Author Topic: Reverse Roll Quarter Sawing  (Read 29213 times)
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Reverse Roll Quarter Sawing
« Reply #80 on: February 28, 2017, 11:02:12 PM »
Congratulations, looks like you zeroed in real quick in picture 2, and nailed the fleck on the first wedge.  The fleck on the wedge look better than the through sawn surface.
I noticed that in picture 5, the log had a LOT of grain change, and the fleck moved a lot, which usually means it is very hard to stay on the fleck, however, you were able to cut boards with full width fleck, which again means you were dead on target, especially with the wider boards, as the technique is supposed to do.  The boards look good.
It also looks like the two full width center cut boards had less fleck than the RRQS boards.  This is something I've noticed also, and I have been taking less boards through the pith and getting right to slicing and dicing, as it allows the log half to be thicker, and RRQS boards to be wider.
I'm glad it worked with a manual mill, was it hard to hold?
HobbyHardwoodAlabama.com
Offline kelLOGg
  • More is better but enough is best
« Reply #81 on: March 01, 2017, 08:23:39 AM »
I think the knots in this trial log contributed to the wandering grain.
The hold felt precarious - it was held mostly by gravity - the clamps and wedges mostly just stabilized it enough to keep the cant in place. I sawed slowly so little disturbing force was applied and nothing shifted. I was pleased how it all worked on this small log.
It did take longer than sawing quarters off the bottom and flipping but some of the time was a learning curve. So far I plan for RRQSing to be my go-to method for QS. We will see when I tackle some larger WO on my rollway. Thanks for the feedback.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #82 on: March 01, 2017, 09:10:28 AM »
Bottom line, you've got yourself some purdy boards.  8)
1992 LT40HD
Offline scsmith42
    • Whispering Pines Farm
« Reply #83 on: March 02, 2017, 08:31:46 PM »
WOW....
Yesterday we tried this technique for the first time and to say the least I was extremely impressed.
We started off with an 11' long WO log with a 19" small end diameter.  This log scaled to 175 board feet on International.  Due to the inherent losses when following traditional quartersawn methods, we anticipate a 30% yield loss over the international scale when following standard quartersawing methods.
However, with the Reverse Roll method we netted 145 board feet actual, which is about 12% greater than expected (18% yield loss instead of 30%).
We followed our standard QS procedures for the first portion of the milling; ie trim off the bark to turn the log into an octagon instead of a square cant, centering the pith on both ends and trimming the bark off on a taper instead of squaring it.  This results in tapered width boards from end to end, but most of our customers don't mind the fact that one end of the board is wider than the other and we get the benefit of a higher yield.
After trimming the bark we followed the Reverse Roll QS method.  We started by marking the medullary rays that we wanted to follow, and then started milling for 5/4 dry measure boards.  Typically we mill 5/4 boards at 1-7/16" to allow for drying related shrinkage (QS shrinks twice as much as FS when drying).
With the reverse roll method we simply lowered the head 1-1/2" with each cut (after aligning the blade with the top of the partial cant after each turn).  After allowing for blade kerf we are netting a milled board right around 1-13/32" thick which will dry to 5/4.
We found the Reverse Roll method to be faster and easier, and one that clearly produced a higher yield of high fleck material as well as a higher percentage of wider boards.
Many thanks for sharing this method.
Tom's 3638D Baker band mill
Offline Qweaver
  • The cabin is done and we love it
« Reply #84 on: March 02, 2017, 08:56:31 PM »
This is what I really love about the Peterson...quarter saw the entire log without turning.  Takes a big log to work well tho'
Online YellowHammer
« Reply #85 on: March 02, 2017, 11:06:10 PM »
Scsmith42
I'm glad the technique passed the test.  When milling for money, such as you do, higher yield and faster production is what it's all about.
Thanks for letting us know about your success with technique.  I'm glad it showed positive benefit.
Online WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #86 on: March 03, 2017, 08:00:07 AM »
Robert, you need to file a patent.
