Author Topic: Today's junkyard find.  (Read 63728 times)
Offline Al_Smith
Re: Today's junkyard find.
« Reply #460 on: January 10, 2018, 04:36:28 PM »
That 1/2" chain makes me tired just looking at it .I've got a few 1/2" myself and they are heavy .I drag them around if I use them . Partly because they are heavy plus the fact you can't push a chain .
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #461 on: January 10, 2018, 07:24:24 PM »
The chain will be used for bench legs.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline gspren
« Reply #462 on: January 10, 2018, 07:47:15 PM »
I like that idea, I remember seeing a mailbox post built out of chain.
Offline bigred1951
  • logging and sawmilling
« Reply #463 on: January 10, 2018, 08:26:06 PM »
. My old mail box post is a great big chain welded together. My papaw built it and put one of them big metal mailboxes on it. A couple years ago we had to put a wood post and new mailbox up next to it because over the years as our road was repaved and the way the old one sit it was to low for the mailman to reach.
Offline starmac
« Reply #464 on: January 10, 2018, 08:59:25 PM »
If that 1/2 chain is dot legal, them are some spendy legs.
Offline Kwill
  • Cedar cutter
« Reply #465 on: January 10, 2018, 10:54:40 PM »
Hey kbeitz can you post a pic of the piston man 8)
Built my own log arch
In the process of building my sawmill
Offline Kbeitz
    • My Hobbies
« Reply #466 on: January 11, 2018, 06:35:09 AM »
Picture posting is down for repairs...
Offline snowstorm
« Reply #467 on: January 11, 2018, 06:35:16 AM »
In the state of maine that mail box chain post would be illegal.  Nothing bigger or stronger than a 4x4 wood post. I know someone that hit a mailbox at over a 100 mph on a motorcycle. The 4x4 broke and  so did he
Offline Kbeitz
    • My Hobbies
« Reply #468 on: January 11, 2018, 06:35:53 AM »
How do I know if it's dot legal ?
Offline sandhills
« Reply #469 on: January 11, 2018, 09:53:12 AM »
If you don't get caught  ;) :)
Offline Gearbox
« Reply #470 on: January 11, 2018, 10:04:17 AM »
If DOT legal every few links has a flat stamped on the link and I think when new there is a number in the flat .
Offline Kbeitz
    • My Hobbies
« Reply #471 on: January 11, 2018, 11:02:19 AM »
I looked the chain over... No flat spots or numbers... Guess it's just cheap chain.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #472 on: January 11, 2018, 01:02:01 PM »
I have some 1/2" load binding chain from the hold of a C-5, there isn't anything stamped on the chain. There was a small sheet metal plate hooked to a ring but its gone now and the bent grab hook is part of the chain.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #473 on: January 11, 2018, 01:34:05 PM »
Yup, cargo chain!
Stress rated to 10,000 pounds, according to the tag, but they'll do a lot more than 10,000 pounds!
I have a couple of them!
They only have a hook on one end!
We put the two tail-ends together and bolted them with a grade 8 bolt a few years ago and put it to a stress test a few years ago, pulling a cement delivery truck out of the mud, and the 75 hp tractor with all it had did not snap the chain, and eventually freed the truck!
The bent hook is really nice, when you hook them, they stay hooked!
~Chuck~
I LOVE MY SAWMILL
« Reply #474 on: January 11, 2018, 01:48:03 PM »
Sounds like a 10k working load vs break strength. The real question is, is it a 4:1, 5:1  or a 10:1 for the working load to break strength ?
Offline starmac
« Reply #475 on: January 11, 2018, 05:12:03 PM »
If it is a newer chain, there should be a grade stamp on it, seems like 7 is the magical number. If it is an older chain it is probably a good one, but may not have the stamps. I have never had the dot check for the grade, but they can if they want.
1/2 in chain would only be of use to guys running lowboys or hauling heavy equipment, a general freight hauler will not use it.
Offline Kwill
  • Cedar cutter
« Reply #476 on: January 12, 2018, 08:59:14 PM »
ok
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #477 on: January 15, 2018, 08:37:50 PM »
Has a 2/1 gear ratio. I have no idea what I'll use it for but I think it's cool.
1992 LT40HD
Offline JV
  • Live - love - laugh a lot today.
« Reply #478 on: January 15, 2018, 08:56:49 PM »
Early angle drive for drill or brace.  Possibly for buffer head.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Offline Kbeitz
    • My Hobbies
« Reply #479 on: January 16, 2018, 02:33:47 AM »
First drill at top left has one...
Draw Knife Find and Junkyard shave Horse
Started by Jason_AliceMae Farms on General Woodworking
Last post March 30, 2014, 10:45:19 PM
by hackberry jake
Made a Little Find Today
Started by DanG on General Board
Last post June 20, 2012, 10:35:47 AM
by Magicman
A nice find today
Started by Magicman on Sawmills and Milling
Last post September 04, 2011, 09:37:33 PM
by beenthere
Going to find a doctor today!
Started by Woodhauler on Health and Safety
Last post February 25, 2015, 05:33:11 AM
by Woodhauler
