Author Topic: Mobile dimensions mill questions  (Read 2252 times)
Online thecfarm
Re: Mobile dimensions mill questions
« Reply #20 on: January 10, 2017, 08:38:12 PM »
2 of any machinery is good.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #21 on: January 10, 2017, 08:56:53 PM »
Congratulations YC,
I'm thinking its a 126 series (industrial) 1600cc motor??
Looking forward to seeing this resto.
D
Offline yukon cornelius
« Reply #22 on: January 10, 2017, 09:30:25 PM »
I think I am going to start a new thread for the restoration. I will post the pics there. I amexcited to start this adventure 8)
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Offline DanG
« Reply #23 on: January 11, 2017, 09:57:11 AM »
Congratulations YC,
Nope. The engines on the MD mills are highly modified by Mobile Manufacturing. They modify the case to accept a large thrust bearing to withstand the lateral tension of the belts, and extend the crankshaft to accept the pulleys. You need to contact them with the serial number of the mill to find out exactly what engine you have. If the lady doesn't have the manuals that came with it, get them from Mobile. There are some parts that are exclusive to their engines, and they require special procedures when you put it back together.  ;)
Offline dgdrls
« Reply #24 on: January 12, 2017, 05:30:21 PM »
Congratulations YC,
No doubt they mod them, my understanding from talking with MD when I was shopping for one
was they did use the 126 series engines for a period of time.
D
Offline gms1911
« Reply #25 on: January 13, 2018, 09:27:45 PM »
Thatís more of what I was wanting. Thanks everyone. I think I found my mill. Iíve seen pics and now a video of it running. And cutting. Next is a deposit to hol it until the weather gets a little better. Then either a plane flight and rent a truck check it out good. Spend some time with the seller getting to know the mill, haul it home 15 hrs or drive up and do all that. Thanks again. Iíll take some dial calipers with me. Iíll keep yíall informed with a follow up after I look at it.
mobile dimensions
Started by cwk266 on Sawmills and Milling
Last post May 11, 2008, 04:02:06 PM
by cwk266
mobile dimensions
Started by L. Wakefield on Sawmills and Milling
Last post August 26, 2002, 12:42:53 AM
by Steve
Mobile Dimensions saw
Started by 711ac on Sawmills and Milling
Last post May 28, 2018, 12:35:42 AM
by DanG
Another Mobile Dimensions project
Last post December 10, 2018, 11:09:13 PM
by cwk266
