Author Topic: Router Sled  (Read 1947 times)
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
Router Sled
« on: December 16, 2016, 08:53:35 AM »
I have a bunch of Cedar and Walnut slabs that I intend to make coffee tables from. The Walnut needed  some serious straightening. The only way I can do this was to was to make a sled. So this is what I came up with and surprisingly it worked real good for me. bg
br>
Offline FalconFan
Re: Router Sled
« Reply #1 on: December 16, 2016, 09:20:04 AM »
Looks great! I have not seen one made from steel yet, usually see them made from mdf. How wide is the slab?
Offline ljohnsaw
Re: Router Sled
« Reply #2 on: December 16, 2016, 09:41:14 AM »
Here is mine I made last year to flatten a 40" x ~80" cedar slab pair.
Worked pretty well.
John Sawicky
Offline Jemclimber
Re: Router Sled
« Reply #3 on: December 16, 2016, 09:51:43 AM »
Those setups look nice.
ljohnsaw,  were did you get that bit?
Offline ljohnsaw
Re: Router Sled
« Reply #4 on: December 16, 2016, 10:41:21 AM »
I think it was MLCS but I don't see it listed.  you could call them.  My current catalog has a 1" bottom cleaning bit ($16.95) and 1" Dish Cutter bit ($19) with 3/16" rounded edge.  I used a 2" (IIRC) as that was a good balance between size and price.  As you go further up in size, the price climbs drastically.  The flat/sharp corner bit I used would leave a very tiny ridge between passes due to the minuscule error in mounting.  It wasn't perfectly level with the tracks.  However, doing the cedar, my random orbit took it off with a quick pass.
John Sawicky
Offline 21incher
Re: Router Sled
« Reply #5 on: December 16, 2016, 11:50:24 AM »
That is a nice sled. On my list of things I want to build.  How long did it take to flatten that walnut  slab? :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Router Sled
« Reply #6 on: December 16, 2016, 02:42:58 PM »
Wouldn't it be faster and more efficient to make a track like that for a 3.25" electric hand planer...?
Offline Bill Gaiche
Re: Router Sled
« Reply #7 on: December 16, 2016, 09:35:13 PM »
FalconFan, its 24" x 44" long. bg
Offline Bill Gaiche
Re: Router Sled
« Reply #8 on: December 16, 2016, 09:41:23 PM »
21incher, it took about 30 min. per side. I had bought a 1 1/4" straight bit as the place didn't have exactly what I wanted. I ordered a 1 1/2" flattening bit. That will be all my router will pull. This is just a for fun thing anyway. bg
Offline Bill Gaiche
Re: Router Sled
« Reply #9 on: December 16, 2016, 09:46:26 PM »
Delawherejoe. Could be, I don't know. I don't have one of those planes anyway. bg
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Router Sled
« Reply #10 on: December 17, 2016, 06:55:00 AM »
Looks good, But would a power hand planer on a sled work in a of the time?
I don't know, The only sled I made is for a skillsaw to cut off the ends of slabs and things.
A&P saw Mill LLC.
License NH softwood grader.
Offline Don P
    • Calculator Index
Re: Router Sled
« Reply #11 on: December 17, 2016, 10:04:59 AM »
My experience with a hand planer is they can't eject the long chips generated by cross grain cutting, it clogs every pass or two. If you run up and down the track lengthwise it should work but they don't have much power.
Offline OffGrid973
  • Off Grid
Re: Router Sled
« Reply #12 on: February 04, 2017, 07:45:37 PM »
Just use this idea to come up with a sled that is easy to throw together when needed. Buddy welded up the 12" wide rails for me and then I bought two fence posts from depot since they stay square with weather change and used the workbench which is a full sheet of ply.  Thanks for the idea and hope to test tomorrow when I get the right length screw for the new router plate.
Your Fellow Woodworker,
- Off Grid
Router Sled
Started by 123maxbars on General Woodworking
Last post March 15, 2017, 12:33:54 PM
by Darrel
router sled
Started by xlogger on Drying and Processing
Last post April 02, 2017, 10:02:33 PM
by Briankinley2004
Router sled...
Started by Hooterspfld on Sawmills and Milling
Last post May 03, 2019, 08:38:17 AM
by busenitzcww
Router sled
Started by xlogger on General Woodworking
Last post September 12, 2016, 04:20:58 PM
by OffGrid973
