Arborwear
Author Topic: Today's junkyard find.  (Read 51082 times)
Offline ljohnsaw
Re: Today's junkyard find.
« Reply #180 on: July 21, 2017, 05:58:36 PM »
Right handed threads for the driver side, left handed threads for the passenger side keeps the twisting force always tightening on either side.
I don't think it really matters cause most things aren't that way today.  If it really made a difference it would be different threads on everything made - cars, trucks, trailers, etc.  Everything is standard right threads today I think.  There's always an exception to every rule and people love to bring it up to prove people wrong, so look for that here soon...  ;)
If you really think about it, there isn't a twisting force applied to the lug nuts/studs.  If the nut was just on the axle, then yes.  But even on trailer axles, there is a castle nut to keep it from tightening or loosening.  Perhaps this is a relic from long ago (wagon wheels?) or some engineer wrote a really good thesis on it :D  Y'all know that engineers don't live in the real world, I should know, I've got an engineering degree ;D
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline JJ
  • Gotta figure this out
« Reply #181 on: July 21, 2017, 07:10:14 PM »
flywheel bolts.
Offline JJ
« Reply #182 on: July 21, 2017, 07:12:44 PM »
weed wacker hub nuts
also left hand thread.  at least on mine
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #183 on: July 21, 2017, 10:29:46 PM »
But with weed wacker's and flywheels if the shaft stops fast the heavy parts can spin and
take the nut off if not left handed.. This can't happen with a wheel. It does not matter how
fast the wheel stops it can not spin on the hub.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #184 on: July 22, 2017, 08:20:39 AM »
Debarker blade bolt on my LT40 is lefty!
~Chuck~
I LOVE MY SAWMILL
Offline sandhills
« Reply #185 on: July 22, 2017, 10:04:46 AM »
Well I probably ruined my chance for an engineering degree because I changed all the studs to right handed on my grain trailer once, the passenger side wheels never fell off  :D.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #186 on: July 22, 2017, 10:21:11 AM »
I have had a couple of old cars/jeeps with left hand lugs.
The first one was a 46 or 8 CJ2A. I was around 14 and trying to pull the wheels off. I had chiseled off one lug and was starting on another one when my father pointed out that they were left handed.
Hard lessons learned are hard to forget.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline Kbeitz
    • My Hobbies
« Reply #187 on: July 26, 2017, 07:36:37 PM »
I did good today...
550 to 1 gear box
140 to 1 gear box
1000's of 1/2" lock washers.
Gas tank filter insert.
2kw 220/120v to 24/12v transformer.
Ammo box.
weight leveler.
And a wood stove bottom to fit one of my antique boilers.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #188 on: July 27, 2017, 06:24:13 AM »
 smiley_thumbsup
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
« Reply #189 on: July 31, 2017, 07:25:39 PM »
That weight leveler ,is actually for pulling engines, you can adjust it so they come out perfectly level.
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline Kbeitz
    • My Hobbies
« Reply #190 on: July 31, 2017, 09:09:45 PM »
Thanks... I was thinking it was for pouring a barrow.
Offline Papa1stuff
  • Can I trade for an LT70?
« Reply #191 on: August 14, 2017, 10:42:20 AM »
Bump
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Offline Kbeitz
    • My Hobbies
« Reply #192 on: August 15, 2017, 10:01:39 AM »
Stopping at the yard today... Hoping I have something to post...
Offline sandhills
« Reply #193 on: August 15, 2017, 01:03:03 PM »
Me too, I always enjoy your pictures  :).
Offline grouch
  • I'm recyclable!
« Reply #194 on: August 15, 2017, 01:56:05 PM »
While you're there and if you don't mind, slice off a chunk of that junkyard and mail it to me. We don't have any such resource around here. There are several auto salvage yards, but nothing general.
Thanks.
Find something to do that interests you.
Offline Kbeitz
    • My Hobbies
« Reply #195 on: August 15, 2017, 04:28:53 PM »
Jackpot today... First... I helped the boss fix his zeroturn mower so everything shown here today was free.
Whatever comes into this junkyard means nothing to the owner. He only see $$$ as weigh in junk.
He saves out very little for his self. Back of my Jeep was full. This is what happens when you don't go for a while.
It took me around two hours to get it all separated and put away.
I got today...
Nails.
Screws.
Much electrical stuff.
Gear motors.
rotating air connections.
Nits, bolts.
Washers.
Bushings steel.
Bushings brass.
two tractor headlights.
16" ridgid pipe wrench.
3/4" heavy duty eye bolts.
all thread couplers.
Two new steering boxes.
lots of pulleys.
What the thing on the top. It looks like it would fit in a drill and it has bearings in it. It has a square 1/8" hole
in the other end. I checked to see if it was a clutch. It's not. The bottom two things screwed together is
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #196 on: August 15, 2017, 05:17:14 PM »
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #197 on: August 15, 2017, 05:23:04 PM »
Nice finds Kevin, but I just couldn't help myself with the Junkyard Song.   :-X   :D
Offline grouch
  • I'm recyclable!
« Reply #198 on: August 15, 2017, 05:41:55 PM »
I wonder if that pipe wrench got tossed by accident, mixed in with some miscellaneous.
Those look like bronze bushings, to me. Ever done any metal casting? I've always wanted to but never got the roundtuit to build a furnace.
Wouldn't give 2 cents for the electrical switches and receptacles, but everything else looks handy. What were those heavy eye bolts for?
That ain't a junkyard; it's a salvage depot!
Offline Kbeitz
    • My Hobbies
« Reply #199 on: August 15, 2017, 08:23:47 PM »
Had to laugh... But hey... I got the best hardware stuff around....
Thanks for looking...
Draw Knife Find and Junkyard shave Horse
Started by Jason_AliceMae Farms on General Woodworking
Last post March 30, 2014, 10:45:19 PM
by hackberry jake
Going to find a doctor today!
Started by Woodhauler on Health and Safety
Last post February 25, 2015, 05:33:11 AM
by Woodhauler
A nice find today
Started by Magicman on Sawmills and Milling
Last post September 04, 2011, 09:37:33 PM
by beenthere
Made a Little Find Today
Started by DanG on General Board
Last post June 20, 2012, 10:35:47 AM
by Magicman
