Author Topic: Reverse Roll Quarter Sawing  (Read 29876 times)
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Reverse Roll Quarter Sawing
« Reply #100 on: March 04, 2017, 11:25:01 AM »
Doin what goats do.  :D
1992 LT40HD
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #101 on: March 04, 2017, 05:56:45 PM »
In the Goat pen.
Y'all think ya can talk about me and I won't know it.....shhhhhhh....
I got an I on Y'all.....
Or the shorter, easier, and much more convienient abbreviation ......
IGAIOY.  :D
Offline Darrel
« Reply #102 on: March 04, 2017, 06:01:18 PM »
Look out we all have been IGAIOYEd!   :P
1992 LT40HD
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #103 on: March 04, 2017, 08:02:01 PM »
Oh No!  I have been IGAIOYed.
Offline Brad_bb
« Reply #104 on: March 07, 2017, 10:16:26 PM »
I nearly think this post should be a sticky.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #105 on: June 21, 2017, 11:32:32 PM »
One of the things I learned at the Sycamore Project was that I needed a bigger chainsaw bar to more conveniently split big logs in half.  For quartersawing, bigger logs is better, and around here, once they get real big, their price goes down because the big mills don't want to mess with them.  So bigger logs for less money means I needed to learn some tricks of splitting logs.  Customsawyer did a great demo ripping a log in half, so it inspired me to get a bigger bar.
After many, many phone calls I finally located a 52 inch Forester bar.
Here is the long bar, mounted on the saw, resting on the BushHog, and it seems to do real well so far.
Here is also the latest load of quartersawn wood straight from the kiln, about to be dead stacked, for its trip to the planer.  About 3,500 board feet, give or take, some boards more than 16 inches wide.  The owner of the commercial wood millwright shop that does the planing told me that he had not seen quartersawn wood that wide in decades and everybody was talking about it at the shop.
HobbyHardwoodAlabama.com
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #106 on: June 22, 2017, 05:24:49 AM »
That should do the job, 8) 8)
A&P saw Mill LLC.
License NH softwood grader.
Offline warren46
  • Been involved in sawing most of my life.
« Reply #107 on: June 22, 2017, 07:01:20 AM »
One of the things I learned at the Sycamore Project was that I needed a bigger chainsaw bar to more conveniently split big logs in half.  ... So bigger logs for less money means I needed to learn some tricks of splitting logs.  Customsawyer did a great demo ripping a log in half, so it inspired me to get a bigger bar.
I split this one with a 60 cc saw and a 24" bar.  It took a little work with wedges and a maul to finish the job.
I got some 22 inch wide boards out of each quarter.
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
Offline rasman57
  • Location: Manistee National Forest Pine River Michigan and Home in Illinois
  • When you come to a fork in the road...take it.
« Reply #108 on: June 22, 2017, 03:43:05 PM »
Wow.  Sweet!
 I wonder if that blade comes with an optional truss and directions to the chiropractor ... wheeliechair
Offline Savannahdan
  • Retired.
« Reply #109 on: June 22, 2017, 05:22:21 PM »
Just lay the bar and chain on the log and it'll do the work.  Have fun!
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline WDH
« Reply #110 on: September 28, 2017, 07:48:23 AM »
I am going to have to work some more on the finer points of reverse roll quartersawing  :D
Offline Sixacresand
  • John and Nancy
« Reply #111 on: September 28, 2017, 08:11:24 AM »
That happens to me too often, quarter sawing or not.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #112 on: September 28, 2017, 08:25:52 AM »
Danny,
   I never do things like that - unless there is a big audience.
Offline paul case
  • Original wearer of the PCM.
« Reply #113 on: September 28, 2017, 08:42:07 AM »
I thought you was gona talk about reverse roll quarter sawing and here is Danny setting up his skateboard/bicycle ramp on the tire of his sawmill. Obviously he has been grinding that ramp a lot to have the edges all smoothed off at such angles so you know this isn't the first time. ;D ;D ;D
I have had a request from a landowner that we are now logging on, for 800 bdft of q sawn lumber from his post oak trees. They have quite a few that are pretty nice and I hate wasting much of them, so i devised a plan. The logs are big. I think we will be able to saw out a 23'' cant without too much bark on the corners. Then we will saw a 7x9 tie out of the heart leaving 4 pieces that should yield 50% quarter sawn material and the other 50% will be grade,some of which will need edged. I realize that the q sawn stuff will not be perfect, but will yield edged boards that are 6''to 8'' wide.
PC
pc
« Reply #114 on: September 28, 2017, 08:41:51 PM »
Well, it was looking good up until then. :D
Offline Darrel
« Reply #115 on: September 28, 2017, 08:54:22 PM »
I looked across the mill at the other tire to make sure there wasn't another ramp over there. :D
1992 LT40HD
Offline scsmith42
    • Whispering Pines Farm
« Reply #116 on: September 28, 2017, 09:34:30 PM »
oops.....
Tom's 3638D Baker band mill
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #117 on: September 28, 2017, 10:45:05 PM »
I hate it when that happens :D
Hey I have a public service announcement to all you pith measurers..I noticed at the project I was at two years ago that yawl measure the pith from the bed up to it to level it.  We all know that the log aint never in the perfect spot to do that and sometimes its hard to get an accurate reading.  So I'll just share what I like to do, it might add an extra second to the front end but it takes two off the back end and is more accurate.  I bring the head up high enough to clear the whole log front to back, and drive the sawhead over each end of the log and measure down from the blade to the pith to get it level.  Obviously make sure you don't move the head up or down, keep it at say 34" for example. On the WM mills you can slightly adjust the head to being perfectly over the pith if you over/undershoot it.  I just hook the tape to the back of the blade and measure down.  If the log is too big to drive the head over then u gotta eyeba it and trim it first then adjust it or just do it from the bed.
Boy, back in my day..
Offline Darrel
« Reply #118 on: September 28, 2017, 11:18:08 PM »
4x4, that's how I do it.
1992 LT40HD
Offline 4x4American
    • Website Link
« Reply #119 on: September 28, 2017, 11:29:15 PM »
I invented it go away!!  lol
Reverse Roll QS on a manual mill
Started by kelLOGg on Sawmills and Milling
Last post April 12, 2017, 07:03:24 AM
by kelLOGg
Applying Reverse Roll Quartersawing to an Onion
Started by WDH on FOOD! FOOD! FOOD!
Last post July 25, 2018, 07:40:01 PM
by WDH
Quarter sawing!
Started by PM on Sawmills and Milling
Last post December 27, 2007, 10:51:45 PM
by Dan_Shade
Quarter sawing
Started by qbilder on Sawmills and Milling
Last post December 18, 2013, 11:48:25 AM
by qbilder
