make some flooring and it would be nice to throw my air dried wood in a kiln before making the flooring.
Offline jzahrt
  • Burson St. Barnwood
Re: Nyle kilns
« Reply #7 on: January 23, 2019, 04:40:39 PM »
Do you still have access to the manual and wiring diagram?
Burson St. Barnwood. Barn dismantling, and learning how to do bugkills
Nyle L50 vs Nyle L200
Started by nanook on Drying and Processing
Last post October 21, 2007, 08:55:24 PM
by David Freed
Looking for Dh/vac kilns in va or near
Started by Bnewman712 on Drying and Processing
Last post October 28, 2018, 10:20:09 AM
by DR_Buck
Vac Kilns Again
Started by DragonsBane on Drying and Processing
Last post January 09, 2006, 03:02:33 PM
by Den Socling
Are kilns Always necessary?
Started by Rod Yowell on Drying and Processing
Last post November 02, 2013, 06:54:04 PM
by GeneWengert-WoodDoc