Offline Brad_bb
« Reply #87 on: March 03, 2017, 08:13:08 AM »
If you wanted to end up with some 2 inch dry planed boards (then milled I guess they'd have to be almost 2.5 inches)  would the reverse roll method still be used and could I get QS on both sides?  Or would I just have to accept rift on two sides or quarter on one side and rift on the other?  Part of it would depend on size of log I'm sure- the bigger the diameter, the more forgiving it would probably be to a wider board at the outside.  The biggest I have is 30 on the small end.  I want to build a heavy door like an antique one I've seen and the perimeter rails and styles be quarter sawn WO.
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #88 on: March 03, 2017, 10:38:14 AM »
Thanks for sharing your technique, I have a couple oak logs laying in my yard that I hadn't decided what to do with them.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #89 on: March 03, 2017, 02:15:25 PM »
Quartersaw yes, but I doubt that you could effectively "chase the ray fleck" with a swingmill.   ???
Offline scsmith42
« Reply #90 on: March 03, 2017, 03:20:48 PM »
It depends upon the log but I think that you would be yielding high fleck QS on both faces of the board.  If you want to net 2" after drying and planing, you probably better mill at 2-5/8" green.  QSWO will shrink 12% or so during drying, so a 2.675" green board will dry to around 2-1/4", allowing you 1/8" per side for S2S.
Offline Brad_bb
« Reply #91 on: March 03, 2017, 07:37:16 PM »
Thanks scsmith42!  I have a toe board for my mill now that I will install and show in a post soon.  Next I need to work on a turner and I'll be set.
Offline paul case
  • Original wearer of the PCM.
« Reply #92 on: March 03, 2017, 09:00:32 PM »
I had never purposely set out to quarter saw any lumber, but this thread crossed with a few white oak logs I was sawing for grade I decided to try it. It worked just as well for me and I was using the old mill with the flip clamp. Sure makes some marvelous looking lumber! Thanks.
PC
pc
Offline Darrel
« Reply #93 on: March 03, 2017, 09:45:52 PM »
Paul, I was wondering how my old flip clamp would work, thanks for that bit of info.
1992 LT40HD
Online YellowHammer
« Reply #94 on: March 03, 2017, 10:56:05 PM »
I am greatly pleased folks are having success with this technique.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #95 on: March 04, 2017, 07:51:50 AM »
Sharing is the Forestry Forum way, and it always makes two people happy.   ;D
Offline Brad_bb
« Reply #96 on: March 04, 2017, 08:13:34 AM »
What's a flip clamp?  Pics?  Or better yet Vid?
Offline paul case
« Reply #97 on: March 04, 2017, 08:22:07 AM »
Here is a video. However I know of more of them like mine where the auto up down flipper doesnt work and you use your God given tools to put it up and down.
PC
pc
Online YellowHammer
« Reply #98 on: March 04, 2017, 08:25:30 AM »
Thanks for this writeup. I'll try it next time.  First Bibby the log, then (Yellow)Hammer it! :D :D :D
Hey, I'll call it the YellowHammer Reverse Roll Quartersawing Technique
Or the shorter, easier, and much more convienient abbreviation YHRRQST :D :D
For some reason, "Bibbying" rolls off the tongue better.
Where's Poston when you need him?   :D
Online WDH
  • Forester
« Reply #99 on: March 04, 2017, 10:16:31 AM »
In the Goat pen.
Reverse Roll QS on a manual mill
Started by kelLOGg on Sawmills and Milling
Last post April 12, 2017, 07:03:24 AM
by kelLOGg
Applying Reverse Roll Quartersawing to an Onion
Started by WDH on FOOD! FOOD! FOOD!
Last post July 25, 2018, 07:40:01 PM
by WDH
First quarter sawing
Started by MrMoo on Sawmills and Milling
Last post August 12, 2004, 07:33:30 PM
by Bibbyman
quarter vs through & though sawing?
Started by krusty on Sawmills and Milling
Last post March 13, 2007, 01:32:47 AM
by footer
