Baltic Abrasives Technologies
Author Topic: Duramark 20" Chainsaw  (Read 2587 times)
Offline Haggis
Re: Duramark 20" Chainsaw
« Reply #20 on: October 12, 2017, 10:59:46 AM »
Thanks for the tips.
Offline 630red
« Reply #21 on: October 27, 2017, 06:22:20 PM »
as the lads were saying 70 links of 72 oregon chain with a 7/32 file sounds about right
Offline Haggis
« Reply #22 on: January 17, 2018, 02:35:43 PM »
So still working on this old saw in my spare time. Looks like I am not getting any spark so I first tried changing out the spark plug but still no spark. Took the side cover off to expose the magneto and took that out, was quite dirty inside hoping cleaning it and re-gaping it would have positive results but still no spark. Before I go ahead and purchase a new magneto any suggestions to verify it is the magneto? I have heard you can hook up a D battery and see if it sparks but not sure how you hook it up.
Any suggestions would be great.
Haggis
Offline Haggis
« Reply #23 on: January 29, 2018, 08:18:41 AM »
So I went ahead and purchased the ignition module. Hope that solves the spark issue.
Offline Haggis
« Reply #24 on: April 28, 2018, 03:11:28 PM »
So ignition module worked!! I got the saw running if I pour fuel into the carb. I put some fuel in the tank and tried to start it and it wouldn't tart. Could this be a fuel supply problem? Carb problem? Gummed up fuel filter seems like something easy to try.
Thoughts and suggestion from some of you experts would be  greatly appreciated.
Offline sawguy21
« Reply #25 on: April 28, 2018, 08:49:32 PM »
Time to replace the filter and fuel line as well as rebuild the carburetor. You're getting close!!
