Arborwear
Author Topic: What tree is this?  (Read 2558 times)
Offline ray299
What tree is this?
« on: December 02, 2016, 01:33:16 PM »
It's got a pine like bark, no sap, not really any smell to it but looks like a dark maple grain... anyone know what it is? Just for ha has I sent the board on the right through the planer.... they werr milled only a couple days ago.
Offline Black_Bear
  • UMaine Black Bears
Re: What tree is this?
« Reply #1 on: December 02, 2016, 04:07:47 PM »
Looks like black cherry (Prunus serotina).
Offline catalina
  • Its a dogs Life!
« Reply #2 on: December 02, 2016, 04:29:24 PM »
without any doubt Black Cherry.
Offline dchiapin
  • TK B-20
« Reply #3 on: December 02, 2016, 04:39:26 PM »
yes Black Cherry
Offline The Axe Man
« Reply #4 on: December 02, 2016, 06:25:22 PM »
Yep. Black Cherry.  :P
Offline Ron Scott
« Reply #5 on: December 04, 2016, 10:04:55 PM »
Yes, to black cherry.
~Ron
Offline Canadiana
  • I was new a while ago
« Reply #6 on: December 05, 2016, 01:30:33 AM »
Sounds conclusive. What are the signs/features that you see? Good pic
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
Offline ray299
« Reply #7 on: December 05, 2016, 07:59:56 AM »
Nice, thanks all- I didn't even know we had a black cherry tree in the yard... I'll have to pay attention to the smaller one I left.. this one was only cut down because the top was damaged and it started rotting.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #8 on: December 05, 2016, 09:01:03 AM »
The scaly bark is diagnostic.  Also, the light colored sapwood and the pink heartwood.  Turns red when exposed to sunlight.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #9 on: December 05, 2016, 11:35:30 AM »
Seal the ends of your logs/boards.  Black cherry likes to check, especially through the heart/pith.
Offline ray299
« Reply #10 on: December 05, 2016, 05:04:53 PM »
Even after its milled? Or seal the ends as is sits in log form? Also, what's a good way to seal it in regards to the most economical way? I don't want to spend $100 on a bucket of sealer for boards I'm just going to air dry and make small projects out of type of thing... or should I put that in a separate thread?
Offline Ianab
« Reply #11 on: December 05, 2016, 06:56:36 PM »
For one log, you can melt some paraffin wax and paint that on. Not as convenient as the liquid wax emulsion wood sealers, but it will do the job.
Offline ray299
« Reply #12 on: December 05, 2016, 10:17:36 PM »
And if I have a dozen logs is there a better option? Tia
Offline WDH
« Reply #13 on: December 06, 2016, 07:49:11 AM »
For a dozen, that is 24 ends to seal.  With that amount, you should consider buying a gallon of anchorseal.
Offline Ox
« Reply #14 on: December 06, 2016, 01:13:13 PM »
Easier to seal the log ends first.
I've used old paint with good results, as have many.
It's important to seal the ends of the wood grains so they don't act like little straws siphoning moisture too fast out the end of the log/board.  Use your imagination as to what would work.   :)
Waxy emulsion seals.  So does most paints.  Most paints aren't "breathable".
I just know when I paint wood and it gets wet, it beads up and doesn't let water through to the wood.  Works the same on the ends, too.
The last batch of black cherry I milled I used old spray paint on the ends.  Just one heavy coat.  Very minimal checking, if any at all.  1 1/2 years ago.
Offline ray299
« Reply #15 on: December 10, 2016, 07:57:48 PM »
Worth a try... I've had logs mainly ash 20-30 ft long sitting dry. I've cut sections as needed and sacrifices to first 18-20 inches but my fresh oak Im dropping is to heavy to move in such long lengths. I got plenty of old paint. I'll give it a shot. Thanks!
Offline Ox
« Reply #16 on: December 10, 2016, 09:21:00 PM »
With paint, make sure you slice a little thin cookie off the end of the log so your blade doesn't have the chance to drag paint through your nice new lumber.  ;)  This is another reason to cut the log at least 6" longer than the boards you want out of it.
Offline WDH
« Reply #17 on: December 11, 2016, 07:47:15 AM »
Compared to anchorseal, paint is a mediocre end sealer.  Think about the time you spend end sealing.  If you spend a lot of time like I do end sealing, you want the best result for your time and money.  If you are only doing a few logs here and there, and if you double coat, you might do OK with paint.  Maybe I used inferior paint when I first started out using paint  :).
Offline Ox
« Reply #18 on: December 11, 2016, 09:45:50 AM »
I've used old spray paint mostly.  I wonder if this has anything to do with my good results?  I can spray thick and watch it suck right up into the wood like a wick.  I don't remember it doing that with the paint on latex/acrylic stuff.  I wonder if this is something that makes a world of difference?
I remember hearing about roofing tar thinned with some kerosene or something similar.  I bet that would seal great, but I sure wouldn't want the mess associated with it.
Offline WDH
« Reply #19 on: December 11, 2016, 11:52:22 AM »
I have used the aluminum roofing paint called Kool-Seal from Lowes.  Makes an awful mess.  If you get it on your clothes or shoes, you wear it for life.
sad
Bushfires Australia story featuring video - Tree Cutting and Tree Removal
Started by acetree on General Board
Last post July 24, 2009, 10:15:06 AM
by acetree
20 inch Tree Terminator tree shear with top grapple SOLD
Started by okmulch on For Sale
Last post January 30, 2012, 06:23:40 PM
by okmulch
Oak Tree, Central New Jersey - Tree Identification
Started by joerosa1 on Tree, Plant and Wood I.D.
Last post March 18, 2017, 05:10:41 AM
by plantman
Magnolia Tree Question for all you Tree Experts
Started by DR_Buck on Ask The Forester
Last post June 27, 2015, 08:34:15 PM
by brendonv
