Arborwear
Author Topic: Today's junkyard find.  (Read 51385 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« on: January 09, 2017, 03:03:34 PM »
I found a hand winch, 12" of 2" sq bar stock and this neat mandrel.
At first I was thinking that was factory made but now I'm not so sure.
If you look real close the body look like part of an old car/truck starter.
You can see the screws that would hold the winding in. But the end
covers are both matching covers. Some one built a chuck out of an
old gear. The work that was put into the chuck is an extreme amount
of effort so maybe someone did make the whole thing. I thought this
would make a good jackshaft for something and I'm always looking
for things to build.
Love machine shop work
and Wood work shop work
And now a saw mill work
Online ljohnsaw
Re: Today's junkyard find.
« Reply #1 on: January 09, 2017, 03:33:51 PM »
Cool find.  I have a feeling as you post more finds, there will be a lot of junk yard envy growing! :D
When I want to spin down my drill press chuck, I give a quick flip on the power switch and grab the chuck.  Don't think I'd want to try that on your new chuck! :o
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline coxy
Re: Today's junkyard find. 1/9/2017
« Reply #2 on: January 09, 2017, 06:15:01 PM »
when I was doing scrap  I saw a lot of cool stuff/junk but the yard guy was an   and would not let me take anything even offered to buy some of it at double the junk price someone junked a jd 350 dozer with great tracks and sprockets and I watched them take a shear and cut it to pieces  :'( :'( :( >:(
Offline Mooseherder
« Reply #3 on: January 09, 2017, 07:01:33 PM »
I have something that looks like that.  Mine is used for gear reduction to the final drive pulley on my Chipper.
Lane Circle Mill
Offline Kbeitz
    • My Hobbies
« Reply #4 on: January 10, 2017, 06:11:12 PM »
Today's junkyard find.... 1/10/2017
rochester automatic lubricator. All Brass.
Sure needs cleaned up. I was in the right spot
at the right time. As I was looking around the
truck with the junk came in and was unloading.
It;s 19" tall at the highest point. I will post
more pictures when I get it all shined up.
48.24 lbs of brass.
Offline Gearbox
« Reply #5 on: January 10, 2017, 06:29:06 PM »
I have never seen one like that . Most steam traction and older gas tractors ran Madison Kip . If you ever get the chance take the cover off a Madison Kip . There is a pump with 2 plungers per port and a eccentric cam to work each port .
Offline Kbeitz
    • My Hobbies
« Reply #6 on: January 10, 2017, 06:34:52 PM »
I see this one has 2 plungers .
Offline Gearbox
« Reply #7 on: January 10, 2017, 07:00:34 PM »
Looks like it is a 3 port or 6 . Looked a second time 2 or 4 .
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #8 on: January 10, 2017, 07:37:22 PM »
That's cool 8)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Kbeitz
    • My Hobbies
« Reply #9 on: January 10, 2017, 07:38:18 PM »
Not sure myself. It has two pistons but 4 lines.
Maybe two of the line are returns ?
Offline Gearbox
« Reply #10 on: January 10, 2017, 08:16:34 PM »
Just slowly free it up . That thing is a treasure .
Offline Kbeitz
    • My Hobbies
« Reply #11 on: January 11, 2017, 05:48:54 PM »
Not a lot today... 1-11-2017
Gas valve, Stanley saw, mill jack, lathe drill bits, wood chisel,
lathe face plate, sanding drum. Might get lucky tomorrow.
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #12 on: January 16, 2017, 07:45:57 PM »
Last Sat.
4' rod and tractor chains.
Last spring I got a 6" craftsman joiner.
  In the summer a 10" craftsman T saw
This summer I man walk up to me at the dump and said I give up and handed me the saw.
This fall someone threw it away.  :D :D :D :D
All I did is put gas in it and blew off the yard,  Ann came out and asked where did I get that?   At the dump!!! :D :D :D
The dump can be fun Kbeitz.  8) 8)
Sawing since 1987
Offline gww
« Reply #13 on: January 16, 2017, 08:39:02 PM »
I just have to post a responce here so that when I am in a hurry and only go to the reponces to threads I have posted in page, I will be able to have this thread come up for me to see the new pictures so I can be jealous.
I know this is not the same but it was made with things I found in the junk pile.
I took this old back massuager
and made this honey extractor.  I had everything laying around but the six bucks I spent for paint.
Just finished it today.
I love seeing what you guys find and also what you do with it.  It gives me ideals to steal.
Cheers
gww
Ps I just replaced the jointer motor on the yardsale jointer that is in the back ground with a treadmill motor.
Offline 47sawdust
« Reply #14 on: January 16, 2017, 08:41:26 PM »
Around here they call them transfer stations.You just transfer your stuff for somebody else's stuff.
Mick
Offline Kbeitz
    • My Hobbies
« Reply #15 on: January 17, 2017, 11:53:06 AM »
Today's find... 1/17/17
I got a whole bucket of these bits. They all have the tapered ends.
I'm lathing down the ends to 3/4" and sharpening them up.
The biggest in the picture is 2-1/8" od.
Offline Kbeitz
    • My Hobbies
« Reply #16 on: January 17, 2017, 11:56:33 AM »
I got the oiler cleaned up a bit... Still have a ways to go...
Offline Kbeitz
    • My Hobbies
« Reply #17 on: January 17, 2017, 06:58:09 PM »
Sure had some fun today... Everyone should have a lathe or two in there
basement. Nothing like making chips.
Offline Gearbox
« Reply #18 on: January 17, 2017, 07:12:07 PM »
Blue chips love it .
Offline Kbeitz
    • My Hobbies
« Reply #19 on: January 17, 2017, 08:37:50 PM »
I don't know what kind of metal the bits are made of but i had another
long one that I needed to cut about an inch off the tapered end.
My cutting wheel was near it end and a little short. I cut all but about
1/8" off and took the bit and smacked it on my anvil to finish breaking
the small chunk off and the bit broke in to 3 chunks and fell on the floor.
Now that's what you call hardened steel. Maybe a little to hard. Oh well
easy come easy go. I still got more to do.
Draw Knife Find and Junkyard shave Horse
Started by Jason_AliceMae Farms on General Woodworking
Last post March 30, 2014, 10:45:19 PM
by hackberry jake
Going to find a doctor today!
Started by Woodhauler on Health and Safety
Last post February 25, 2015, 05:33:11 AM
by Woodhauler
Made a Little Find Today
Started by DanG on General Board
Last post June 20, 2012, 10:35:47 AM
by Magicman
A nice find today
Started by Magicman on Sawmills and Milling
Last post September 04, 2011, 09:37:33 PM
by beenthere
