Author Topic: Stihl 311 Not Cutting Like It Used To Cut  (Read 522 times)
Offline GaTrapper
« on: January 09, 2017, 06:32:00 PM »
Hey Y'all,
A year ago I purchased a Stihl 311. It would really rip through the wood without a problem. I would sharpen the chain when needed and never had an issue.
Lately, it's been cutting slower than normal. I don't know if my chain is getting worn out or what. This is the second chain I've had in the past year.
What can I do to diagnose and fix the issue?
Offline Texas-Jim
Re: Stihl 311 Not Cutting Like It Used To Cut
« Reply #1 on: January 09, 2017, 06:48:50 PM »
First thing i tell everyone who complains about saw not cutting. If saw is running good but not cutting, check the chain. Is the angle right? And often forgotten did you or who ever sharpen it do the rakers? Even a sharp chain wont cut if rakers are too tall.
What we do in life echoes through eternity.
Offline thecfarm
« Reply #2 on: January 09, 2017, 08:03:19 PM »
Hard to say. A chain,chainsaw,should really go into the wood with just the weight of the saw. I mean,the chain should draw itself into the wood. A chain that is sharpen correct,you should be able to hang onto the the rear handle and it should draw into the wood. This is not a safe way to run a saw either.
Offline GaTrapper
« Reply #3 on: January 09, 2017, 08:28:36 PM »
Went back and checked the rakers. There were a handful that needed a quick touch up. Would that have a major affect on the cutting?
Offline JW IN VA
« Reply #4 on: January 09, 2017, 08:43:14 PM »
 What method do you use to file?Check raker? Stihl and Oregon have gauges you can easily check raker height with.If its been cutting well and stopped, you probably need to file the rakers or use a new file on the teeth.Had one of my saws not cutting right for  very long after filing.Got out a new file and fixed the problem.
 Sure is nice when the saw is taking itself into the log.
Offline thecfarm
« Reply #5 on: January 09, 2017, 08:53:52 PM »
A few more things,puting the bar in a vise when filing? Are you hand filing? Using a gauge?It took me a few chains to understand what I was doing wrong. Finally I just took a big log and kept filing and sawing and remembered what I did if it was better or worse. Did not have much left of that chain,but I got it.  ;D
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #6 on: January 09, 2017, 09:28:13 PM »
Does the chain wobble from side to side in the bar, the cheaper bars go bad faster and cause your saw to cut funny or not to cut much at all.
Offline ZeroJunk
« Reply #7 on: January 09, 2017, 09:45:43 PM »
Put a new chain on it and see if that puts it back to normal. Not many people including myself can sharpen a chain to cut as fast as a new one.
If that doesn't seem to help check your compression.
Offline ladylake
« Reply #8 on: January 13, 2017, 07:19:16 AM »
 For sure try a new chain
 Rakers have to be taken down after maybe 3 sharpening's
 Check the muffler screen, if clogged that cuts power a lot.    Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Stihl 120 cutting off
Started by derakicksyou on Chainsaws
Last post July 05, 2015, 01:23:51 PM
by zandoval
Stihl 029 cutting-out
Started by tstex on Chainsaws
Last post December 25, 2008, 11:52:12 AM
by Weekend_Sawyer
Stihl ms361 cutting out
Started by Filthyliam on Chainsaws
Last post April 04, 2015, 02:25:51 AM
by Filthyliam
Stihl 029 cutting crooked...
Started by Thehardway on Chainsaws
Last post June 09, 2013, 08:04:01 AM
by ladylake
