Arborwear
Author Topic: Stair tread and riser sizing  (Read 728 times)
Offline canopy
« on: December 23, 2016, 08:11:04 PM »
I would like to make some 5' wide stairs with 4' span between supports which are block walls. The plan is to notch the tread into the riser so the front and back of the tread are supported all the way across. Below are pictures of the idea. What size stock is sufficient for this (1-1/2" is shown)? Is the notch shown (3/8" deep and placed 3/4" up the riser) ideal? Rise is 7-7/8" per step and total height 9'.
Offline ljohnsaw
Re: Stair tread and riser sizing
« Reply #1 on: December 24, 2016, 02:16:43 AM »
Depends on the wood.  Are you talking oak or pine?  I would be driven more by aesthetics than minimums.  For that span, I would do a minimum of 2" of either wood.  Are you/have you notched the blocks as shown?
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline canopy
« Reply #2 on: December 24, 2016, 07:46:56 AM »
No work has started on the blocks and I haven't ordered the wood yet. It will be teak which is more comparable to oak. I could go 2", 3" or more thick without any problem. But 12" wide stock in any thickness could be incredibly hard to find and expensive so I would like to build the treads by gluing several narrower boards with splines keying them together if that would be ok.
Offline Heartwood
  • Will Beemer
    • Heartwood School
« Reply #3 on: December 24, 2016, 09:44:56 AM »
Add triangular glue blocks underneath every 12" between the tread and riser, and screw the riser from behind into the tread every 12", and glue the dadoes, and you'll be fine with 1-1/2".
Stair tread caps
Started by coalsmok on General Woodworking
Last post December 04, 2015, 07:01:58 AM
by coalsmok
Amazing trailer riser bunks!
Started by hackberry jake on Sawmills and Milling
Last post November 13, 2015, 08:54:09 AM
by 5quarter
solutions for deere exhaust in limb riser?
Started by green mt treetapper on Forestry and Logging
Last post April 22, 2015, 10:37:17 AM
by tantoy
How to lay out stair treads?
Started by LeeB on General Woodworking
Last post November 24, 2010, 06:31:45 PM
by LeeB
