Arborwear
Author Topic: JD 540 Skidder fan blade removal/swap  (Read 671 times)
Offline Jase
« on: December 23, 2016, 07:43:51 PM »
 Hello,
This is my first post, and I am excited to be here. Long term I am going to be doing some cutting of white birch and beech, to establish a sugarbush, and will have questions for those who have experience.
At the present moment my question is regarding how to get the fan blade out of my good friend's skidder so it can be swapped from blowing forward to pulling air through the radiator and past the fuel filter..
It appears as if taking the fan blade off/out through the top of the hood may be the best option. We took it off today and then put it back on when realizing it would be a fight from start to finish.  He used to have a JD440 and said removing that fan was easy and has done it twice in the last couple of years...
any and all suggestions welcome.. as to how to make this an easy task,
Thanks,
Jase
Offline ohiowoodchuck
Re: JD 540 Skidder fan blade removal/swap
« Reply #1 on: December 23, 2016, 08:08:03 PM »
I had to pull the nose forward some on my 440 and loosen the bottom radiator nuts then remove the top bolts were they bolt in to the bracket arms. This gave me enough room to pull it out the side. Hope it's the same on a 540
Education is the best defense against the media.
Offline finding the trail
« Reply #2 on: December 23, 2016, 08:14:25 PM »
 I'm guessing you want to warm the fuel in the filter ?
Offline Jase
« Reply #3 on: December 23, 2016, 08:44:00 PM »
Yes, that and to keep his feet warm(er)
Offline Jase
« Reply #4 on: December 23, 2016, 08:45:40 PM »
OK, so the nose and radiator have to move... That is not ideal.. but if one knows going into the project it is a lot better than finding out along the way. Thanks for sharing your experience.
« Reply #5 on: December 23, 2016, 08:58:53 PM »
That's what I had to do to get the fan blade out. I took that grill out and there was six bolts that held the nose on. Took them out and slide it forward a bit. Then did the bolts and nuts on the radiator. That gave me enough room to get my hand in and remove the bolts on the fan. I had already removed the four bolts on the fan shroud and slide it back toward the engine.
Offline Jase
« Reply #6 on: December 23, 2016, 09:49:23 PM »
Ok, that is were we are headed... nice that it is warm tomorrow... Thanks for the replies.
Jase
Online Maine logger88
  • Don't force it get a bigger hammer
« Reply #7 on: December 23, 2016, 11:10:51 PM »
Don't know what model 540 you are working on but on my 540B or a D there is room enough to take it off through the side doors with a (9/16 I think ?) wrench. I've rebuilt the water pump several times on mine without taking the hood or nose off. Tho if you have something handy to lift with it's not a big deal to remove the nose either.
« Reply #8 on: December 24, 2016, 09:43:03 AM »
Your probably right. I was giving my experience of doing the water pump in my 440 and what I had to do to get my big meat hooks in there just to get the fan blade off. It was a 9/16 wrench on the fan bolts.
Offline Beattiebros
« Reply #9 on: December 24, 2016, 09:57:47 AM »
There is room to take the fan out without unbolting the nose piece.On the outside of the nose there a bolt for the top of the radiator that is slotted,just loosen them and you can tip the top of the rad forward enough to remove the fan.i always loosen the fan bolts first,unbolt the shroud,(pull that toward the engine)tip the rad forward,and them roll the fan blame out toward you through the passingers side sidepanel.I learned this way after reading the service Manuel after fighting it a couple times.Hope this helps,not to rain on your cold feet but swapping the fan around on mine didn't change the direction of the way the heat blew I had to buy a different fan,that was a pull not push.
Offline Gearbox
« Reply #10 on: December 24, 2016, 10:06:45 AM »
Who makes a reversible fan that will fit . Just push the blade in and turn it to push or pull . Had one on my 850 case dozer . Would switch to push in the fall to keep the leaves from plugging the grill .
Offline Jase
« Reply #11 on: December 24, 2016, 10:18:29 AM »
Excellent information! This is a big help. Thanks.  We have a new and different fan from JD (8 blade puller type) to replace the 6 blade pusher(I could have mis-counted). Mostly to keep the diesel fuel filter happy, and maybe the operator a little more comfortable.
827 Blade swap
Started by dgdrls on Lucas Mill
Last post November 19, 2017, 04:39:09 PM
by dgdrls
440a john deere skidder------motor swap
Started by phil-tinker on Forestry and Logging
Last post February 05, 2011, 12:28:49 PM
by Bobus2003
skidder with operator for rent in MA/CT for logging or scrap removal
Started by logger444 on Services
Last post June 27, 2009, 09:26:35 AM
by logger444
my skidder blade
Started by cherish on General Board
Last post December 11, 2014, 09:43:00 AM
by cherish
