Author Topic: Today's junkyard find.  (Read 57921 times)
Offline grouch
  • I'm recyclable!
Re: Today's junkyard find.
« Reply #280 on: September 06, 2017, 04:50:32 PM »
I would have to buy one even though no one here nos how to sew  ;D :-X
Sew what? Them's for plowin'!
Find something to do that interests you.
Offline Al_Smith
« Reply #281 on: September 06, 2017, 05:12:32 PM »
You can see anything at tractor shows .Once in Portland Indiana they made a hot rod from a ground drive manure spreader ,Oak with chrome beater bars and a souped up Chevy 350 engine .
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #282 on: September 06, 2017, 07:43:15 PM »
Tractor shows is my favorite pass time. Going to one this weekend Penns cave Pa.
Hope to take this tractor.
Love machine shop work
and Wood work shop work
And now a saw mill work
Online JJ
  • Gotta figure this out
« Reply #283 on: September 07, 2017, 09:18:38 AM »
That has to be the first garden tractor.  No mowing deck?
Offline Kbeitz
    • My Hobbies
« Reply #284 on: September 07, 2017, 08:10:57 PM »
Home built...
Offline Kbeitz
    • My Hobbies
« Reply #285 on: September 08, 2017, 04:17:24 PM »
Another good day. The air grinder works great. All I had to do to it
was change the end to fit my hose. Even the wire brush is good.
The saw blade and chain came off another good looking Homelite
XL saw. The chain looks newish. I did now need another saw so I
only took the blade and chain. The coil is off a tecumseh engine.
Big $$$ today.
Offline coxy
« Reply #286 on: September 08, 2017, 08:21:02 PM »
that grinder is an oldie so it should be a goodie  dam I'm so jealous if I had a junk I mean a treasure yard I could buy from id never go to work  :D
Offline Kbeitz
    • My Hobbies
« Reply #287 on: September 08, 2017, 08:56:03 PM »
I'm not crazy about the air switch on the grinder. If this thing ever got wrapped up in you shirt
I think you would be in a world of trouble. When it's on it's on. If you let it go it's still on.
But it does do a good job... Maybe I'll hook it up to a foot controlled air switch.
Offline ljohnsaw
« Reply #288 on: September 08, 2017, 11:42:03 PM »
Yeah, I saw that thing and thought, now there's trouble just waitin' to happen...
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 54' - using it all to build a timber frame cabin.
Offline Al_Smith
« Reply #289 on: September 09, 2017, 05:43:21 AM »
That old end grinder is typical of the stuff in industrial use about 50 years ago . It takes a lot of air volume to run one of those style .
Online Chuck White
  • Sawing Mobile since 2005
« Reply #290 on: September 09, 2017, 07:10:40 AM »
Definitely a 2-handed operation running that grinder!
~Chuck~
I LOVE MY SAWMILL
Offline Kbeitz
    • My Hobbies
« Reply #291 on: September 09, 2017, 07:52:36 AM »
Yea it had a 1/2 air connection on it. I dropped it down to 3/8 and it still worked.
I wont use it a lot but it will come in handy for some jobs. I have a large 5hp compressor.
Offline Al_Smith
« Reply #292 on: September 09, 2017, 09:29:15 PM »
When I worked as a welder at Baldwin-Lima -Hamilton a former maker of the Shay locomotives those had 3/4" lines as did all the hand grinders .Of course the plant had a huge supply of compressed air .
A few of those right angle grinders got " liberated " Ingersoll -Rand good ones .Problem was most peoples air compressor could not  supply enough air to run more than a few minutes .
I've got a 5 HP myself dumping into  two 60 gallon tanks at 160 PSI .I've got big air grinders but I seldom use them because the electric is less hassle and the lack of the exhaust air doesn't freeze your fingers .Those dang things will make you go deaf too, loud .
Offline Kbeitz
    • My Hobbies
« Reply #293 on: September 13, 2017, 03:24:54 PM »
Yesterdays finds.
This is the chainsaw that I took the blade and chain off of last week.
The saw was still there saying (take me.... take me...) so I brought it home.
I put gas in it and cleaned it up a little and put the blade and chain back
on it and put gas in the tank. It started right up and ran fine for about 30 min.
Then the coil died, It looks and runs good enough that I'm going to wait for
another saw to come into the yard to rob a coil off of.
The blue thing on the left is a 1" impact gun. All that was wrong with that
was that the trigger was stuck. I needed to remove the handle to get it
unstuck. But now it runs fine. It's the best sounding impact I ever heard.
It sounds just like a single cly John Deere tractor when running.
In the middle is some very expensive TV or stereo  wires.
Not a bad day...
Offline TreeStandHunter
  • ISA Arborist from Michigan
« Reply #294 on: September 13, 2017, 03:46:48 PM »
What type of impact is that? Its huge!!
Currently only have a Panther Mill 2, hoping to upgrade to a WM soon!
Offline paul case
  • Original wearer of the PCM.
« Reply #295 on: September 13, 2017, 05:26:58 PM »
I guess I never saw a receiver hitch bolted to a desk? There has got to be a reason for that.
PC
pc
Offline thecfarm
« Reply #296 on: September 13, 2017, 06:19:03 PM »
A vice holder!!!
Offline Kbeitz
    • My Hobbies
« Reply #297 on: September 13, 2017, 07:18:42 PM »
PC
Yep a Vise holder and a tool holder. Many of my tools just slid into the hitch.
I have them on all my work benches.  I keep many tools under the bench and
just pull out what I need at the time and pin it fast. Saves a lot of room.
Offline grouch
  • I'm recyclable!
« Reply #298 on: September 13, 2017, 11:09:47 PM »
Have you tried testing the impact driver for torque?
Offline Kbeitz
    • My Hobbies
« Reply #299 on: September 14, 2017, 02:54:14 AM »
Not the right way... I'm afraid of braking my 1/2" sockets.
But it does all I need it to do.
Draw Knife Find and Junkyard shave Horse
Started by Jason_AliceMae Farms on General Woodworking
Last post March 30, 2014, 10:45:19 PM
by hackberry jake
Strange find today!!!!
Started by Woodhauler on General Board
Last post August 20, 2014, 06:13:40 AM
by timberlinetree
Going to find a doctor today!
Started by Woodhauler on Health and Safety
Last post February 25, 2015, 05:33:11 AM
by Woodhauler
A nice find today
Started by Magicman on Sawmills and Milling
Last post September 04, 2011, 09:37:33 PM
by beenthere
