Author Topic: Walnut slab bench  (Read 953 times)
Offline stanwelch
Walnut slab bench
« on: December 22, 2016, 09:28:51 PM »
This is how it started
After a few hours it turned into this
The legs are hard maple. Two coats of tung oil finish.
Merry Christmas to Karen  :)
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader& Forks, Econoline 6 ton tilt bed trailer
Offline thecfarm
Re: Walnut slab bench
« Reply #1 on: December 22, 2016, 09:31:07 PM »
I would much rather you said,Merry Christmas to Ray.  ;D
Offline 123maxbars
    • www.outofthewoodsforestry.com
« Reply #2 on: December 24, 2016, 07:12:40 PM »
nice work!!
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline ljohnsaw
« Reply #3 on: December 24, 2016, 08:26:04 PM »
Very nice.  Curious as to how you attached the top to the legs.  Any pictures from the bottom side?
John Sawicky
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #4 on: December 24, 2016, 10:27:00 PM »
Whoa!  That is a nice one.
Offline newoodguy78
« Reply #5 on: December 25, 2016, 11:28:21 AM »
One of a kind, great job.
I've got some walnut slabs myself. Did you air or kiln dry that slab? And for how long?
Offline 21incher
« Reply #6 on: December 25, 2016, 01:20:44 PM »
Great looking job. I bet she will love it. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline stanwelch
« Reply #7 on: December 26, 2016, 07:07:24 AM »
Thanks everyone.  :)
I attached the top with 6" tenon on each leg with matching mortise in the top.
Glued the joint heavy and angled one screw through the inside of each leg into the top.
The legs are 17" high exposed.  I made a stretcher 4" inches high to fit under the top between the legs but I didn't think it would be needed. If the legs loosen later I'll glue and screw the stretcher to the assembly
Hope everyone had a Merry Christmas  :christmas:
Offline 5quarter
    • Blue Harbor Refinishing
« Reply #8 on: December 27, 2016, 09:55:50 PM »
Merry Christmas Ray... :) :)
Building a Rite Leg Walnut Slab bench
Started by WDH on LogRite Tools and Rite Leg Co
Last post January 21, 2015, 03:10:46 PM
by Tam-i-am
Bench from a slab questions
Started by coalsmok on General Woodworking
Last post April 12, 2015, 09:53:29 PM
by coalsmok
Sycamore Slab Bench
Started by POSTON WIDEHEAD on General Woodworking
Last post April 22, 2012, 10:23:06 PM
by WDH
Santa Brings Slab Bench
Started by Left Coast Chris on General Board
Last post December 28, 2016, 07:02:34 PM
by Klicker
