Arborwear
Author Topic: Brace Pockets - Drilling Strategy  (Read 959 times)
Offline Rougespear
  • Salmon Arm, British Columbia
« on: December 20, 2016, 10:45:37 AM »
When drilling brace pockets, I see some maintaining the 45-degree angle while others just bore the entire mortise to full depth.  Rationale on the latter strategy is the grain has already been severed below, as well as it negating the possibility of a brace not seating in the mortise fully because of a conflict along the 45-degree slope.
What's the strategy?
Custom built Cook's-style hydraulic bandmill.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Brace Pockets - Drilling Strategy
« Reply #1 on: December 20, 2016, 11:13:52 AM »
I bore everything full depth unless replicating a scribe rule mortise in restoration.
Offline Rougespear
« Reply #2 on: December 22, 2016, 10:41:37 AM »
Thanks Dave!
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #3 on: December 22, 2016, 11:40:20 AM »
Can you explain what a brace pocket is?
lots of dull bands and chains
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #4 on: December 22, 2016, 12:37:13 PM »
A mortise where the brace end tenon goes into. It is commonly called a pocket instead of a mortise.
Jim Rogers
Offline ljohnsaw
« Reply #5 on: December 22, 2016, 09:25:57 PM »
Jim,
Nice drawing.  Was this used to explain a problem to someone?  I'm just trying to figure out the gap shown at the blue arrow.  Is that just to point out that a gap there is a, relatively, non-issue?  I get the 5 line as the "inner" timber and the dotted line on the brace at the red arrow as the true measure point.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Rougespear
« Reply #6 on: December 23, 2016, 12:47:58 AM »
From what I have read, the gap at the top is a product of square rule joinery.  The brace pocket is cut large enough to accommodate the widest of brace stock (e.g. 6 3/16" when expecting a nominal 6"), leaving a slight gap with the smaller brace members.  Correct me if I'm wrong...
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #7 on: December 23, 2016, 09:04:09 AM »
Yes, there needs to be a place for the variability of the brace timber width. The legs of the triangle as well as the hypotenuse are fixed lines and can't be changed. So the variability has to be on the inside of the triangle.
We make the pocket and the housing larger by at least 1/4" then the length of the brace shoulder so that if the brace timber is oversized as it is rough sawn, then there is some way to compensate for the extra width.
If the stock is wider the brace shoulder length will be longer and if the pocket and housing are cut to the drawing size then the brace will not fit. Doing it longer eliminates the risk of the brace not fitting.
You can size your brace stock and make the pockets perfect if you wish but that is a lot of extra work.
Jim Rogers
Brace tenons and pockets - questions
Started by Preserved on Timber Framing/Log construction
Last post December 23, 2010, 09:02:56 PM
by laffs
moved
MOVED: Marketing Strategy
Started by Jeff on Ask The Forester
Last post May 05, 2015, 09:58:21 AM
by Jeff
Frame raising strategy
Started by srjones on Timber Framing/Log construction
Last post September 26, 2005, 11:26:33 PM
by srjones
Sawing strategy for big butts
Started by Larry on Sawmills and Milling
Last post June 09, 2005, 02:25:54 AM
by Rockn H
