Arborwear
Author Topic: Rebuilding a Belsaw M-14  (Read 6493 times)
Offline Dieseltim
  • M-14 Project, Sawing with an LT40HD since 04/2017
Re: Rebuilding a Belsaw M-14
« Reply #20 on: February 13, 2017, 09:29:29 PM »
I think we have a good start now.
Offline richhiway
  • Rich
« Reply #21 on: February 15, 2017, 06:45:30 PM »
nice load of steel. be nice to see the progress. thanks.
Logosol M-7
New Holland 35 hp tractor
International T-6 Dozer
Takeuchi mini excavator
Stihl Chainsaws
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #22 on: February 15, 2017, 10:32:28 PM »
Goin'ta be the stoutest belsaw M-14 ever!
1992 LT40HD
Offline Don P
    • Calculator Index
« Reply #23 on: February 15, 2017, 11:32:24 PM »
I mean.
That pile makes me... green.
Offline Joe Hillmann
« Reply #24 on: February 16, 2017, 11:57:05 AM »
Bandmiller2,
  As for the rotation of the engine vs blade, I have read and seen video where the use a rear axle diff to change the rotation. I'm thinking that locking the spider gears would be best. Still thinking about using the oem brakes to stop the shaft rotation when I don't want it to move.
I haven't read the entire thread so maybe someone already pointed this out but, you can't weld the spider gears, all that would do is make it a solid axle.  If you want to use the rearend as a reverser you you have to lock up the drive shaft or carrier.  That way the spider gears can reverse the rotation from one side of the rearend to the other side.
 Or you could mount a brake on the drive shaft to use a clutch to engage and disengage one side of the rearend from the other.  But that only works if you have a brake or enough load on the side you want to disengage.
Offline bandmiller2
« Reply #25 on: February 16, 2017, 04:01:58 PM »
Joe, not my post about welding spider gears, I don't do that. I have on occasion locked one side axle which, as you stated, is the proper way. There are so many things that can be done with a differential, I have seen dandy log loaders using one side brake as a clutch. Frank C.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #26 on: February 16, 2017, 05:31:00 PM »
I take the smaller ones out of old garden tractors to use as
steering reverses.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Gearbox
« Reply #27 on: February 17, 2017, 02:46:35 PM »
Simple turn the rear end over and you reverse the rotation lock up the spiders cut one axel off and you have a angle drive  .
Offline Dieseltim
« Reply #28 on: February 18, 2017, 11:15:54 PM »
Gearbox you are right on. That is exactly what I'm planning to do. Once the axle is locked I will see which side rotates in the direction I want, then connect that up to the end of the arbor on the mill. The rear axle rotates both sides forward, so if you flip the axle housing over then they both rotate the other direction. What was up, is now down so to speak.  Lol
Offline Dieseltim
« Reply #29 on: March 11, 2017, 09:51:36 PM »
s the weather is getting better and the fact that it was a full moon last night, I got more done than I usually do.
Offline Dieseltim
« Reply #30 on: March 11, 2017, 09:56:44 PM »
borrowed a miller bobcat welder/ generator from a buddy of mine this afternoon, so if the weather will clear off again, I'll start welding the frame together.
Offline Darrel
« Reply #31 on: March 12, 2017, 10:08:49 AM »
Good to see some progress!  That steel looks to be quite strong.
1992 LT40HD
Offline Dieseltim
« Reply #32 on: March 12, 2017, 01:11:36 PM »
Yes, Darrel. It is 6x 12" 3/8 thick. Each beam is close to 2000 lbs. Its all my tractor can do to pickup one beam. Good thing we have a boom truck that can pickup 11,000 lbs and the dozer. Once it is all welded together it will be 66 ft long. What you see so far is only half of the length.
Offline Gearbox
« Reply #33 on: March 12, 2017, 01:45:34 PM »
Just reading and thinking . 3.90 gears should work if you turn the engine 2000 it will be 512 RPM . 3.73 would be 536 RPM . 3.55 =563 RPM . 3.23 = 619 RPM.
Offline Dieseltim
« Reply #34 on: March 12, 2017, 04:57:19 PM »
Ok thanks Gearbox. I wonder what rear axle ratio came in a Mercedes 5cylinder turbo diesel D300 with an automatic transmission. I guess I'll have to do some research. I'm thinking they like to run in the higher rpm compared to a truck engine like a 4BT. Higher rpm might be smoother but might burn more fuel.
Offline Gearbox
« Reply #35 on: March 12, 2017, 05:36:43 PM »
If you have the truck see how far it is around the tire and devide by 5280 ft. times 60 to get rpm's at 60 mph . If the engine has a overdrive you will need to figure in direct . I think I would shoot for 550 or 560 RPM at the saw to give you a little pull down to get full fuel and turbo spool .
Offline Dieseltim
« Reply #36 on: March 12, 2017, 05:58:14 PM »
Ok according to the Mercedes sites, an 83 300d has a rear ratio of 3.46 . I don't think the automatic transmission had overdrive back then but even if it does I can probably lock it out.
Offline Gearbox
« Reply #37 on: March 13, 2017, 08:08:26 AM »
That figures out to 576 at 2000 . I think they ran those a lot faster (3000 ?) . Can you use cruise for speed set . If you need more power just shift down 1 gear . Still should run 60 MPH .
Offline Dieseltim
« Reply #38 on: March 20, 2017, 08:43:44 PM »
Got a lot done this weekend.
Offline Dieseltim
« Reply #39 on: March 20, 2017, 08:45:50 PM »
Coming along a little more each day.
what are the do's and don't when rebuilding a 046
Started by whatwas on Chainsaws
Last post April 03, 2018, 09:03:03 PM
by welderskelter
Rebuilding an 044
Started by KyLogger on Chainsaws
Last post September 07, 2012, 09:15:39 PM
by KyLogger
Rebuilding an OWB firebox
Started by Engineer on Firewood and Wood Heating
Last post October 21, 2016, 06:24:11 AM
by coxy
Rebuilding a Stihl 660
Started by JVand10 on Chainsaws
Last post January 09, 2014, 11:36:14 AM
by joe_indi
